Question about Shure SM57 Professional Microphone
Compare the Shure SM58 to AKG D5, which is the best for male lead vocals?
  • Shure Master
  • 3,368 Answers
I use the SM58! That is what it was designed for.
Posted on Jun 01, 2014
5 Suggested Answers
night71
  • 328 Answers
SOURCE: feedback
That is a great mic. It has a lot to do with the room your in and acoustics of it. If you are too close to your PA or monitor, it will also feedback. Lowering treble and reverb will also help.
Posted on Nov 04, 2007
robotek
  • 1512 Answers
SOURCE: shure sm58
Hi danny
There not that much to take apart on the sm58. On page 2 of the user manual there is a wiring diagram to reconnect wires. the grill wind filter part screws on. The socket on the bottom is secured with a screw.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jul 04, 2008
  • 1137 Answers
SOURCE: Reparing a Shure SM58
If your talking about the coilwires on the diaphragm, you have to be very good at soldering with a variable temperature contolled soldering station, good magnifiers and pretty much one shot a doing it. You will have to carefully remove the varnish from the wires and bridge the broken gap with more of the same diameter wire. You are better off replacing the capsule. Hope this helps.
Posted on May 26, 2009
  • 211 Answers
SOURCE: re-solder shure sm58
If you're careful, you can solder it yourself.
Just solder some thin wires to the lose ends.
After soldering use some cellotape to isolate the solderingjoint and to attach the wires to the element.
If you're not familiar with soldering tiny things, please don't. Any technician can fix it for you.
Good luck,
Gerard
Posted on Mar 05, 2010
Eq for male vocal mic on mackie 1604 vlz3
There is no easy answer to this. It will depend on the mic, the speakers and the singer and genre amongst many other things. It will also probably be room dependent too although the overall eq should be able to take this out of the equation to a large extent.
Your best bet is to get someone to sweep the frequency on the mid range with a bit of positive and then a bit of negative eq to find where most affects your vocals then fine tune to your liking. Are you using a bit of reverb/chorus/echo as his can often, when used sparingly, enhance even a good singer. The biggest difference you'll probably find is from using different mics. The ubiquitous SM58 does not suit everyone but is robust, warm and forgiving but if you're after a more pure sound there are many more accurate mics you can try.
Aug 10, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
Error code F441 on akg HT 450
Anyone find an answer? Or did you just buy a Shure?
Mar 13, 2014 | AKG Ht450/D Wireless Uhf Handheld...
T2i have a shure SM 58 wireless mic and nack in placeeed to know where wires are on the mic section so as to solder b
The wiring diagram can be found in the User Guide for the SM58. It can be downloaded on Shure's website.
Dec 01, 2013 | Shure SM58 Professional Microphone
Hi, i would like to buy some sharp microphones, two for lead singers and 6 for musician. can you give me some advice on what types i should get?
Hello
microphones broadly fall into 2 distinct types
  1. Condenser - requires a power source either a battery inside the microphone itself or remote 'phantom power' usually provided from a p.a. mixer.
  2. Dynamic - do not require a power source. Most famous of all is the Shure SM57 (instrument / vocals) and SM58 (lead vocals) used by many musicians and singers around the world.
Condenser microphones are used extensively in recording studios because they are very sensitive and have a better range than dynamic mics. However they are a bit fragile and good ones are expensive. There are plenty of cheap condenser microphones about but they give a rather tinny sound.
If you want the microphones for general band work, especially gigging you will get better value for money with dynamic microphones. These are much less sensitive that condenser mics and are intended for close up work - no more than a few inches from the mouth of the singer (use a pop shield to prevent unwanted noises) or hung close in to an instrument.
There are also 3 different pick-up patterns for microphones. Which ones you go for will depend on the use for which they are intended.
  1. Cardoid - cone shaped directional pick up pattern. These will only pick up sound from in front of the microphone in a cone shape of about 60 degrees. Suitable for general vocals and instruments. Good resistance to feedback. To effectively mic-up a big instrument like a piano you may need to use more than one mic.
  2. Hyper Cardoid - as above but with a much narrower pic-up sone - a cone of about 30 degrees. These are very good for lead vocals as you can drive them a bit harder without risk of feedback or picking up other instrument sounds on the stage (particularly useful if you have a singer who plays an a loud acoustic instrument or a keyboard with built in speakers). THese are okay for using to mike-up an instrument where the sound comes from a small fixed point (saxophone, violin, trumpet, acoustic guitar - provided that the musician stands still) but not much good for larger instruments like pianos or harps. They are also good for mike-ing guitar amps, but only if they don't have a separate tweeter.
  3. Omni-Directional . These will pick up sound from all around. Whilst they can be good for picking up large acoustic instruments or choirs they are very prone to feedback and are not really suitable for public address purposes.
Don't be tempted to buy cheap microphones with permanently fitted cables, especially ones with a standard 6mm jack-plug. Always go for mikes with a balanced (3 pin xlr) cable as they do not pick up as much radio interference on the cable (but only provided your mixer/amp also has balanced inputs too).
Although many professionals swear by the Shure SM57 and SM58 mics mentioned above I personally prefer the AKG D55 a hyper-cardoid which has a longer pick-up range and higher output than the Shures (useful if musicians or singers hang back a bit from the mic) and usually slightly cheaper too. It is really good for lead vocals but makes a good instrument mic too with a nice crisp but warm sound across the frequency range.
For larger instruments, or two backing singers sharing a mike, I use the standard cardoid version of the same AKG (but I'm afraid I can't remember the model number now).
If you want to mike up drums that is another subject all together.
Jan 31, 2011 | Sharp Audio Players & Recorders
Shure pgx sm58 vocal system... receiver is excepting transmitter but no audio.. I tried to sync it to different channels but still no audio.
Unfortunatley, it is quite difficult to troubleshoot a wireless mic over the internet, as there are many, many things that could be causing this problem. I'd really suggest contacting Shure, as they can best help you troubleshoot any problems that you are having. You might need to send it to them for repairs.
Aug 26, 2010 | Shure (PGX2SM58H6) Professional Microphone
Where to buy a the swivel adapter for shure sm58 and shure wireless lx2 sm58
You can buy the swivels from Beyer, they have several sizes.
In my opinion he best you can get.
Regards,
Gerard
Jan 05, 2010 | Shure (LX287CC) Professional Microphone
Finding dealer
Use the link at the bottom of this blurb.  Best of Luck to you!
Beware of Fake Shure Microphones Being Sold in the Market
AIO | Just Announced
Wed 27 Aug 2008
icon_digg.gif digg this   icon_slashdot.gif slashdot this
sm58%20with%20sticker.jpgManila, Philippines -- The Shure SM58 unidirectional (cardioid) dynamic vocalmicrophone is designed for professional vocal use in live performance, sound reinforcement, and studio recording. It has a tailored vocal response for a sound which is a world standard for singing or speech. A highly effective, built-inspherical filter minimizes wind and breath "pop" noise.
A cardioid pickup pattern isolates the main sound source while minimizing unwanted background noise. Rugged construction, a proven shock-mount system, and a steel mesh grille ensure that even with rough handling, the SM58 will perform consistently, outdoors or indoors.
The fake ones don't even come close.
To know which is authentic, look for the holographic stiker, or ask a Shure sales representative at any official dealers or Audiophile branch.
Buy only from authorized Shure microphone dealers:
-A. Salonga Raon
-Audiotech
-Avesco Mktg.
-Cardinal Audio
-Ginza
-M.L. Rapacon
-One Stop Music
-Pace Electro
-Persona Mktg.
-Phasetron / Kinetic
-Pure Sound -Sanjun
-Santech
-Stagepoint
-Watson's Electronics
-A. Salonga Cebu
-Better Components
-Cebu Appliance
-Dream Circuits
-JVS Bacolod
-JVS CDO
-JVS Dumaguete
-JVS Gensan
-Music Box II
-Music World
-Proline Electro
-Tanedo Electronics
-Toneworkz
-VJS Cebu
Shure Microphone products is exclusively distributed in the Philippines by Audiophile Components Inc. Visit the website at www.audiophilecomponents.com
Jan 13, 2009 | Shure Beta 58A Professional Microphone
Shure SM57 Professional Microphone Logo
47 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
