Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Can't get gas to start primer pump not working
  • Mtd Master
  • 1,807 Answers
Sounds like you have an air leak in the fueling system and air, not fuel is being sucked in to the primer, check the fuel line and primer pump gaskets or bubble (if it is the primer bubble type)
Posted on Aug 01, 2013
Can't get primer blub to pump gas
The primer bulb may have a pinhole or be worn out. Also check the primer line going from the bulb to the carb, could be pinched, blocked, or the attached ends may be too loose. Try pulling the hose ends off, it should not be too easy to remove them, if it is and its long enough cut off the old loose section and reinstall.
Nov 09, 2014 | Troy-Bilt Tb320bv 31cc 2-cycle Gas Powered...
The little pump for gas does not wok
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
Aug 29, 2014 | Ryobi Garden
Out of Diesel
This particular JD engine has an individual fuel pump for each cylinder. The injectors, fuel lines, and pumps are not accessible from outside of the engine. There is a hand primer pump built into the top of the fuel filter. Start by removing the rubber outlet line from the filter base and pump the primer pump until fuel come out of the filter base outlet. Ounce fuel comes out of filter reconnect the line and continue pumping by hand until the pump button feels solid, then crank engine until it starts. This works better if a helper is available to operate the starter while continuing to pump the hand primer. This is normally all that is needed after running out of fuel.
If fuel does not come out of fuel filter base there may foreign material inside of primer pump. Primer pump can be disassembled and cleaned. If fuel comes out of filter, primer pump become feels solid but engine does not start the fuel control rack inside of engine may be sticking in the off position. This may sometimes be overcome by clicking the key switch from off to on rapidly. If not you may have to have your dealer remove the governor cover to free the rack.
Mar 19, 2014 | John Deere 4020 Gas & Diesel Tractor...
I have a Husqvarna 455 about 2 years old. At about 1 year point it would no longer start using the primer pump button on the side when cold. If I take off the air cleaner and give it a a shot of gas down...
Your seeing the problem. Air in the fuel lines usually caused by a cracked fuel line or a pin hole in the primer bulb. Until you can stop the air bubbles by either replacing the actual primer bulb or fuel lines your always going to have the hard to start problem. This can also cause the engine to run lean at high RPM settings and eventually burn a hole in the piston. You should repair the fuel problem ASAP. If you do not find any fuel line / primer bulb problems then it is time to start looking at the carb diaphram.
Thanks for choosing FixYa,
Kelly
Oct 08, 2010 | Husqvarna Chain Saw 20" Bar
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
My home lite blower wont start not getting fuel how does the primer bulb work
Primer bulb pumps fuel from gas tank to carb. Once started gravity takes over.
Oct 09, 2009 | Homelite Garden
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a homelitejacobsen 320 snowblower i replaced the primer bulb with one that has a single line running to it after it starts gas starts squrting out of the hole on the primer bulb how do i stop this
You need a "wet" primer bulb for the Jacobsen / Homelite snowblowers. A wet primer actually pumps gas - not air - a primer bulb with a hole in it was designed to pump air.
If you need a "wet" primer bulb email me and I will tell you where to get one for around $10 - basscatt at hotmail dot com
Feb 20, 2009 | Homelite Mighty Lite Lawn Trimmer
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
155 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
