Question about Kenmore 62602 Electric Dryer
I would like to know how to maintain a gas dryer that has been sitting unused for over 3 years, I want to make sure it will be safe to use. Anything I should do before I connect it and start it up?
  • BEric Aug 01, 2013
    sorry I posted this in the wrong place will put in the correct category
    New Friend:
  • 24 Answers
Providing that the machine was not stored in a wet location or out in the elements you should have no problem. If it were me I would first thoroughly clean the machine, then plug the machine in without the gas line hooked up,start the machine. Let the machine run for a few minutes and listen for the igniter to cycle and for any unusual noises. If everything sounds ok proceed with gas hookup.
Posted on Aug 01, 2013
It's been standing for around 2 years unused. Fitted new battery,indicators horn,brake lights all work. No ignition ligh,turns over, but won't start. Was working fully before 2 years unused
After sitting so long did you drain out the old gas as well you could have a dirty and plugged carburetor. Just to try an experiment take the spark plugs out and squirt a little gas into the plug hole and put the plugs back in and hook up the wires and see if it tries to start. If it does then you know the carburetor or dirty gas lines needs cleaning. if you do this several times there is a chance it may keep on running..If there is a gas filter it may need changing.
Jul 03, 2015 | Motorcycles
I have a 2000 mercedes benz e320 and its been sitting in my garage for about 10 years now and im planning on registering it and driving it as my everyday commute vehicle..i put gas in it the other day and...
Replace all fluids, replace belts and hoses. Check brakes for proper operation, get tires checked and replaced as needed. Replace wiper blades. Sitting unused is the worst thing for any vehicle. Check all lights for proper operation as well.
Jan 19, 2013 | 2000 Mercedes-Benz E-Class
My kenmore 80 series gas dryer heats sometimes, but other times wont heat. I can see the flame when it does heat. I replaced the thermostat. It seems to heat when it has been sitting unused for a long...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 25, 2011 | Kenmore Dryers
My gas dryer is 3 years old and it starts to heat up when it is turned on and then stops heating while running.
This is usually due to the two gas valve solenoid coils sitting on top of the gas valves, one with 3 prongs and the other has 2. The coils work fine when cool but one or both are weak and fail when get heated. Both coils must work to open the two gas valves in order for the dryer to fire up. The coils are not repairable and the only viable solution is replacing both of them. Replace the solenoid coils and it should solve the problem.
Feb 28, 2011 | Amana DLG330RAW Gas Dryer
Clothes will not dry - not hot enough - installed professionally about 3 months ago - is it safe to move it to see how the venting was done behind the unit? I'm afraid of disconnecting something and not...
look behind dryer, making sure you can easy it out without pulling on the gas line or anything. You can or should be able to disconnect the vent without pulling the machine out at all or if you do just a little. Here is a website that covers venting, Good Luck Tim:
http://www.applianceaid.com/general.html#timers
Nov 28, 2010 | Samsung DV218AG Gas Dryer
2004 nissan sentra sitting unused for 3 years
between 400.00 and 800.00 dollars. it cheaper to allow someone to drive it no car is made to set up.
May 17, 2010 | 2004 Nissan Sentra
Suzuki died on the Interstate at 65!
yes! purchase a can of Seafoam from Autozone $10 pour 1/3 can into two gallons of gas and get on an open highway... be safe though. Also drain all old gas out of the tank use an 89 octane, also replace 'fuel filter' it might be clogged and pre fill the filter with some Seafoam, and then if it wont start just try a push start and once you get it started keep it going, it might run rough the first couple of miles.if theres anything clogged up in the jets it'll probably clear it out.
Apr 07, 2010 | 2001 Suzuki VS 800 Intruder
Chainsaw will not start.
Not sure if it's safe but when I was cutting timber and we weren't sure if the chainsaw was flooded, we lit a match and put it on the ground underneath the exhaust pipe then tried to pull start it. If you got a little puff of flames then it was flooded. If not, you had no gas. And don't leave your gas can sitting around close while you're attempting these brave feat. Don't let your kids watch and don't do it unless you're alone or with someone you don't like much. Get them to hold the match.
Apr 11, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
5 hp Briggs and stratton wont run on a MTD tiller.
I had the same problem a few years back. Check the rubber elbow coming from the gas tank to the carb, it's probably cracked and sucking air instead of fuel from the tank.
Nov 30, 2008 | Garden
Kenmore 62602 Electric Dryer Logo
73 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
