Question about Samsung Televison & Video
40' Samsung TV model LN40d610 showing retrace lines top 2 inches of screen with double image.
  • 84 Answers
SOURCE: hdtv lcd 40 in. broken screen face
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
  • 191 Answers
SOURCE: Vertical stripes on screen.
well, change ur screen their is failure in your screen line & row moudle
Posted on Sep 29, 2008
  • 2920 Answers
SOURCE: double images
you will need to have the tv re converged to make the picture right call a repairman
Posted on Feb 16, 2009
  • 2318 Answers
SOURCE: retrace lines in top of tv...
These lines are cause by defective capacitors in the vertical section of the TV. No adjustment will work unless the capacitors are replace. The values of the capacitors are between 1uF, 10uF or possibly a 47uF.
I do not have the service manual at this moment but you can google it by the model number of your TV.
Let me know if you need further assistance.
Posted on Jun 16, 2009
SOURCE: I have got Samsung Plano 29 inch TV. I see
I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
Posted on Nov 25, 2010
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
TOP RETRACE LINE IN THE SAMSUNG CRT TV MODEL CB5081Z
you are going to find a open filter capacitor right at the vertical output chip (usually a 220 uf at 25-35 volts) that is open or low in value.
If the set is run like this it will soon destroy the output chip.
Mar 23, 2012 | Televison & Video
Samsung lcd tv 40" model#ln40a450c1d.
try changing the aspect ratio to 16:9 if not it could be a burnout.
May 20, 2011 | Televison & Video
Green lines down length of screen on my samsung 40 inch LE40F8
The reason for the green lines are the resolution. I'm assuming you're TV is set at 1080i, not 720p or 1080p correct? What happens is the "i" stands for interlaced, meaning, your TV displays your images with scan-lines. The "p" stands for progressive, meaning, TV displays picture as a whole. You can not visibly see the scan lines when seeing 1080i, but certain TV programs are not outputting their show to the resolution you're at, which will cause you to have the green line up at the top of your TV. SOME TVs might let you adjust the settings to rid yourself of the scanline, but most consumer TVs will not let you without the maintenance code to protect your unit from over calibrating and braking your television. Hope this helps.
Mar 20, 2010 | Samsung LTN1535 15 in. HD-Ready LCD...
Retrace lines in top of tv...
Jun 16, 2009 | Toshiba 27A45 27" TV
Double images
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Retrace lines and poor convergence
you have bad solder connections on the convergance board solder then and get back to me k
Oct 30, 2007 | JVC AV-48WP74 48" Rear Projection...
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Televison & Video Logo
81 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
