Question about GE WBVH6240F Front Load Washer
I have a GE front load washer wbvh5200jww. Just the tub shakes and is tearing up the front door seal when it spins out. Otherwise it works fine. Ripping the seal apart.
  • Toni Pugh Aug 01, 2013
    Its not leaking, I just think the tub is not being stablized by whatever it is that stablizes it during spin
    It looks like the tub is hanging lower on the bottom left corner when I look at it thru the front door
2 Suggested Answers
SOURCE: My front load ge washer model GCVH6260F is leaking
the bellow or gasket may need to be replaced. this is a common problem with front loaders as the bellow can be pierced by anything that may be in or even on your clothes. I would visually inspect every inch of the front bellow to see if there is a TEAR or PIN HOLE.
New bellows $150 plus fitting so I use a Bike repair it and used the glue to glue a piece of bicycle tube to the inside of the seal to cover the chip by 1 cm either side and trimmed to the same height as the seal lip.
I then placed a little bathroom sanitized silicon sealant over the repair within the chip, wet down with soapy water on the door glass in the chip area and shut the door. Carefully wipe of any excess with wet finger and repeat. Open the door and let it all cure.
Posted on Aug 29, 2010
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
Kenmore 3.5 cu ft front load quiet tumble action washer. Will not stop cycling, leaks, and shakes violently when spinning.
The shaking could be due to a defective drum support bearing. The shaking also could have caused the door seal to fail, resulting in the leak.
Jan 22, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
HI my ge adora washer is leaking and it looks like the rubber rim has 2 small u shaped tears about 3/8" in it what can I do,
You could try sealing the tears with silicon sealer, it might work, otherwise you will need to have a new rubber seal fitted.
Dec 16, 2010 | GE WSXH208A Front Load Washer
I have a GE WCVH 6260 front loading washing machine. It has a massive tear (approx. the bottom third) in the rubber door seal. All the water drained inside the unit, beneath the tub, on down to the floor...
Please join us in this petition to have GE recall this front loading washer! Thanks :)
http://www.thepetitionsite.com/739/633/604/recall-ge-wcvh-front-loading-washing-machines-due-to-smoking-fire-hazard/
Dec 01, 2010 | GE WCVH6260F Front Load Washer
Our new GE front load washer shakes/ vibrates and moves during the spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Aug 22, 2010 | GE WSXH208A Front Load Washer
Door on ge front loader washer leaks, door gasket is fine. Could it be the lock not working properly
Yes it could be the door lock not pulling the door in enough to make the seal. Solution... Remove covers and with door pressed in hard, ( You may need help ), adjust the lock mechanism to make seal. Put lock-tite on the threads after it works for you. This will prevent the shaking of the washer from losening of the nuts again.
Aug 01, 2010 | GE WSXH208A Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
I have a Duet Whirlpool Front Load washer on the spin cycle it make a clanking sound and is now dripping waster from the bottom of machine.
your pump is going bad.the water is leaking from pump or rubber door boot that connects to tub and wher door shuts,check for tear in boot.
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Doesn't spin the clothes dry on the final spin but spins at high revolutions without a load of clothes
I have read that if the pump is not draining the tub completely, there is an interlock that prevents the high speed spin from engagin. I have had debris caught in my pump several times (kids!!) with similar issues. There is a trap on the line leading from the tub to the pump which is "supposed" to capture debris, but it doesn't work all that well. Check your pump.....
Dec 18, 2007 | Frigidaire GLTR1670A Front Load Washer
GE WBVH6240F Front Load Washer Logo
54 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
