Question about Tennis Tutor Sports Tutor HomePlate Pitching Machine
My tennis tutor plus model is not working, the lower button is not responding in the elevation control....any help???
A number W tripled plus t quadrupled
Destiny, number w tripled plus t quadrupled is 3w+4t.
Search the net. for algebra help/tutoring.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Aug 23, 2016 | Motorcycles
Replacing battery on tennis tutor
it is very simple . Just lie the machine down as u play tennis . Use a hex key and loosen out 6 hex screw joining the two half of the upper and lower black boxes of the tennis machine . take out some screws on the upper control panel not all of them.and one more hex screw on the upper box . Lift off the upper box. You can the battery right there. Proceed to change the battery. U can buy a battery for $23 on ebay but the unit need 2. If u need any other parts , call tennis tutor manufacturer phone is attached to the machine. They are very nice and send out replacement parts free of charge by Federal Express.
Jun 04, 2014 | Sport & Outdoor - Others
Balls stuck in tubep
Hello
It sounds like there is a build up of material on either the ball throwing wheels (decreasing the overall velocity and causing the balls to stick in the tube) or a build up in the actual tube.
From the manual, it recommends against using new tennis balls in the unit as this directly contributes to the debris build up on the ball throwing wheels. It is recommended to use slightly used balls as some of the waxy coating and ink on the ball would have been partially worn off.
I would suggest using a spray cleaner (like Windex) to clean out the tube. IF you get any material on your cleaning cloth, continue cleaning and, if necessary, use a mild abrasive pad to help with the cleaning process.
As for the ball throwing wheels, the manual suggests using a 40 to 60 grade sand paper and cleaning all of the wheels until they are slightly rough to the touch.
The manual for your unit can be found here:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=3&cad=rja&ved=0CEAQFjAC&url=http%3A%2F%2Fwww.nedtennis.org%2Ffiles%2Ftennis-tutor-prolite-user-manual.pdf&ei=9fJ9Upu2I9GIkQf144DAAg&usg=AFQjCNFSv4Co1N7iJRhQODi7rKYGDUzwbA
I hope this helps you out!
Nov 09, 2013 | Tennis Tutor Plus Player Tennis Ball...
What is paddle tennis?
Paddle tennis is one of my favorite games! It is similar to regular tennis except for a few factors. Paddle tennis uses solid paddles instead of a strung racquet. Also, the court is smaller, there are no double's lanes and the net is lower than regular tennis. It is usually played in doubles on an enclosed court.
Jan 14, 2013 | Sport & Outdoor - Others
My treadmill is locked in the max incline position and controls won't respond
Run the software calibration for diagnose, troubleshooting, and fix it.
2) clean the gear and shaft from elevation motor.
3) adjust the POT for better improvement.
see the diagram
God bless you
Jul 27, 2012 | Exercise & Fitness
Tennis tutor
Google the model number or call the maker or their customer service number if it is found.
Jun 13, 2012 | Dryers
Elevation Will NOT go down after the elevation calibration
Unplug unit and remove motor shroud if you are savvy with a multi meter then try these trouble shooting procedure:
Perform and elevation calibration again, On the display, can you see numbers counting down and up and the treadmill is going up and down? If yes then the unit will proceed to work, if no when power is on, check on the lower board, on connector J5, do we have 5V DC between pin 1 & 3? If yes During Calibration, J5, between Pin 5 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 4 & 6, on the lower board, do we have 120V AC when treadmill is going up?
If Yes During Calibration, J5, between Pin 2 & 3, on the lower board, do we have DC voltage varying from 1.15 to 3.00? If any of the above is no then then the lower board will need replacing if all is yes then elevation motor needs replacing.
Jul 31, 2010 | RTO Bodyguard T200 Treadmill
My 7222 copier will not start it is showing f-77-2
M7 (Elevator motor) drive abnormality
• While the elevate tray is going
up, the PWB-F (Elevate tray
top face sensor) is not turned
OFF in the specified period of
time after the M7 is turned
ON.
down, the M7 is locked.
• The S2 (Elevate tray upper
limit switch) or the S3 (Elevate
tray lower limit switch) is
turned ON in the specified
period of time after the elevate
tray starts to drive.
The main
body stops
immediately,
and the RL1
(Main) turn
OFF.
M7 (Elevator motor)
PWB-A (Control board)
PWB-F (Elevate tray top face
sensor)
S2 (Elevate tray upper limit switch)
S3 (Elevate tray lower limit switch)
FS-114 F77-2 M11-FN (Elevator motor) drive
failure
• During tray ascending, PC14-
FN (Top face detection sensor)
does not ON after specified
time from M11-FN ON.
• During tray descending, it
does not reach the target
position within specified time.
• During tray descending, M11-
FN is locked.
PWB-A FN (Control board)
PC15-FN (Top face detection
sensor)
UNPLUG FINISHER AND SHUT WORK
Feb 23, 2009 | Konica Minolta Office Equipment & Supplies
Tennis Tutor Sports Tutor HomePlate Pitching Machine Logo
258 people viewed this question
Top Tennis Tutor Sport & Outdoor - Others Experts
Are you a Tennis Tutor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
