Question about Gateway 505GR PC Desktop
My gateway monitor just went black/greyish
I tried to disconnect all components and power and nothing seemed to help. I cant even see a menun on it.
  • 3 Answers
Try to disconnect the monitor from the back of the pc..........if you are getting any messege then monitor is fine................if not there is some problem with the monitor so u can try to swap the cables if still that dosent work try with different monitor ............if that works then is some problem with the monitor............u need to replace it.............
Posted on Sep 06, 2007
  • 20 Answers
It's likely the monitor just died and needs to be repaired or replaced. Do you have another monitor you can try temporarily?
Posted on Sep 01, 2007
SOURCE:
Gateway FPD1960 monitor
support.gateway.com/s/Manuals/Monitors/8511446.pdf OK manuals above and below. support.gateway.com/support/manlib/.../Monitor.shtml Below is how to repair your monitor step by step, hope this helps. http://www.ccl-la.com/LCDrepair10.htm
I looked for a service manual, but could find none :(
Jun 06, 2010 | Gateway FPD1975W 19" LCD Monitor
Working fine till yesterday. When shutdown
Open up the set and look for bad caps, see some failed monitors here: http://s807.photobucket.com/home/budm/allalbums
Jan 11, 2010 | Gateway FPD1760 Monitor
Screen went black
You could have a back-light problem and it could be a faulty inverter board or a CCFL lamp.
For service, parts and DIY info check out LCD parts - Click on this link to their WEB site :-
www.lcdparts.net
Dec 19, 2009 | Acer 22" X223w LCD Monitor
My gateway desktop does not want to start,
Check you bios configuration with Date and time correction.
See if your computer need cpu fan cleaning. Try to run F8 and scan your computer after you have accessed to safemode. Goodluck
JMC
Aug 15, 2009 | Gateway Computers & Internet
My gateway mt6839b wont turn on anymore
Gateway was working good went upstairs came back NOTHING BLACK SCREEN....
My gateway screen was constently black every time I powered on nothing no bios, nostart up no warning..The board has indicating lights to follow the start up power light on, battery light on, then the disk drive....but thats it normaly the harddrive reader light comes on but nothing.... So detached every component and tested individually..... come to find out one of my 2 ram slots is damaged not the chips...this could be your problem..try
Skillz Unlimited MDA
Nov 20, 2008 | Gateway MT3705 Notebook
Gateway FPD1975W black 19 inch LCD
most likely is the power supply in the monitor.
gateway LCD has a building power supply in the monitor. it supplies 38W to the lamp.
since there is no display, it tells me that there is no power to the monitor.
if try another monitor and it works fine. then the problem is the monitor. (dispaly lamp is good for 17 Years- according to the tech spec.) but the power supply is pushing too much power.
other vendors max power is apporximately 30W.
make sure there is nothing behind the monitor and has good air flow. Since there is no fan in the unit. it need to vent the hot air natually.
Oct 18, 2008 | Gateway FPD1975W 19" LCD Monitor
Black Screen
Look in the back of the Gateway where you currently have the video cable connected. If there are two connectors, (Side by Side) there than disconnect & re-connect to the other. Your display should come up. Don't be fooled. Most Pc's that have no display on their monitor is not a monitor problem but a computer problem.
Feb 08, 2008 | Sony VAIO VGC-V617G PC Desktop
Power Supply/Video on/off problem
hi, seems to be a problem design, you can check the users review on: http://reviews.digitaltrends.com/review1430.html options 1,5 even 6 is ok. sorry.
Aug 26, 2007 | Gateway /ton 160W Power Supply (6500582)...
Gateway monitors not powering on
Do you get an Amber light on either monitor?
Jun 21, 2007 | Gateway FPD1950
Screen lit up, but nothing displayed (black)
Hello Frank, I have the same problem with my monitor. I don?t have the answer yet to resolve the problem. if you want the first of us who find the resolution will advise the other. I sent an email to Xerox to get the info to remove the cover without breaking it. regards Sylvain
Sep 01, 2006 | Xerox XG-91D 19" LCD Monitor
Gateway 505GR PC Desktop Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
