Question about Illy Francis Francis X7.1 iperEspresso Machine Black
Illy X7 only brews a very small quantity of coffee. I need to press the "brew" button several times. Any fixes for this?
What does brewing time off mean
You can try the reset for the B60. I do bot understand your original What does brewing time off mean??...
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Jul 02, 2014 | Keurig B60 Coffee Maker
All I need is the manual to my Mr.Coffee Pot how to set the timer to Mr. Coffee GBX23.
First set the clock on the brewer with the unit plugged in. Press and hold the Hour and Minute buttons until the current time is set. Next press the Delay Brew button while using the Hour and Minute buttons to reach the time you want the coffee to begin brewing.
Set up the coffee maker with ground coffee or beans and sufficient water in the reservoir then follow the directions below.
For brewing with fresh ground beans, press and hold the Delay Brew button until it flashes then press Select once. The Grind and Brew light should come on and the Delay Brew light should become steady.
For ground coffee, press and hold the Delay Brew button and then press Select twice. The Brew Only light and the Delay Brew light should both be on and steady.
Most Mr. Coffee product manuals are here: http://www.mrcoffee.com/InstructionManuals.aspx . The direct link to the GBX23 manual is http://www.mrcoffee.com/Manuals/MANUALS/GBX23_43_50118420.PDF .
I hope this helps.
Aug 20, 2011 | Mr. Coffee GBX23
When we press the brew button, a lot of the time it will not brew. sometime it starts but then does not finish. Also there is a note that says "brew temp set". I bought my keurig from QVC To...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jun 25, 2011 | Keurig Platinum B70 Coffee Maker
My Incanto Sirius coffee maker is acting strange. It automatically keeps brewing (1) large coffee. The only way to stop this is to shut off the machine. I am getting a LCD read out of Program quantity....
Program quantity is trying to program that amount.
When it starts to brew and gets to the quantity you want for that cup size push the brew button again and see if it stops.
Nov 21, 2009 | Saeco Incanto Sirius Fully Automatic...
The machine says REady To Brew- the lights flash and i press the button to brew. It says "brewing" but nothing ever comes out and then it goes back to "Ready to Brew".
Mine does this all the time. When it does, I tap the top of the machine and the coffee comes out. I don't know if it will work for you, but it works every time for me. It's like there's a small clog or something.
Nov 01, 2009 | Keurig Special Edition B60 Coffee Maker
Cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Aug 30, 2009 | Saeco Royal Digital Plus Coffee...
How do I pre brew
I got one of these for xmas, and I was able to program the pre-brew option.
First, turn off the machine.
On the front of the machine, there is series of 5 buttons. (From left to right, they are: Small Coffee, Large Coffee, Pre-ground Coffee, Hot water and Descaling.)
While holding down the 1st (Small coffee) and 4th (Hot water) buttons, turn on the power.
Wait 3-5 seconds before releasing these two buttons. You machine is now ready for programming.
Below the 5 buttons are 4 small lights. If the second light from the left is red, the machine is already programmed to pre-brew. If the light is not red, do the following:
Press the Coffee button (2nd button from the left) once and the second light from the left should glow red. This turns on pre-brewing. (Pressing the Coffee button again will turn off both the light and the pre-brew option.)
Now turn off the power for at least 5 seconds. The next time you turn the machine on, it should pre-brew the coffee.
The process worked great for me the first time, but when I wanted to program the machine to not pre-brew, I had to go through this process a couple of times. Not sure why, though. :-)
Kathy
Jan 13, 2009 | Saeco Incanto Classic Espresso Machine
Miele brew unit jammed and brewunit block is being displayed
There is a third solution. The brewunit drive motor has three contact switches that indicate home, preset (loading grounds, I assume) and make espresso. The problem is the three contact switches are all on one circuit, so the microprocessor knows a limit switch has been reached, but it doesn't know which one. The programming obviously assumes the limit switches are reached in the correct sequence. In my case, the microprocessor thought the brew unit was in home position when it was in the make espresso position. Miele technical support recognized this immediately, so it is a common problem. The solution is to remove the top panel of the unit, unplug the unit, unplug JP34 on the microprocessor board (four wires, red/yellow/brown/black, in the middle back edge of the microprocessor board). Plug in the unit, put it in maintenance mode, and press and hold the medium coffee button for several seconds. This will move the drive motor past the current limit switch. Plug JP34 back in, plug in the machine, and put it in maintenance mode. Press and hold the large coffee button for a second or two, maximum. Open the machine, and look at the brew unit drive male gear in the main machine as compared to the brew unit female gear. It will take several tries to get the male/female gears to match so you can plug in the brew unit. Once this is done, and the brew unit snaps in place correctly, place the machine in maintenance mode one more time and press and hold the Medium Coffee button to reset the microprocessor with the limit switches. You should be back in business!
Nov 25, 2007 | Miele CVA615 Espresso Machine
Illy Francis Francis X7.1 iperEspresso Machine Black Logo
Top Illy Coffee Makers & Espresso Machines Experts
ray gallant
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Illy Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
