Question about Konica Minolta Start Up Kit for DI650 DI670
Code d'erreur sc29-03 minolta di650 - Konica Minolta Start Up Kit for DI650 DI670
  • Konica Minolta Master
  • 6,161 Answers
Sir/Mam,
When was the last time your machine had a 250,000 Preventive Maintenance kit installed. Very 250K copies/print the Developer and certain parts need replacement, the drum at 500K. The code your machine has is telling you that either the drum is bad a sensor/sensor board is bad, or the drum is old and needs replacement. Also possible the sensor needs to be cleaned. Have to remove the drum cart then the drum to get to it. Recommend a tech do it.
Posted on Jan 02, 2015
Code erreur 46 40
Sir/Mam your copiers Hard Drive needs to be initialized.
Sep 08, 2014 | Konica Minolta Minolta Dialta Di5510 Laser...
Code erreure sc53_01
might check the fuser(hot part) motor. Recommend get a tech to look at this problem
Jun 19, 2014 | Konica Minolta Genuine Di650 Di551 Di5510...
Error code 42-2
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Di650 error code 42-2
FM-2 Fan code, Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site
Minolta di650 error code sc50-01
If powering off then on the machine does not clear this code it is a fault with the serial drive signal from Printer control Board! Quite Expensive! Or main dive section of the machine. Recommend a Certified Tech look at it, sir/mam
Mar 14, 2014 | Konica Minolta Start Up Kit for DI650...
Minolta di650 error code sc90-01
Sir, Mam
The middle section of the that you pull out to get paper jams will the circuit board the controls that section or a major board is bad you mite want to check for any paper that left a part of stuck inside that area of the machine look in the back (When you pull it out) IF not you Need a Technician!!! Not a normal code!!!!!!!
Feb 03, 2011 | Konica Minolta Start Up Kit for DI650...
Minolta di 181 error code M4
QUEL EST LA SOLUTION POUR DESACTIVER L'ERREUR CODE M4 ?
Jan 21, 2010 | Minolta DiALTA Di181 Printer
Minolta dialta trouble code c0650
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
Oct 23, 2008 | Office Equipment & Supplies
Konica Minolta Start Up Kit for DI650 DI670 Logo
74 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
