Question about Samsung SP-R4232 42 in. Plasma HDTV
Black patch distortion - Samsung SP-R4232 42 in. Plasma HDTV
Color distortion-Sony Bravia Model KLV32EX500
check for a loose connection in the t-con board tried with re seat the cable wire in the t-con board.
Oct 04, 2012 | Televison & Video
I was wondering if anyone could tell me how to fix holes in my exhaust on a Buick 99 century custom
An exhaust shop may be able to patch it up, but I recommend putting on a new exhaust. It will help out your vehical in the long run and improve the performance. Hope this helps! Please rate 4 thumbs up!
Apr 19, 2011 | 1999 Buick Century
I have a Samsung DLP HLN 5065W and recently the TV started to get Horizontal Lines in it with a 2 inch black horizontal line across the TV and the bottom half you could see the picture and the top half...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 27, 2011 | Samsung HL-R6168W 61" HDTV
HD DVD Audio playback is distorted after microsoft
try uninstalling the audio drivers completely, restart and re-install them
Mar 11, 2010 | HP Pavilion dv9000z Notebook
Distorted sreen when full size images and games.
if video for everything else looks ok, it might just be a driver issue... hopefully, you have Nvidia graphics as they are the easiest to find drivers for, you can go to their web site and basically have them scan your machine for the correct one.
for non Nvidia, i would just make sure you're current with your windows updates, usually they will patch your system with relevant drivers.
Jan 15, 2009 | HP Computers & Internet
Pink scrable in background
your cable provider is using high compression causing the distortion.
Dec 07, 2008 | iLO 3200 32 in. LCD Television
Kodak V803
there is no way except to replace with new screen.Sorry.
Nov 02, 2008 | Kodak EasyShare C513 Digital Camera
Copies and prints in color are black procesed, but in black are ok
Using CMY Color produces a Processed Black.
Using only K will produce a Black.
In the print driver on a PC change your default setting to Black, from the machine you can set it to use only black as well.
That Patch is on the transfer belt. which it will alwyas do, that is what color machines do.
Install the print driver twice and set one driver s Color Mode to color and one to greyscale. This setting can be accessed by right clicking on the print driver and selecting Printing Preferences, click on the Color tab and set the Color Mode appropriately.
Oct 23, 2008 | Sharp AR-BC260 Color Copier
TV shadows
Check the proximity of magnetic fields. Large Speakers near the TV for example will cause colour distortion.
Dec 24, 2007 | Televison & Video
Colour distortion at the sides of the picture
check to see if you do not have speakers on the side of your tv or any where around it.which could be causing your problem.
Jun 09, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Samsung SP-R4232 42 in. Plasma HDTV Logo
Henry  Thomas
Henry Thomas
