Question about Vacuums
Cuisine select oven
I need to adjust the lid and have no manual. Never been issued a manual
  • Vacuums Master
  • 18,414 Answers
You can download a free copy from our site.
Posted on Aug 02, 2013
Is the t-fall steam cuisine 700 bpa free
It should not matter because that product gets very bad reviews due to being cheaply made. The handles, lids and tray break very easily and too soon. Many people are having the same issue and complaints are high. Avoid this item
Jan 01, 2015 | Vacuums
Recovery tank has no water in it when shampooing
Hi there! Try these quick troubleshooting steps below to restore suction to your cleaner.
1. Remove the solution tank.
2. Recline the handle and let the cleaner lay down flat.
3. Remove the dirty water tank lid.
4. Adjust the front panel located on the outside of the tank in the center so that it is flush and even across.
5. Assemble lid back on dirty water tank from the front to the back. Be sure the lid does not lift off from the front.
Hope this helps!
Jul 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My dyson no longer will turn on. Is there some filters I am supposed to be cleaning. Purchased the vacuum from someone who did not have the manual.
you have two filters, one under the lid on your dust bin and one in the ball. It could be the switch has gone bad because of overheating.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 12, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
I have a Betty Crocker BC 1679C Toaster Oven and I need a replacement control knob (the dial that you turn to adjust the temperature). Can you please advide where I can find this part.
I couldn't come up with the part# or even who manufacturers Betty Crocker's appliances. I do notice on their website (bettycrockerstore.com) that they have an email contact for help with replacement parts. It is on the contact page. Under 'select a subject', choose 'product information'. "Help with replacement parts" is the second option. There is also an 800 number and a mailing address listed. Here is the site: http://www.bettycrockerstore.com/HelpContactUs.aspx
Hope this helps
Jan 30, 2011 | Vacuums
L'm trying to find the instruction manual for my convection oven. lt's a galloping gourmet cuisine express ( model AX-707A-C5500 Thank You
Go to this link.
http://www.recipelink.com/mf/11/11674
Click on :
Galloping Gourmet Cuisine Express Model AX-707A (C5500) The Electronic Touchpad Manual.pdf (click here).
It's a 35 Mbyte file.
After clicking it takes you to another page.
Move your mouse over the name and you will see a DOWNLOAD LINK appear.
Click DOWNLOAD and you should be able to save the manual.
Hope this helps. Don't forget to live positive feedback. Thanks for your rating.
Jan 06, 2011 | Vacuums
What is the ratio of yogurt culture to milk to make yogurt? I have misplaced the instructions to the euro cuisine yogurt maker.
Usually only a very little culture is needed to be added to milk to obtain good yogurt. But if you can add 100ml to one litre milk , it will be fine.
Aug 31, 2010 | Vacuums
My hoover steam vac is not releasing the cleaner
http://www.hoover.com/pdfs/manuals/F5914900.pdf this is the manual for your model
Godbless
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Possible cause
Possible solution
• Solution tank not firmly in place
• Make sure tank is securely locked in
position
• Solution tank empty
• Refill tank according to instructions for
surface being cleaned
correctly
• Make sure lid is firmly in place
• Pump needs to be “primed” (when
using tool)
• See “Before using tool” section, p. 13
Jun 15, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Mcculloch chainsaw 2416
All you have to do is call 1-800-521-8559 and select U.S. then select the parts department, have your model number ready and ask them for a PDF of the owners user manual to be emailed to you, they will normally be sent in 1 hour for free.
Aug 03, 2008 | McCulloch MC1275 Steam Vacuum
Vacuums Logo
41 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
