Question about Broan-NuTone RC515 Door Chime Remote Control
The rc515 door chime is not working - Broan-NuTone RC515 Door Chime Remote Control
The door chime for the sliding door stays on even when the door is closed
Look underniethe dash for a rectangular black box, older chevs had the chime separate to the radio, yours may be old enough that it still has the chime box. If not, it could be the connection at the door or a bad door latch switch, via a wiring diagram you can find which wire diactivates the chime and either splice it or disconnect it, the system could work with continuity or an open circuit.
good luck!
Apr 22, 2014 | 2003 Chevrolet Venture Passanger
Open door chimes and keys left in in car chimes plus left on chimes not working question what operates chimes door lock ?
Door left open chime is operated by your interior light switch. It is located in a few places on different vehicles. Often in the door jam at the front or low down on the pillar at the rear of the door. You will notice a little black rubber boot and when you push it it goes in and out. That is your interior light switch.
Feb 04, 2011 | 2000 Volkswagen Golf
How to install
its all very simple, just plug in the receiver, and make sure the battery for the button is good.
May 20, 2010 | Broan-NuTone RC515 Door Chime Remote...
Wirless bell and intercom
Since most of these systems are digital now, there should be no affect to your application. The signals are all scrambled, as not to interfere with each other.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Mar 15, 2010 | Broan-NuTone RC515 Door Chime Remote...
We had a power surge a few months ago and every since the front and back door doorbell doesn't work. Model # CBP972 - 16 VAC. Can you assist me in getting it to function again?
Wireless units usually arent the problem, it is probaly you main unit that had blown the transmit, Have you unplugged or powered down the units and restarted them
Nov 30, 2009 | Broan-NuTone RC515 Door Chime Remote...
Static through door bell can't turn off
Check all the ground wires to make sure they have a good ground
Aug 07, 2009 | Broan-NuTone RC515 Door Chime Remote...
Disarm door chime
According to my manual.
>Turn Chime Doors on:
1. System must be disarmed. Press Chime Doors button.
panel will announce,"Chimes On". Chime Doors button will be lit.
> Turn Chime Doors off:
1. Press Chime Doors button.
panel will announce, "Chime off". Chime Doors button no longer lit.
Sep 02, 2008 | GE Security Simon 3 Wireless Home Security...
Repair at home
You Need to Buy a ESR Electrolytic Capacitor Tester. Can get one on Ebay ( Affordable ) or Shop around. I Bought one New when I was a Troubleshooter & Making A Lot of Money for abt $200. Largest paper or Metal Electrolytic Capacitors are usually Your Main Problem. Elect Caps Dry out from Heat-age. Capacitor Testers DO NOT Find these Problems I Tried them. More Often I always find More than One Bad ESR Electrolytic Capacitors on All Audio, Intercom, Computer Monitors, Color Tvs I Service. The two leads You put across all Elect Caps on Motherboard or Chassis Instantly Tells if good-bad. I Make and Save Money on all Products I Often service with ESR Problems. Esr Tester Pays for itself Quickly. Takes Disassemly and time to Restore Service But I always Get the Job Done.
Aug 16, 2008 | Broan-NuTone RC515 Door Chime Remote...
Broan-NuTone RC515 Door Chime Remote Control Logo
Top Broan-NuTone Televison & Video Experts
Electro Med Services...
Are you a Broan-NuTone Televison and Video Expert? Answer questions, earn points and help others
