Question about Sanyo Microwave Ovens
Sanyo EM-S2297V microwave - will not heat - symbol like a red rainbow with a dot in the centre showing when you select the power level
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: power on but no heat
see the next step:God bless you
Microwave Runs, but no Heat OK, get ready, this micrwave oven repair can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
Posted on Jul 27, 2012
ercupa190
  • 12223 Answers
SOURCE: my sanyo microwave model no em-s2297v is not heating the food the plate goes round the light comes on just not heating the food
follow the steps and fix it. God bless youwhere you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.
mwswitchtest2.jpgIf the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.
Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode.Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
Posted on Apr 02, 2013
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
How do I use power feature?
Sanyo EM-S5002W Instruction Manual & Cooking Manual
www.manualslib.com > ... > Instruction manual & cooking manual
Sanyo EM-S5002W Manual Online: Control Panel And Features. OPERATION (1) ...Sanyo instruction manual microwave oven em-s5002w. Hide thumbs ... cooking. (4)POWER LEVEL. Use to set power levels other than. 100%. (5) KITCHEN ...
Oct 09, 2015 | Sanyo Microwave Ovens
Power on but no heat
Jul 26, 2012 | Sanyo Microwave Ovens
How to preheat my new microwave model EM-C5796V of sanyo
you really don't pre-heat a microwave. set it for the time you want to cook and it reaches the temperature for cooking almost instantly
Sep 27, 2010 | Sanyo EM-Z2100GS Microwave Oven
Microwave not heating food
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Cheers,
Ben
Nov 15, 2008 | Sanyo Microwave Ovens
Sanyo microwave mod # EM-2100GS
unscrew the unit replace fuse near the transformer. this fuse is for heating....
Feb 02, 2008 | Sanyo EM-Z2100GS Microwave Oven
Sanyo EM-P740w
It looks like you would enter the cooking time then press POWER 1 to 10 times. Once = 100%, twice = 90%, thrice = 80%, and so on, and "PL#" will appear in the display where "#" is the selected power level. On some models, twice = 80% and thrice = 60%, etc. and "80%", or "60%", etc., will appear in the display. Then press START. Did that do it?
Dec 07, 2006 | Sanyo EM-P740W Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
tony denham
Level 1 Expert
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
