Question about Bionaire BT45RC Tower Fan
Tower fan rotating rotate
The fan will not rotate, please advise what I should do to correct this. Thanks
Why blades are not rotating or throwing air?
some of these have a expansion pin that holds the fan blade assembly onto the shaft, this may have fallen out or ? broke,,,
May 13, 2014 | Seville Classics MSC10166 Tower Fan
Will not rotate
You need to check the manual. try here
ceiling fan manuals
Dec 14, 2013 | Tower Aloha Breeze Fan
My tower fan(not a lasko) but very similar cuts off when i put it to rotate.
Sounds like a short in the wire. Return it before it burns your house down.
Oct 10, 2012 | Lasko 2554 Tower Fan
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
Hi, we just got a new woods 59017 timer, and the dial turned until it turned off, at the point that we indicated, but after it turned off, the dial remained stuck in its place and will not turn any...
You have new 59017 single-pole in-wall 24-hour timer with tripper pins located on dial.
Timer is heavy duty and will handle up to 2500Watts 1 HP, including anything typically controlled by 15-20Amp light switch: incandescent, florescent, CFL, motor, pump, AC, whole house fan, etc.
http://waterheatertimer.org/images/Woods-59017-mechanical-timer-300.jpg
When timer is wired correctly, timer dial rotates no matter which position slide switch is set to.
Your dial rotated correctly and turned lamp ON, and rotated correctly until lamp turned OFF, and then stopped rotating.
This implies loss of power.
Check circuit breaker.
Check for loose wire on timer installation.
If wiring checks out, then timer is suspect. Replace different switch with suspect timer, and see if timer works on different Load.
http://waterheatertimer.org/images/GE-15070-wiring-1-500.jpg
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
Aug 08, 2011 | Woods Mechanical Inwall Timer 59017
Fan will not stay rotating,
The rotation lever was be disalligned just retightend.
Jun 19, 2011 | Tower Tropical Breeze Nexus Fan
Cooler makes noise,when it rotates.please help.
Stop beating up the tower before you damage the harddisk! If the case/PSU is out of warranty, take the PSU out and get the fan replaced. You can do it yourself, just observe the arrow direction on the fan (usually the round label should point out) and wire colors (the fan should blow out). Observe also all the precautions since the capacitors inside can hold a significant charge.
Nov 10, 2009 | Cooler Master Extreme 430 RS-430-PMSR...
Rotate
Throw it in the junk.
Nov 10, 2007 | Aloha Housewares Breeze 29" Tower Fan
Mini tower desk fan smells like it burned
no. you are correct in attempting to lubricate this motor, except that use 30W motor oil...WD40 is great to "loosen" the bearing, will only last a short time. The motor shaft should spin freely as this is not a permanent magnet type motor. This motor is widely used and quite common. I often "cure" broken machines by lubricating these motors. There is only a magnetic coupling (when powered) between the rotating shaft and coil. it should be safe to handle this motor even when powered up, providing there is no electrical damage to the coil. Think of this motor as a magnetic machine that requires AC power for the magnet.
Jul 25, 2007 | Rival (PATHT17ZU) Tower Fan
Bionaire BT45RC Tower Fan Logo
73 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
