Question about Garden
I have a Powercraft chainsaw with no spark. I know Chinese plugs can be dodgy, but how do I check the ignition coil. I'm thinking this could become more expensive than the thing is worth!
  • 1,807 Answers
Check the spacing between the ignition module and flywheel, should be generally the thickness of a business card between the two. Try plugging in anothe ppark plug into the HT lead and earth it on the cylinder to see if you get a spark, that should rule out a dodgey plug.
Posted on Aug 01, 2013
Testimonial: "Thanks, I'll give that a try, before binning it!"
  • 3 Answers
SOURCE: Wild Thing 18" chainsaw model 952-051338 Spark
Spark plug size= 3/4 or 19mm. Champion RCJ--7Y gapped to 0.025.
Fuel mix= synthentic 40:1.
http://www.manualsonline.com/ex/thread/view/idThread/3524133
Posted on Oct 24, 2010
joboo1
  • 257 Answers
SOURCE: I have a powercraft chainsaw, do you know the
Hi, Most chainsaws use three mixes, which are 32:1, 40:1 or 50:1. Most are labeled somewhere on the saw. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little, it is supposed to smoke some. If you see any oil coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
Posted on Mar 05, 2009
  • 226 Answers
SOURCE: Craftsman Chainsaw will not start
It's your ignition, which you can take that stuff apart on the left hand side of the saw under the recoil. I have 2 of these, & you can get the parts. Maybe its just the magneto gap adjustment, which is like a business card or newspaper width gap. I would check that first. Hope this helps you, Rick
Posted on Apr 29, 2009
steve_lima
  • 181 Answers
SOURCE: Gas chainsaw has no strong spark and wont start
the air gap should be .012", the gap you have it set at is to small.reset the gap and try it again.......hope this helps,let me know........
Posted on Jun 02, 2009
dontbother10
  • 2220 Answers
SOURCE: wanted coil ignition module for Husqvarna 394xp chainsaw
I found an IPL for your saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 394 as model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I chose the 92-10. The coil and wire were manufactured as separate pieces. I found both at Jacks Small engines. It is interesting that the same ignition wire fits a Poulan at 1/2 the cost. About $86 for both pieces at Jacks. HTH
Lou
Posted on Oct 19, 2009
Testimonial: "Most interesting and very helpful Thank You"
Ryobi C4618 chainsaw worked great for two years, sat for a year. Fresh premium gas, fresh chain oil, fresh spark plug. Getting no spark. Ignition coil? Oil cut out?
check switch first then coil. Use a multimeter and set the positive lead of the multimeter in position where the spark plug would usually insert
ensure it has made good contact. Place the negative lead onto the metal body of the ignition coil. A working ignition
coil will give a reading of between 2.5 - 5 k ohms. Hope this helps.
Sep 18, 2016 | Ryobi Garden
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
EU3000is inverter generator. Why won't it start?
Check the switch on /off is not faulty try taking the wire off the switch that goes to the motor mine had that problem (lot of dodgy switches fitted to them ,make sure the choke is closing on fully.check spark plug not fouled up with carbon.
Oct 03, 2015 | Electrical Supplies
Cpi 50 formula r got no spark
Hi, Anonymous if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
Chinese scooter NO SPARK
My scooter has no spark how to fix gy6 chinese scooter 139qmb qmb139 50cc...
https://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
CPI Formula 50 2009
Mar 19, 2013 | 2009 Cpi Formula R 50
Diamo 200cc no fire
Hi, Corey and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
troubleshoot motorcycle not starting
http://www.carlsalter.com/diamo-service-manuals.asp Scooter Parts for Chinese Scooters Atvs
Chinese ATV Owners Repair Manuals
Apr 29, 2012 | 2009 Diamo LS 200
250cc Baja bike won,t start, no fire from spark plug
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Chinese scooter no spark kit
Madass No Spark Test Part 1 wmv
How to diagnose no spark situation on motorcycle
new scooter 2010 need help no spark 50cc got it fix was the mag
Mar 31, 2012 | Bajaj Motorcycles
I just acquired a 1969 benelli buzzer and it doesn't have spark so I am trying to figure out the wiring from the magneto to the coil. I also don't know what the fuel mix ratio is for the bike...
Hi, Cole_bliven if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial BENELLI MINIBIKE
https://www.hagerty.com/price-guide/1969-Benelli-Buzzer
Jun 13, 2011 | Benelli Drakon NKD 50 Motorcycles
It's about Husqvarna 345 chainsaw. I would like to know the resistance value between spark plug wire and blue wire from ignition coil, and between spark plug wire and the ground and finally resistance...
The easiest way to test is on the machine. Remove the ignition switch wire from the module coil. Check the pole gaps of the module by inserting a thin business card into the gaps after turning the flywheel magnets under the module. Loosen the module mounting screws to allow the module to contact the magnets, tighten the screws, and turn the flywheel slightly to release the card. Turn the flywheel one full turn to make sure the gaps don't close up further. Use a fresh spark plug gapped at 0.020" and try for spark. If nothing, replace the module. This gets around measuring resistances while trying to evaluate the module. Hope this helps!
Nov 21, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Husqvarna chainsaw stops when using it
Check for spark after it quits. If none, the ignition module may be dying when hot. If ok, check the muffler for plugging. Use compressed air to remove sawdust from cylinder and head area. If everything looks good, note whether the spark plug is getting wet with fuel after trying to restart the saw. If dry, check the fuel lines for cracking or other deterioration. Make sure the fuel tank vent is clear of debris. (Loosen the fuel cap for a moment, then see if it will start.) Hopefully, one of these suggestions will hit on the problem!
Feb 19, 2010 | Husqvarna Chain Saw 20" Bar
Xg wg50 wireing diagram
Hi, Xsprodb if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial Benelli service manuals page 4
2008 Benelli BX505 Enduro
Mar 30, 2009 | 2008 Benelli Bx 505
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
