Question about Kenmore 63792 Microwave Oven
Kenmore Microwave/Vent Hood Model 40185059210. Vent hood motor has blown three times. Sears will not fix it anymore, b/c they say it is water causing it to blow (from roof). However, the three times it has blown there has been a power surge. It is plugged into a surge strip, but it hasn't helped. Anyone else having this issue?
MicrowaveSvc
  • 9086 Answers
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
SOURCE: Kenmore microhood model 721.80833500
mlsavoie,
When did you purchase this microhood? Do you have the extended warranty on it? I'm having the same problem. It's driving me crazy.
Linda
Posted on Feb 08, 2008
rylee_smith
  • 8619 Answers
SOURCE: Dead microwave!
Hi Kevin
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
If still you are unable to diagnose the issue then it is recommended to call a local repair center for this to get fixed as Microwave usually have high voltage even when it is turned off.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Apr 24, 2009
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Posted on Nov 09, 2009
SOURCE: Kenmore Microwave Hood Combination 721.80019 does
My kenmore microwave will not work. The light stays on inside, buttons will push, but the start button does nothing. I've tried everything. The last thing I did was express defrost which was fine. Could it be something really simple? I hope so.
Posted on May 16, 2010
My hood fan quit working on my kenmore microwave/ hood combo. How do I fix?
Check to see if fan is getting power. If it is and the fan does not turn then you need to replace that motor. Also check motor bearings - not uncommon for them to get all gunked up with yuck from the air they push through the hood.
Aug 23, 2017 | Kenmore Microwave Ovens
Sears l kenmore microwave 665.60622000
Most Kenmore appliance manuals are available from Manage My Life. For the 665.60622000 microwave and range hood User's Guide, see http://www.managemylife.com/mmh/owner_manuals/5728/KENMORE-Microwave-Hood-Combo-L0211211?brand_name_search=665.60622000 . This will load the PDF in the browser window if you have a PDF reader plugin. If you wish to download the manual, the direct link is http://www.managemylife.com/mmh/lis_pdf/OWNM/L0211211.pdf . You need Adobe Reader or a similar program to read the file. If you want only the Installation guide, start here: http://www.managemylife.com/mmh/owner_manuals/search?query=665.60622000 . Unfortunately, you will need to print your own copy from the PDF. (Alternatively, go to a print shop with the file on a flash drive and they will print the file for a fee.) Sears no longer has the manuals available for sale at Sears Parts Direct, http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/All-Products-Parts/Model-66560622000/0582/0123370/P0080166/00001?blt=06&prst=&shdMod= .
I hope this helps.
Jul 18, 2013 | Microwave Ovens
My Sharp carousal microwave model R 1482 goes on and off on its own. When cooking the steam from boiling water will set the micro off like I am pushing buttons on it.
If it's just the hood vent exhaust fan coming on, that's normal due to a temperature sensor (the hood vent exhaust TCO / thermostat).
If other functions on the microwave are coming on, then the keypad and / or controls may be shorting due to moisture and / or heat, and that needs to be addressed.
You should always run the microwave oven's hood vent exhaust fan whenever you're cooking on the stove top.
If you do, and the trouble persists, I would suspect the controls.
The service manual is at our site and we have uploaded it here to help you.
You can order any needed parts from the Sears Parts Direct Web siteimage-4235112-10659157 or Encompass here or you can call them toll-free at 866-779-5835.
Let us know if we can help you further.
Jan 09, 2011 | Sharp R-1482 Microwave Oven
Connect microvawe vent to exhaust pipe on ceiling
I would call Sears service (and ask for the manager) every day until they send the guy back with the right parts!
If that somehow doesn't work, you can order the parts at the Sears parts site.
You can find out which parts you need in the owner's / installation manual. If you don't have it,
you can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Dec 25, 2008 | Kenmore 63792 Microwave Oven
Kenmore elite microwave/vent hood model 721.80834500 turntable
I bought a Kenmore Elite Microwave Hood Combination Model 721.80823500 at Sears. The installer did not bring the parts to connect the vent to the pipe on the ceiling and never came back. I cannot find the vent/exhaust connetor part to have it installed. No one knows. I appreciate information or installer. Thanks.
isabelmvaldes@gmail.com
Nov 16, 2008 | Kenmore 63792 Microwave Oven
My Kenmore 64663 still heats but I don'y hear the fan anymore while heating
If it's the internal cooling fan, you really need to get that repaired before you cook anymore with it. Otherwise, your magnetron will be destroyed.
If it's the hood / exhaust fan, then the problem may be the motor or a problem on the control board.If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't feel confident to tackle it yourself, I would contact Sears for service.
Aug 22, 2008 | Kenmore 64663 Microwave Oven
Kenmore Elite Microwave hood
Please reply back with your brand and full model number so we can help you.
May 26, 2008 | Kenmore 64683 Microwave Oven
Kenmore microwave shuts off after several seconds
Hopefully the hood / vent fan was always on when boiling on the stove top.
Otherwise moisture can get into and damage the keypad or control circuit board.
That may be the problem.
If this is a convection model, it may have a bad thermistor (not to be confused with a thermostat).
The full model has three more digits, in case you need more help and want to post that.
If you or a friend decide to look into it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find an exploded view by entering your full model number here: http://www3.sears.com (the 3 is correct)
Dec 06, 2007 | Microwave Ovens
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Kenmore 63792 Microwave Oven Logo
235 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
