Question about Dynaudio BM6A MKII Speaker
Happy owner of a pair of Dynaudio BM6a. BUT !!the tweeter in one of them stopped playing at same level as before after a protection Cut-off. It has sound, but level is reduced. Whattodo ? Pls
  • Steen Lidsmoes Aug 08, 2013
    A friend with som tecnical skills, sugets that it could be a limiter fuse or an resistor that i blown, since i have sound in the tweeter at all. Could anyone help me to locate the fuse/resistor on the board ?
3 Suggested Answers
  • 17 Answers
SOURCE: where is there a repair center that could validate
You need to contact them directly for a repair center in the US.
http://www.tcelectronic.com/servicepartners.asp
Posted on Mar 09, 2011
  • 5603 Answers
SOURCE: Hi, I own the Dynaudio BM6A acoustics monitors
If an internal circuit breaker pops, something has failed. Even surge protectors do little to protect stuff unless they are high level types with filtering. Key thing: ALL your interconnected equipment MUST be powered from the SAME receptacle or power conditioner. Using multiple outlets can allow building "ground bounce" to rupture sensitive input circuits. Use of balanced lines avoids noise in systems.
Posted on Apr 21, 2011
Testimonial: "thanke you very much!! I learnt a lot - but did you mean specificaly to the Dynaudio MB6A acoustics? or maybe your explanation was generaly?"
Why will my speaker stop playing and go into protection is there a reset bottom
The "Built-in overload-protection circuitry" is just doing its job...protecting the speaker from damage. Lets look at your system 1st. Is your power amp or powered mixer underpowered which requires you to turn the volume controls up past 1:00? Big systems play loud at moderate setting where-as small systems must be max'd out to reach those same levels. Pol-mount your speakers for better coverage as your ears are not attached to your shoes.
May 20, 2014 | Behringer B1520 Pro Eurolive 15" 2-Way...
Bm5a blows fuse when turned on
Blowing a fuse means that it has a dead short. The fuse does its job by protecting the other components while the circuit fails. Something is definitely burned out inside.
Mar 24, 2014 | Dynaudio BM5A Active Monitor
How To fix a broken Tweeter
Most of these in sound equipment have screws on the back allowing you to open and change the diaphram. Some do not.
Feb 16, 2013 | Dynaudio Music
My monitor is styill for working but the tweeter dont make any sound. i think its blowed up, is there a fuse a something that could be replaced in the amp?
no fuse in there unfortunately.
The problem could either be a blown tweeter (but that would likely cause distortion rather than silence) or a fault with the amp or crossover. Often it seems a relay is at fault in these instances with dynaudio monitors. In any case, unless you have considerable electronics knowledge (which I think it's fair to assume you don't ?) you won't be able to fix em yourself. Give dynaudio an email or call - they're helpful.
Dynaudio North America
1140 Tower Lane
Bensenville, Illinois 60106
USA
Phone (630) 238-4200
Fax (630) 238-0112
For Service: service@dynaudiousa.com
Apr 25, 2011 | Dynaudio BM5A MKII Monitor Studio Active
Hi, I own the Dynaudio BM6A acoustics monitors & I want to know if there is a circuit breaker system inside the monitors, for surge protection? The reason I ask is because I have no power conditioner...
Apr 21, 2011 | Dynaudio Acoustics BM6A MK II Active...
Hello, i mistakntly bent the esotar2 tweeter dome, i fixed it by applying finger pressure on the dome, it popped back as it was. will it affect its performance? thanks a lot. joe
if u got it back in place an it looks fine then id plug it in an see if it sounds the same if it does just slowly *** more power if it sounds fine u okay
Oct 03, 2009 | Dynaudio MD100 Car Tweeter
My Kenwood amplifier is having problems, whenever i turn it on. all seems well until i play some music through it, after 30seconds to a minute the music will cut off and a distinct click is sometimes...
Your amp is going into protection. The click you hear is a relay meant to protect your speakers and stereo. Check your speakers with an ohm meter for the the proper ohms ( listed on the speaker ) and physically try to push each woofer and midrange cone in gently to make sure it moves and is not stuck or frozen in place. A speaker may read correctly on an ohm meter if the woofer is ok but if the tweeter or midrange is not working it will cause the amp to go into protection mode. When you play music stick your ear up to each tweeter\midrange\woofer to ensure they are working.
Your stereo could also be the culprit although usually if it plays music it is ok as long as you are not hearing loud pops. Loud pops are voltage spikes that indicate that a transistor\IC is breaking down and will eventually short. Good luck!
barneyluc
Oct 01, 2008 | Audio Players & Recorders
KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Jan 11, 2008 | KLH HT-9930 System
Dynaudio BM6A MKII Speaker Logo
44 people viewed this question
Top Dynaudio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Dynaudio Audio Player and Recorder Expert? Answer questions, earn points and help others
