Question about Home
Jacuzzi allora The oval shaped plastic pads between the seat and the chinaware have splintered and are breaking off. Where can I buy replacements and how do they fit on?
SOURCE: replacement ear pads
http://headsetpartsunlimited.com/orderinfo.html
Posted on Mar 09, 2008
chiquititas
  • 1010 Answers
SOURCE: brekas Nissan Datsun Sentra 1982
May have to shave them pads down, or see if the parts store carries different ones that are thinner. Good luck.
Posted on May 15, 2008
dragonsthatk
  • 547 Answers
SOURCE: Jacuzzi Whirlpool toilet EZ33959
any one should fit
Posted on Feb 21, 2009
heavyt15
  • 91 Answers
SOURCE: How do I replace a light bulb in an Indesit cooker hood
Yup we break them all the time...flaw...
Posted on Nov 04, 2009
  • 518 Answers
SOURCE: how to replace heater hose bypass fitting on 03 impala
You need to buy the fittings first they are sold by a company called HELP motormite. Very common to go bad. You will need to buy or borrow springlock tool. Are sold seperately or in a set. What they are is a garter spring that will disconnect quick connector on fittings. The parts store will have them too.
Posted on Jun 07, 2010
Testimonial: "It is good idea to buy replacement part first a then what...?"
How to replace a toilet seat
There are round and oval seats.... take note of which you need. Back towards the bowls water tank on the toilet seat you will notice two tabs....pop open with a screwdriver. You will see the screws holding the toilet seat in place. .
Reach under the screw there will be a plastic nut. Hold if while you losen the screws with the Screwdriver....remove and replace seat. ... install screws and plastic nuts again.... and your finished. ...5 minute repair
Sep 30, 2014 | Home
Tip
Identifying Your Reebok / Robix Studio Cycle
  • 9600
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and dual brake pads.
  • 9800
    Black matte finish on 1-piece welded frame. Black crank arms (generally) and single brake pad.
  • 9900
    Glossy finishes w/angled back legs (stabilizer). Bolt-together frame (assembly required). Rectangle shaped stabilizers.
  • 2000B
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Silver crank arms and belt driven.
  • 2000C
    Glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and single brake pad. Black crank arms and chain driven.
  • 3000B Robix
    Black glossy finish w/angled back legs (stabilizer). Bolt-together frame (assembly required). Oval shaped stabilizers and frame down tube. Belt driven with single brake pad.
http://www.sportsmith.net/Categories.aspx?did=CEF96124-843A-4128-9B53-8E10980C9920
on Mar 11, 2015 | Exercise & Fitness
Have to replace two new toilets seats,the seats move
Martin, Jacuzzi has a one year warranty on toilet seats so if you have defective seats and they were purchased less than a year it is covered you will have to find a dealer near you, I provided a link for you to accomplish this. How is the seat attached? There should be two plastic screws with a nut on the underside which can be tightened these tend to loosen and nee re-tightening every so often. I hope this has helped. Thanks for using FIXYA, good luck and have a great day. Jeff
Find A Jacuzzi Dealer
Apr 07, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Jacuzzi Era elongated seat attachment
first need to buy the longer oval seat so it sits correctly at the front most mounting screws are universal-- go buy thin rubber washers and trim and place between the hinge and bowl than tighten down this will stop slippage but the front if not correctly sitting on the bowl will still cause problems
Jan 22, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
Do you have to take the gas tank out to replace the fuel pump on 95 subaru lagacy wagon 4x4
No. On the sedan, remove the rear seat and carpet, there will be an oval shaped plate, remove that and fuel pump is right there.
On the wagon, remove the carpet, same oval shaped plate.
May 01, 2009 | Subaru Legacy Cars & Trucks
Looking for a lifter rock lever plate pad for a singer 211g156
Bit confused here, what is the 'make' of the machine and what do you mean by 'pad'
Mar 25, 2008 | Sewing Machines
Need replacement earpads for Sony FM/AM Walkman SRF-H4 headset radio
Roger, ear pads are US $3.54 each. plus tax and shipping.
follow link:
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=81781&searchOperation=modelSearch&searchText=SRFHM33
Good luck. I had the same problem.
Mar 20, 2008 | Sony SRF-H4 AM/FM/Weather/TV Radio
Replacement ear pads
Jan 24, 2008 | Logitech Internet Chat Consumer Headset
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
