Question about Canon PIXMA MX860 All-In-One InkJet Printer
Canon MX860 had an error code of C002 after a grinding noise occurred when I left the top up for a few minutes after removing an ink cartridge. Then after turning power on and off a few times, an error code of C000 appeared. Then after turning power on and off while top was up the grinding noise occurred again when the print cartridge moved to the left and error code 5100 appeared.
vanbiaka
  • 104 Answers
SOURCE: I have got error code 5100
If you've already cleanup the cartridges try the followings
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please let me know if this work for you.
Posted on Dec 03, 2008
  • 1335 Answers
SOURCE: Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
Posted on May 05, 2009
nyilasrobert
  • 627 Answers
SOURCE: error 5100
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab
Posted on Jun 29, 2009
  • 1126 Answers
SOURCE: I get an error message c000 when i turn on my
Feeder unit and / or purge unit defective.
Blocked Zahnrad-/Kupplungs-Verbindung between the two systems / defective. The purge unit pump or hose is clogged...recommend having serviced by tech.
Posted on Nov 24, 2009
komguy
  • 2306 Answers
SOURCE: Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Posted on Dec 13, 2009
How do I reset or fix an Error B200 Code on a Canon PIXMA MX860 Printer?
Dear
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
9. Plug the power back in and turn the printer on.
Thanks
Jan 15, 2015 | Canon PIXMA MX860 All-In-One InkJet...
Canon MX 892 = Printer error has occurred. Turn off power than turn back on. If problem persists see the manual.
The grinding noise would be a clue that something needs to be put right before the reset would work!
Open the cover and check the paper has not jammed or cartridge has not been placed correctly.......remove cartridge and replace! Then turn off power and back on again!
Oct 19, 2014 | Canon PIXMA MX892 multifunction printer
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Mar 06, 2013 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Can I fix canon error 5C20 myself?
Dial 18002430019 Canon Printer 24/7 find here Canon Printer Customer Service number 24 hour and booming path to get instant technical support for technical problems.
May 07, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I have PIXMA MX860, I recently replaced new cartridges.. but all time when I switched on printer , error u140 comes.. please help me out
The ink tank is not compatible with this machine. (The lamp on the ink tank is off.) You can try reseat the cartridge if that doesn't work, you need to replace it.
Here's instruction on how to replace an ink cartridge for MX860 http://support-au.canon.com.au/contents/AU/EN/8200407400.html
Dec 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon mp250 series can i print only in black and white i ran out of color ink.
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Nov 08, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Cant ge the print cartridges out of my Canon MP830
[6A00] or Light blinking 12 times = AP position error. It's mean there is an error occurred in the AP motor during purging operation. You may need to replace Sheet feed unit, logic board or purge unit. And also please use original Canon cartridges to solve your problem too. Thank you
May 29, 2010 | Canon PIXMA MP830 All-In-One InkJet...
My Canon printer MX860 will get half low on ink and freeze up with error U163 telling you to replace the ink cartridge. Is there a way to override this error so you can use the remaing ink?
This just happened with my MX860. I pushed the "Stop" button on the far right of the control panel and held until it beeped. Appears to do some kind of a reset. After that, the U163 error was cleared and it printed again. Don't know how long it will go before that happens again but it is working for now. Hope this helps.
Apr 26, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Receive message 345 and alarm which prevents operation.
Other Canon models "may" be repaired with these instructions also, for example MP370, MP390, etc. Try with your own risk.
Symptoms:
-Grinding noise (very loud)
-Flashes error code ##345
Error code ##345 = "BJ cartridge head cleaning error" -reasons for this are:
-Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up. Make sure waste ink pump rotates freely, after cleaning. Clean the waste pump-hose too! Waste ink pump is located under head cleaning system.
Short solution:
1.Take apart and wash the ink clogged mechanical parts. Use hot water.
2. Reset waste ink counter
purge unit: HM1-0723-000
see more parts: http://www.e-parts.fr/pictures/uploaded/files/MP_360_370.pdf
I hope this is useful
Sep 25, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Canon Pixma MP530 All-In-One
I had contacted Canon to resolve my problem.
Through the technician I am informed that the printer has to be sent back for service as one of the 4 pins on print-head print has dropped off leaving only 3pins that is why the error code U043 simply occur which is why replacing another new ink cartridge does not resolve the issue.
I have understand from him that:-
  1. Most of the time when error code flash up, usually are due to the unique feature that Canon has build on the ink cartridges not properly done which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges. Of course this causes inconvenient to users, but if users are not using 3rd party ink cartridges, once detected is Canon's ink cartridge issue, do contact Canon, they will provide house call for 1 to 1 exchange for the ink cartridge.
  2. Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  3. If your problem is like mine, inputting the ink cartridge into the wrong slot, well I guess only have to contact Canon as the printer's components used seem to be highly sensitive, by input the wrong slot would have caused scatches on the pin, well it is better to have the ink cartridge remove by the expert than to DIY. (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
I hope the above information will help all the troubled Canon printer users as I notice from previous search on this website, there are other users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again, by replace a new ink cartridge will help as the partial used one would be faulty already, and do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge.
Mar 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MX860 All-In-One InkJet Printer Logo
62 people viewed this question
old marine
old marine
