Question about Bluebird Microphone
My mic head broke off pulling the wire completely out. How do I reconnect it?
Galaxy dx 44hp, no am audio or mod ,fm & pa ok
Have you tried another mic. First guess microphone wire broke or broke solder for audio wire in mic jack at mic cord.
Mar 26, 2014 | Galaxy Radios DX-44HP Mobile Amateur Radio
5 pin astatic corba cb mic
take the mic plug connector an check the wireing that broke off and just rewire it the same way
Jul 27, 2013 | Cobra Radio Communications
My xbox 360 mic is acting up. I can talk to people but I can only hear them if the plug is twisted to a certain position
Sounds like a wire broke inside. That's why it only works when you have it in a certain position. Unless you are good at splicing wires, move the wire till you get it to work, and wrap it in that position, then don't move it at all. Good Luck.
Jul 01, 2012 | Eforcity HEADSET W/ MIC CONTROLLER FOR...
Audio Tech at831cw lapel mic wires disconnected
normaly when pulled out the cable is also come inside defective, probably better a new mic spare. you can spend time repairing and still no working well
Jan 02, 2010 | Audio Players & Recorders
Pull cord is out and wont return. unable to crank
they spring clip is broke, you have to take the head off and reconnect. You have to get a new head or spring, depending on which one failed. Good luck
Jun 09, 2009 | Garden
No sound
I removed the cover on the back (the access to musicartridges) I also removed wireless receiver unit (approx 2" black plastic piece) pull straight up to remove. after removing the receiver you'll see two screws, remove them, unscrew the mic head, pry the body apart (fingernails). You will see two circuit boards, the smaller one became disconnected. The board should reconnect easily, the outlet looks almost like the wireless receiver outlet you removed earlier. if it does not slide in easily DON"T force it, you may be trying to install into receiver outlet ( They look the same), The correct outlet is above (towards mic head) the four outlets to the music cartridges. CAREFUL NOT TO BEND PINS same with the wireless receiver.
Aug 31, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Bluebird Microphone Logo
44 people viewed this question
Top Blue Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Are you a Blue Audio Player and Recorder Expert? Answer questions, earn points and help others
