Question about Polaris Pool & Spa
How to install polaris 9-100-7010 - Polaris Pool & Spa
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
Diagram to install a fuel lines on a polaris atv
talk to dealer ship to get diagrams
Nov 26, 2011 | Polaris ATV
2011 polaris 500 sportsman ho ...going down hill it free wheels is this normal ?
Yes this is normal for the 2011 Sportsman 500. The 500 does not have a one way bearing in the clutch acting like an engine brake as do the previous years. Polaris removed this option for the 500 sportsman in 2009. If you were to own a 550 it would not free wheel down a hill.
Aug 14, 2011 | Polaris ATV
95 polaris xcr 440 headlight burns out shortly after install
IF YOU ARE NOT TOUCHING THE BULB WHEN YOU INSTALL IT, THAN IT IS THE VOLTAGE REGULATOR
Dec 24, 2010 | Polaris New Genuine Polaris Snowmobile...
Just bought a new polaris booster pump (PB4-60) and installed it...the polaris ran for a few seconds and shut off.
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
Apr 14, 2010 | Polaris Pb460 Polaris Booster Pump...
Polaris snowmobile spark plug wire replacement
THEY ARE THREADED ON . TURN IT COUNTER CLOCKWISE TO REMOVE IT AND CLOCK WISE TO INSTALL IT
Dec 23, 2009 | Polaris New Genuine Polaris Snowmobile...
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Pool & Spa Logo
15 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
