Question about Garden
Toro lawnmower that won't start after dumping the clippings. Starts up first time, but each time it is stopped to empty the bag the starter turns over, but the mower will not start.
  • Jim Agler Aug 12, 2013
    After the mower is warmed up it won't start after stopping to dump the clippings. It smells of rich gas, and acts like it is chocked
  • 226 Answers
SOURCE: My Toro self perpelled lawn mower starts then conks out.
It sounds like your fuel system is plugged up (or water in the carb) First i would make sure there is good fuel supply to the carb, then if so & not running, I would remove the carb and clean as it appears that it is running properly otherwise. Also check your air cleaner element as it may be totally plugged up.. Hope this helps you, Rick
Posted on Apr 27, 2009
SOURCE: riding lawnmower starts but will not continue stay running?
its probably in your ingnition switch, grab the switch and turn it right the turn key I had the same problem and that fixed it. It also wasnt starting and it was the same problem the switch is lose.
Posted on May 31, 2009
  • 634 Answers
SOURCE: Engine starts when primed but stops in seconds
it sounds like you have contaminants in the fuel and have clogged the fuel filter or carburetor, try changing fuel filter if there is one and back flush the fuel lines with carb cleaner spray and clean out fuel tank and clean with brake cleaner refill with fresh fuel.
Posted on Aug 22, 2009
digritz
  • 530 Answers
SOURCE: troy bilt lawnmower not starting
In most cases it's not enough to just dump the gas out of the float bowl. The problem is that the gas has turned to varnish and varnish is sticky. It will put a nice coating over all the the interior of the carb. The only way to clean it is to dismantle it completely. This means removing the float bowl and float. Along with the needle.The important thing is that both the float and needle move freely and both the high and low idle screws are clean. Depending on the type of fuel filter you may also need to remove and clean it as well. If it is not an inline filter it most likely is located inside the tank. As long as your careful not to tear the float bowl gasket you shouldn't require a rebuild kit for the carb.
Hope this helps.
Posted on Sep 16, 2009
Testimonial: "WOW! Thanks for the taking the time to put in all the detail.As soon as I get a chance, I'll take it back apart.Again thanks for your time Appreciat!"
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Posted on Nov 11, 2012
Toro personal pace 20372, starts fine, runs well for 30 or 40 minutes then dies. Starts up again when cooled down just a bit.
Need fuel that is not more than a couple months old
Need a good or clean spark plug
Have no idea how old it is, or how many years
you have used it
Sometimes you have to remove the head & clean the
carbon off the piston & head
That is a tune-up on small equipment
Make sure the air filter is clean
They usually start with the air filter off,but you don't
want to do that all the time
Jul 21, 2014 | Toro 20372 Recycler Personal Pace...
I have a Toro 16.5 riding lawnmower it stop and wouldn,t start back what could be my problem?
Battery charged? Bad fuel? Low on oil? 30w oil required. Clean carb. Check for improper ground on starting circuit. Ignition switch providing power to starter when key turned? Always use Stabile in gas. Remove bowl from carb ensure float is working properly. Float up no fuel flow, float down fuel flow. Ensure oil is full, low oil shutoff will not allow starting.
May 30, 2013 | Toro Lawnmower Lawn Mower SP Drive Belt...
My 22" cut toro lawnmower with its 190cc Briggs & Stratton motor with automatic choke starts easily when cold and runs well. When you turn it off to empty the grass clippings bag, it will not restart...
You may want to check valve clearance, sounds borderline. You should have 11/1000s on the exhaust valve.The exhaust is usually the culprit, since it runs hotter.
Oct 05, 2010 | Toro Lawn Mower With Toro Power Tools
I have toro lawnmower starts for helf minut then shots off 22 inch front drive y-5tpxs 195
Sounds like its not getting enough gass. It starts then dies because there isnt enough gas getting to the engine.
May 01, 2010 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Clippings not going into catcher...dropping onto lawn
ck the outlet of the deck and any connection between the deck and bag for debis build up.
Sep 13, 2009 | Garden
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
