Question about Landice Pro Sport Trainer Treadmill
Program button on my landice L8 stopped working, also, if treadmill is left alone, it will turn on and start cycling through the programs on it's own. help!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Seem like you need the overlay. See if Landice will cover it.
Posted on Aug 13, 2013
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: landice L8 treadmill won't turn on
Check wall outlet for power , then if outlet is good unplug unit remove motor shroud you will see a charcoal or white ceramic fuse check it if open replace blows again immediately you have a shorted lower board. Here is the info Landice they help you with parts and get you in touch with a servicer if you need one.
Landice, Inc.
111 Canfield Avenue
Randolph, New Jersey USA 07869
(800) LANDICE
(973) 927-9010 - FAX: (973) 927-0630
service@landice.com
Posted on Apr 25, 2010
outfield502
  • 79 Answers
SOURCE: landice L8 has an L5 error displayed wont start up
is a speed sensor problem or the card connectors are wired specifically where the motor wires, sometimes that part is too hot and breaks the solder
Posted on Sep 14, 2010
SOURCE: landice L8 automatically turns on by itself
It is either the control board or the overlay. I would think it is probably the start button on the overlay that is stuck. The solution is to replace the overlay.
Posted on Mar 05, 2011
ercupa190
  • 12223 Answers
SOURCE: landice L7 treadmill won't turn on
1)LUBE the deck belt, maybe you have a deck belt worn, by lack maintenance.
2) Lube the rollers bearings, in according with the maintenance schedule.
3) Test the main motor for voltage input, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
5) After fixing RUN the software calibration for diagnose, and troubleshooting.
Posted on May 09, 2012
Landice executive L8 treadmill makes clunking noise when I run on it
You need to get someone out to look at it. Noise issues are rarely able to be diagnosed remotely.
Mar 21, 2013 | Landice L8 80 LTD Executive Trainer...
Landice L8 automatically turns on by itself
Mar 05, 2011 | Landice L8 LTD Cardio Trainer Treadmill
Landice L8 has an L5 error displayed wont start up
Jul 19, 2010 | Landice L8 LTD Cardio Trainer Treadmill
Landice L8 treadmill won't turn on
Landice, Inc.
111 Canfield Avenue
(800) LANDICE
service@landice.com
Apr 24, 2010 | Landice L8 LTD Cardio Trainer Treadmill
Landice 8 over speed protection
first screen shows any error number? for what you describe I think it is simply speed sensor, try to check the cables leading to the sensor card. and then checks whether the sensor is aligned correctly.
Check speed sensor alignment.
It should be within 1/16" of the flywheel
and parallel to the flywheel.
Is it out of position?
Feb 02, 2010 | Landice L8 LTD Cardio Trainer Treadmill
Blower on my citreon zsara hd estate only works on full blow
hi i get this prob a lot on peugoet 406
its the ignition worn, try wiggle the key when running and it should work if not get back to me.
Aug 18, 2009 | Landice L8 LTD Cardio Trainer Treadmill
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
Pulley slipping on front roller
Since the drive pulley is slipping on the roller itself, then the front roller will need to be replaced.
May 12, 2009 | Landice L8 LTD Cardio Trainer Treadmill
Landice L8 Cardio trainer giving messages on readout P4 and L5
I've definitely never seen "P4" on a Landice before so I'm not entirely sure on that one. The other issues seem like they might be associated with stuck keys on the console. It's a very common problem if you have it in a humid area and/or it gets sweat on it during the work out. Being that it's a Landice, you should have a part warranty on it. Have you contacted them?
Jun 15, 2017 | Landice L 7 Club Cardio Trainer Treadmill
Landice  Pro Sport Trainer Treadmill Logo
149 people viewed this question
Top Landice Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Brian Woods
Level 1 Expert
Treadmill Repair...
Treadmill Repair...
Level 1 Expert
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
