Question about Ricoh Office Equipment & Supplies
When copying checks for our records the copy comes out completely black
  • 62 Answers
SOURCE: Canon NP-4050 printing almost completely black pages
This problem appears to be that the scanlamp cable has fatigued and become open-circuit. This can be checked by selecting A3 and pressing the START button while having the lid up. Watch to see if the light stays on all the way through the forward pass of scan cycle, it can be intermittent. Make sure that the machine is unplugged before attempting to replace the cable.The drum is definitely on its way out at that amount of copies, but can be made to last a fair bit longer with some fine-tuning.
Posted on Nov 09, 2007
bandana_gyrl
  • 181 Answers
SOURCE: black line on my fax copies!
You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Posted on Feb 28, 2008
  • 134 Answers
SOURCE: Black Copies
It could be a bad voltage board, which is not supplying enough power to the lamp.
Posted on Jun 30, 2008
SOURCE: Each succeeding copy gets darker and darker
When was the drum replace? Recently? Could it be time again?
Was it a remanufactured unit?
Regardless of all that, It sounds to me like the drum is failing.
Posted on Apr 11, 2009
  • 255 Answers
SOURCE: Copy machin SHARP SF-7320
Check the copy lamp and its thermal fuse if they are okay, then clean optics, check drum and blade and clean or replace and finally clean or replace fuser rollers. If the above is ok and still black copies, check the copy lamp wire harness for continuity or the copy control board located underneath the display panel and check for bad component like triac and replace. If OK replace the main control board.
Posted on Dec 01, 2009
My HP photosmart is printing out completely black pages when i put something in to copy!
It would be worth checking if the lamp is coming on when it scans the original in for the copy. I bet it isn't...
Aug 31, 2010 | Office Equipment & Supplies
Trying to copy home videos onto dvd thru dazzle product connected between vhs player and my computer. Can witness video on computer monitor while recording and says copy is complete. But when I check dvd...
Open again your Intant DVD Recorder and then after that do the advance mode. Next on step number 1 click the full down arrowed and then choose your dazzle device. On step number 2 click on the full down arrow and choose your DVD writer. Make sure that you already inserted your DVD blank disc then hit prepared button message comes out just click okay.
Nov 17, 2009 | Pinnacle Dazzle DVD Recorder
Out going fax is coming black
FIRST test copying. if the copy come out completely black, then the exposure or scanner lamp or contact image sensor is dead,not lighting on. Now if the copy has black only black lines on it,then you can clean the place where the document passes thru where the light of the exposure lamp projects unto the text of the document being scan,which is the small glass on the left side of the platen glass when you open the auto document feeder.NOTE: Lay your document on top of the platen glass & make copy if the copy come out clean as you needed it,then the lamp is O.K. Then the small glass just need to be clean. If the copy is completely "BLACK", then the lamp is dead, or the circuit that control it. In thus case then you need a technician to do it
Jul 14, 2009 | Panasonic KX-MB781 All-In-One Laser...
Fax problem
Something is blocking part of your scanner light, or scanner light may be bad. Check if the scanner light comes on, and check inside the original feeder and machine for a scrap of paper blocking the scanner light to the imaging drum.
Nov 26, 2008 | Brother IntelliFax-2820 Laser Fax
Errors burning to 1x to 16x DVD-R
I have had much luck recording on off brand 16X discs as follows:
1) Record a "dummy" program on the hard drive, need only about 15 or 20 seconds.
2) Put a blank disk in drive, and COPY that dummy program to disk. Do not finalize.
3) After a minute or so, window will come up and say "Cannot
complete copy."
4) Now while above window on screen, click HOME MENU, COPY, New program list, Select your movie/program to copy, go ahead and finalize, and START.
5) Think you'll find this is successful, however there might be some brands of blank disks that won't work.
6)Let me know if it works for ya. JGIDUSKO@CFL.RR.COM
Jul 04, 2008 | Pioneer DVR533HS DVD Recorder with 80GB...
Voice Recorder
It could very well be related to Vista - go ahead and upgrade the firmware on this player from the Sandisk website
Feb 08, 2008 | SanDisk Sansa c240 MP3 Player
Dvd recorder wont finalize etc
The DVD drive works harder when trying to record the info faster. As the unit ages, tracking is less precise. DVD-R copies occur at 4-16X real time. Try DVD-RW disks which copy slower (now that the price has dropped substantially), and you may find that your aging drive can still copy programs from the HD to the DVD.
Oct 16, 2006 | Pioneer DVR-530H-S DVD Player/HDD Recorder
469 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
