Question about Philips Televison & Video
The resistor #5561 is burn, what that value that resistor
4 Suggested Answers
SOURCE: Fried resistor, need value for R801
Brown/ Black/ Brown/ Gold It is a 100 ohm +/- 5%
Posted on Feb 11, 2008
  • 4234 Answers
SOURCE: Resistor problem in sanyo
I can not even begin to help without the model number as each model is slightly different. Can you post that please?
Thanks,
Dan
Posted on Oct 29, 2008
SOURCE: videocon crt tv poewr supply failure burn the
videocon crt tv vdf vc 232 is dead and fuse burns when swicth on
Posted on Jun 16, 2010
What is the value of resistor 601
600 ohms
A resistor with a number code instead of a letter code is a SMD:
Surface Mount Device. You might have searched for SMD resistor code and got some hits.
The system for SMD resistors is:
1st value-2nd value-multiplier
6 - 0 - 1 following zero
= 600 or 600 ohms
603 would be 60,000 Ohms or 60k
6 - 0 - 3 following zeros
Mar 21, 2016 | Televison & Video
Need Help with burned resistors value. Please.
have you repaired the component that burned these resistors out? if not then you cannot replace them as they will just cook again.
Nov 06, 2015 | Cobra CPI 1575 1500 Watt 12 Volt DC to 120...
Motor Joy
Hey boss. Just follow this guide and replace with a resistor that matches the value and tolerance. You have a 5 Band resistor, follow the guild and you should be good. Click here for a chart to help you identify the values.
Jul 06, 2013 | Car Audio & Video
I need to know the value of the Resistor "R1" in
Let us use a bit of logic to resolve this... I have an Axiom but it would be a lot of screws to take out to get to the part... so let us think about this. The resistor value starts with a "1" and we know it is 5% tolerance (gold). we know the resistor burnt up with likely 5 volts on it... Value could be 1000 ohms, however the voltages present (12 volts max) would NOT have burned up a resistor of 1000 ohms. The USB area is mostly 5 volts and across 100 ohms is only a quarter watt... not enough to really burn up a resistor... First thing is to MEASURE that the resistor s open... in spite of being burned, it MAY still be OK... these resistors now usually either open or remain close to their value. The resistor ALSO may be a fusible resistor intended to act as a fuse... Is the resistor open or not? is it near a resistance with a "1" as the first digit? If it is not open I suspect it is not all of the problem. In that case, look for a burned circuit trace on the board. If it is open, then MEASURE the voltage across the resistor with the power applied. If you find 5 volts, then it MIGHT be a 10 ohm used to limit the USB current to 500ma. Get back to me with your findings... I have unraveled many of these things...
Jul 12, 2011 | Music
What is the value of the resistor that burns up when to much RF power is input?
Hi wrightjc2,
Most common burned resistor are those with low resistance because it acts like a fuse to avoid further damaged to some parts if shorts,overload happened. But still best to have a schematic diagram to identify the burned one. If you haven't a schematic you may get the resistance of the resistor, measure it to the middle where the burned cut out, add the resistance from one half side to other half side. You may now have an Idea what may be the value of the burned resistor.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 25, 2011 | Pyramid (Swr14) Swr&Power Field Strength...
Resistor burned on my Grandmother's Emerson model NR303TT
Hello Gio, Hi, a burned resistor is usually caused by a shorted part like a semiconductor or regulator, there are two things you should do, find the value of the resistor and what caused the resistor to burned, for the Resistor, the value is usually written on the board, If not you can find the value on schematics diagram (which is usually hard to find, but if you have one, fine), and on the same working model (very remote a possibility). IF this are not available, you now need the assistance of a technician.
Jan 26, 2011 | Emerson NR303TT CD Shelf System
Burned resistor, need value for replacement
I re-drew the schematics from the PCB-layout and did some backward engineering to determine the resistor value. The machine is now again in excellent working order.
Jan 20, 2009 | Sewing Machines
Burned resistor... no clue what is its value
brYze,
take a look and get the resistor number printed on the pcb. i might be able to give you what you're asking for.
Francis
Aug 31, 2008 | AOC 4 Vn 14" CRT Monitor
Burn resistor
if its a 4 band resistor, use the following calculator...
http://www.dannyg.com/examples/res2/resistor.htm
if the resistor is a 5 band, use the following link....
http://www.sizes.com/materls/resistorcolor.htm
hope this helps!
Jun 16, 2008 | Dell E773C 17" CRT Monitor
Televison & Video Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
