Question about DFI Computers & Internet
I have an old motherboard (G4V100-P) and upon bootup I hear a series of beeps; beep-boop-beep-boop-beep-boop, continuously. I first thought it was the RAM but I replaced both sticks. Anyone have any suggestions?
    Brigadier General:
  • DFI Master
  • 3,400 Answers
Http://www.pcmag.com/encyclopedia/term/38515/beep-codes
HERE ARE SAME READING TO HELP YOU TROUBLESHOOT THE PROBLEM.
Posted on Aug 02, 2013
Testimonial: "Those are for AMI BIOS, I have a PC with Phoenix BIOS... do you have a link to all of those beep codes?"
joey64
  • 209 Answers
SOURCE: video card not connected to power cable
remove your video card uninstall if you ugraded this and temporarily use the on board then switch on. this way you can determine if your motherboard is also having a problem if you hear a beep beep sound your ram memory shold be taken out clean it then transfer to other slot.
Posted on Dec 06, 2007
spare_head_2
  • 47 Answers
SOURCE: Continous Beeping sound
Hi neosw,
Could you provide a little more detail?
Was this a previously working set-up or is this a new build?
If this was a previously working set-up have you changed anything?
When you switch on the PC
  • do you see anything on the screen, does the monitor remain in standby?
  • are any of the fans running?
  • does the hard drive spin up?
  • does the beeping sound stop after a short while?
The reason I ask these questions is because a continues beeping usually means that the BIOS is not seeing the processor, or that the power to the processor is not correct. With some BIOS manufactures it can also mean the processor clock speed is not set
correctly.
Please don't take this the wrong way but...if you provide greater detail in your question, the easier it for us to diagnose your problem, otherwise we can only make educated guesses.
I hope this has been of some help.
Regards,
Spare head 2
Posted on Jan 06, 2008
Reddin
SOURCE: ga-k8ns pro motherboard/ pc self build
Hey me too. Just bought a sata drive. I have the same mobo (AK86-L), and now the same problem. Updated the bios and SATA is enabled. Updated the driver. Tried both sata 1 and sata 2 connections on the mobo. It will not recognize the drive although it picks up that something is connected to the mobo. Its a WD Caviar 500 GB drive. Anyone have any thoughts?
Posted on Mar 31, 2008
map9966
  • 2351 Answers
SOURCE: New RAM, computer stays on intel screen and occasionally continually beeps
Hi DeezKelb, The continous beeps you are hearing is the Award bios telling you the memory is not seated correctly. Please remove the memory & re-seat the two DIMMS.
See Award bios beep codes, click on this link.
http://www.bioscentral.com/beepcodes/awardbeep.htm
If the beeping continues. Either boot into the bios & reset from there or reset the bios by moving cmos/bios jumper page 1-16 in you're user manual to clear/reset the bios. (Remember to set the jumper back to default). Boot the PC & enter bios to setup you're prefered settings.
If you're board still continues to beep download a free program called Memest86 & run the software which will test you're memory. http://www.memtest.org/ Scroll down the page till you are under the three Screenshots. Listed there is ** Memtest86+ V2.01 (21/02/2008) ** typed in red.
You have a choice of downloading software to creat either a bootable floppy disk or a bootable CD disk.
Bootable floppy; Download - Pre-Compiled package for Floppy (DOS - Win)
Bootable CD; Download - Pre-Compiled Bootable ISO (.zip)
You're Asus board can only run up to 2GB Max memory.
Main download web site for ASUS P4V8X-X.
http://support.asus.com/download/download.aspx?modelname=P4V8X-X&SLanguage=en-us
Good Luck!
Have more questions, feel free to ask.
Mike
Posted on May 04, 2008
colliewob
  • 778 Answers
SOURCE: Continuous short beeping after RAM upgrade
Try the old ram back in if it works you have the wrong ram
ram comes in many shapes and flavours
ddr ddr2 etc
Posted on Aug 16, 2008
Dell xps 9100 constant beeps upon startup
Beep Codes
Your computer might emit a series of beeps
during start-up if the monitor cannot display
errors or problems. The following repetitive
beep codes help you troubleshoot problems
with your computer.
NOTE: To replace parts, see the Service
Manual on the Dell Support website at
support.dell.com.
One beep - BIOS ROM checksum failure;
possible motherboard failure
Contact Dell (see "Contacting Dell" on page 53).
Two beeps - No RAM detected
Remove the memory modules, reinstall
one module and restart the computer. If
the computer starts normally, reinstall anadditional module. Continue until you have
identified a faulty module or reinstalled all
modules without an error.
If available, install memory modules of the
same type in your computer.
Three beeps - Possible motherboard failure
Contact Dell (see "Contacting Dell' on page 53).
Four beeps - RAM read/write failure
Ensure that no special memory module/
memory connector placement requirements
exist (see the Service Manual on the Dell
Support website at support.dell.com).
Verify that the memory modules that you are
installing are compatible with your computer.
Five beeps - Real Time Clock failure
Replace the battery.
Six beeps - Video BIOS test failure
May 22, 2014 | Dell Studio Xps 9100 Desktop Computer
Motherboard Error Code 62
first replace your ram,if problem occur,then check your c.p.u
Jan 26, 2014 | Biostar Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
NO SOUND HEAR
Hi, Do this beeping code for motherboard troubleshooting. First disconnect all memory,external video card, etc only motherboard and power supply. Then power on if you hear continuous beeping means the motherboard working good. Please do this beeping code troubleshooting.
No beeping means Short, No power, Bad CPU/MB, Loose Peripherals. One beeping means Everything is normal and Computer posted fine. Two beeping means POST/CMOS Error. One Long Beep, One Short Beep means Motherboard Problem.
One Long Beep, Two Short Beeps means Video Problem.
One Long Beep, Three Short Beeps means Video problem.
Repeated Long Beeps means memory error.
Continuous Hi-Lo Beeps means CPU Overheating.
Jul 14, 2011 | Computers & Internet
I have just installed a 478 socket MSI MS-6526 ver 3 motherboard to my computer and all it dose is bleeps when i turn it on any help would be apricated
check for the error beep if you hear continues beep it means issue with the memory. check the RAM if it is properly inserted to the slots and if it is compatible to the motherboard. if you hear 2 or 3 beeps it means issue with the video. your video card maybe not compatible or not properly inserted to the slot. your motherboard has a built in VGA/Video card try using that first. try connecting the main components memory/RAM, power supply, KB and mouse, VGA card(optional you have a built-in) then check if there is a display or if it booted. then one by one add your other components you want to add. just to trace the problem.
May 19, 2011 | Intel Motherboard
HP notepad - continueous beeping sound with equal sign characters
If you are getting a lot of = character along with the beeping, this indicates you have a stuck = key and the beeping sound is the keyboard buffer is swamped with the = character. If you can't unstick this key, then you need to replace the keyboard.
Jun 08, 2009 | HP Pavilion dv6000t Notebook
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
May 06, 2008 | Dell POWEREDGE 2400 Server
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Problem with my newly built pc
Hello!
The information for that specific motherboard lists beep codes for 3 beeps or 4 beeps. 3 beeps signals a memory error, 4 beeps signals a thermal warning.
The PDF is here.
Additional information on beep codes can be found at this site.
Hope this helps! If not, let me know and I will try to find more information.
Jan 19, 2008 | Computers & Internet
Video card not connected to power cable
Dec 06, 2007 | MSI KT4V (MS-6712) Motherboard
Computers & Internet Logo
74 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Matthew Spark
Matthew Spark
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
