Question about Toshiba 62HM196 62" SD Television
Toshiba 62HM196 Fan stopped on light engine. Can fan be replaced? Can replacement fan be found?
  • 298 Answers
SOURCE: Humming noise
The light enigine shouldn't be that difficult to replace if you have a decent amount of time and are moderately mechanically inclined. You can order the original Toshiba replacement light engine for this model (62HM95) from a major Toshiba parts distributor at the link below:
Toshiba 62HM95 Replacement Part Light Engine / Optical Block
Posted on Apr 02, 2009
SOURCE: No picture, starts normally then shuts off. blue
T.V is going into protection mode, will have a short of some sort.
Posted on Sep 26, 2009
vinnyq
  • 157 Answers
SOURCE: toshiba 62hm196 just replaced lamp 2 weeks ago and
It could be the ballast. The ballast is what fires the lamp and an over or under voltage to the lamp could cause it to blow prematurely. A clogged fan could also be causing the issue if the lamp is not cooling correctly but you said the fan was fine.
It could had just been an defective lamp, send the lamp back to where you bought it and tell them it was defective. There also should be return instructions that came with the lamp and also warranty information.
Posted on Nov 11, 2009
Angel Petter
  • 114 Answers
SOURCE: need to replace light engine on a toshiba 56 DLP
try this link it's arrowed $270
http://www.discount-merchant.com/TOSHIBA-4D09-40A-Light-Engine-w-Color-Wheel-p/1130472.htm
is like this depending on your Tv Model
Posted on Feb 05, 2010
techman
  • 3130 Answers
SOURCE: will a light from a 62HM196 work on a 62hm15a
I looked up both models and both tv sets have different part numbers so probably not!
techman
Posted on May 04, 2010
Tv states the cable card fan is not working
Well the issue is that one of the TV's fans isn't working. It doesn't matter if you have a cable card in the slot or not, the fan still doesn't work and the TV's self diagnostics is picking that up.
The answer isn't to deal with the message. It's to get the fan fixed. That's also an easier fix than trying to somehow hot-wire the TV's self diagnostics so it's blind to errors. It'll be a little mini fan maybe an inch to inch and a half square that costs less than $10. Go the simple route.... just replace the fan.
Sep 11, 2014 | Toshiba SELECT 62HM196 Rear Projection...
Toshiba 42TL515U -fan has stopped working
I have spent some time searching the internet and you are not alone. However I haven't found where anyone has documented repairs. If I were you I would just remove the back and look for it. The fan may be the same as many computer fans. It probably has speed feedback. Check computer shops for replacement, Digikey.com or Newark.com
How to interpret output of 3 pin computer fan speed sensor
Good Luck, Tom
Aug 25, 2014 | Toshiba 42TL515U 42 in. 3D TV
Will a light from a 62HM196 work on a 62hm15a
techman
May 04, 2010 | Toshiba 62HM15 62" Television
Lamp light blinking
The problem is that your lamp has expired, You need to either get in touch with the brands authorised repair agent and they can order and replace lamp( at a cost) or you can replace the lamp yourself. Also make sure you know how to rest the lamp use hours after replacing the lamp. Good luck.
Nov 20, 2009 | Toshiba 62HM196 62" SD Television
Toshiba 62hm196 just replaced lamp 2 weeks ago and this one is blown to, fan is working fine is it just a bad lamp or could something else be causing failure? When i inserted the replacement it fit...
Nov 08, 2009 | Toshiba 62HM95 62" DLP HDTV
Humming noise
Apr 01, 2009 | Toshiba 62HM95 62" HDTV
Toshiba 62HM196 62" SD Television Logo
93 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
