Question about Frigidaire Refrigerators
Model fghs2655ke0- clicks at switchboard. everything works just powers on and off. eventualy a sy ce error code. got the new replacement switchboard (main board) and install with new harnesses. will not power up at all. Thought a bad board. warranty out. same again. warranty just to be sure. same again. I tested all the connections tightened them. once again the old board and everything works on user interface, just relay issue. New board not a thing. Thanks!!
  • Official Brand Answer
  • 4,342 Answers
Hello Steve, thank you for your inquiry! SY CE is commonly referred to an error code between the main control board and the user interface (the control on the Freezer door). A tech would typically check the communication wiring wires between both parts to determine the cause of the error code. If the wiring is correct, then more than likely you are looking at a faulty main control board or user interface since the MCB has already been replaced. I would please recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Posted on Aug 03, 2013
  • 42 Answers
SOURCE: Freezer won't defrost
savey73,
I think I know what is wrong. First the defrost thermostat you are talking about I believe is the round metal type with possibly a pink and an orange wire coming out of it. That is not the defrost thermostat as most people know it. That is a defrost overheat termination thermostat that opens only over 140 degrees F, that is why your old good one and your new good one show closed at room temp. If you read on the outside of the metal cover you will find it has a L140 indicating the limit of 140 deg.
Now to what should be causing your problem. You should find on the evaporator coil at the top left side of the evaporator coil a part that has 2 white wires going into what looks like about a 1" long X 1/4" round plastic thing. That little white plastic thing is a THERMISTOR. If it is bad your defrost will not work. Sounds like that is the only thing you have not replaced. There is no polarization of the wires That should FixYa
supertechks
Posted on Nov 24, 2007
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
  • 159 Answers
SOURCE: Overload relay bad ordered new one part# 67005560 pulled old relay out and it has different connection did I order wrong relay?
normally it a replacement part but overload is a clickson
Posted on May 22, 2009
SOURCE: My GE side-by-side howls. Model GSL25IGRBBS.
First of all - make sure you route the green grounding wire connector from the board to one of the screws, holding the board cover. If you leave it hanging - you can kill the board if the wire touches some of the board elements.
Second - check what kind of sensors you have in your fridge. There are three of them: one in the fresh food section, and 2 in the freezer.
If any of the sensors has black compound where the wires enter the white plastic cylinder, you'll need to replace it with the newer one: WR55X10025
Locations: One behind the damper cover in fresh food section (far left top corner)
One in the far left bottom corner (small cover with 2 white wires to it)
One (which most likely makes the problem) is on top of the evaporator (coil in freezer section, behind the lower back cover). Ifyou replace any of them - make sure to insulate the splice points with food-grade silicone.
Posted on Oct 16, 2009
Testimonial: "You truly are my guru. I don't know how you knew exactly what to look for, but the thermosters were just as you described. Thank you, it works!"
GodBlessU
  • 3513 Answers
SOURCE: Frigidaire Gallery side by side
Hi
If you have unplugged the unit for at least 5 minutes and the error code keeps coming back then this will be a warranty concern. Any attempt by you to correct the problem aside from resetting the unit (unplugging it for 5 minutes resets the main control board) will void your warranty.you have to call the dealer or frigidiare service center.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 17, 2011
Error code SY CE displayed plus lights in refrigerator and freezer not working
I appreciate your post, Carol!
Based off the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and the lights are not working. A "SY CE" error code stands for a communication error at start up. This might be a miscommunication within your refrigerator and I would recommend performing a reset in order to correct the issue. To reset your refrigerator you need to disconnect power from it for roughly ten minutes. If this does not help correct your issue you may need to change your control panel or a wiring harness. In order to properly diagnosis your refrigerator you may need to disassemble it and I would suggest having a professional technician out to do so. This will help you avoid any unnecessary part purchases or personal injury. -Matt
Jun 08, 2015 | Frigidaire Refrigerators
I have a frigidaire refrigerator with electronic screen about a wk ago started beeping giving me a code of sy ce what does this mean?
Thank you for your inquiry, Carlos!
From the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and you would like to know the meaning. The error code "SY CE" stands for communication error at power up. This could be an issue with your wiring harness, main control board, or user interface board. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
May 26, 2015 | Frigidaire Refrigerators
Code on door of French door reads error message 5y ce. sounds like it is still running but no light inside or ice maker not working.
Thank you for your post, Carol!
I understand that your Frigidaire refrigerator is displaying an error code of "5Y CE". However it appears that "5Y CE" is an invalid error code. I have noticed the code of "SY CE" and that means there is a communication error at power up. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord for at least ten minutes. If that does not correct your issue it could be possible that there is an issue with your main control board, wiring harness, or user interface board. I would then suggest having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
May 19, 2015 | Frigidaire Refrigerators
What does EI28BS36IS3 blinking lights mean
Are all of the lights flashing or is it flashing a code like Sy EF or Sy CE? If so the ef would indicate the evaporator fan circuit has a problem, and if it is SY CE it would indicate a communication error.
Feb 19, 2015 | Electrolux Refrigerators
SY CE error on Electrolux Refrigerator Display. I unplug the unit and it works for about several hours then the power outage alarm will go on and off several times and then unit will error out the SY CE...
I have a very similar issue with my GE in wall oven, circa 1999. I learned it was due to one of two issues.
1. The touch panel keypad is shorting out somewhere along the ribbon wire circuit. Replacement likely needed.
2. The microcontroller brain of the oven is faulty. Replacement likely needed.
My issue was the keypad. I personally went to RadioShack and prototyped a new circuit board to reverse engineer the keypad. The flimsy keypad replacement was $244.00 for a new one, however they no longer make the keypad. For less than $20 and a little solder I have a fully functioning replacement.
Oct 29, 2014 | Refrigerators
Error message 5y ce
Good Afternoon Cheryl, I am happy to assist you. Could the error code possibly be SY CE? If so, error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the refrigerator. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Jul 30, 2013 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Codes sy ce refrigerator display
Good Afternoon Johnny, thank you for your inquiry! Error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the unit. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Jul 27, 2013 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Sy ce on fridge door
Hello Debbie Lee - Typically error code SY CE indicates that the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need placing.
Feb 02, 2013 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Lcd reqds 5y ce
Hi John Dirksen- Could the error code possibly be SY CE? If so, it typically means that the unit has detected a communication error at power up. A professional will need to check the wiring between the main control board and user interface. Depending on the diagnoses from the professional either part may need replacing.
Jan 13, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Code 5y ce
Hello Marc Donmoyer - Could the error code be SY CE? If so, then the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need replacing.
Dec 18, 2012 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Refrigerators Logo
67 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
