Question about managemylife.com
Trying to program garage door opener when pressing learn button, nothing happens with hand held remote.
Posted on Aug 07, 2013
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
I don't have the owner's manual for my 2002 GMC Yukon XL Denali. Do you know how to program the garage door opener?
I hope this helps.
Programming the HomeLink Transmitter
Do not use the HomeLink Transmitter with any garage
door opener that does not have the stop and reverse
feature. This includes any garage door opener model
manufactured before April 1, 1982.
Be sure that people and objects are clear of the garage
door you are programming.
It is recommended that a new battery be installed in
your hand-held transmitter for quicker and more
accurate transmission of the radio frequency.
Your vehicle's engine should be turned off while
programming the transmitter. Follow these steps to
program up to three channels:
1. Decide which one of the three channels (one of the
HomeLink buttons) you want to program.
2. Press and hold the desired button on HomeLink
through Step 3.
3. When the HomeLink indicator light begins to blink
slowly (this may take up to 30 seconds), hold the
hand-held transmitter about 1 to 3 inches (3 to 8 cm)
away from HomeLink and then press and hold the
transmit button on the hand-held transmitter.
Continue to hold both buttons until the indicator
light on HomeLink begins to flash rapidly (this may
take up to 90 seconds).
If you have trouble programming HomeLink, make
sure that you have followed the directions exactly as
described and that the battery in the hand-held
transmitter is not weak. If you still cannot program it,
move the hand-held transmitter to the left or right or
forward or backward or flip it upside down. HomeLink
may not work with older garage door openers that do
not meet current Federal Consumer Safety Standards.
If you cannot program the transmitter after repeated
attempts, refer to "Training a Garage Door Opener with
Rolling Codes" later in this section or contact the
manufacturer of HomeLink at 1-800-355-3515,
or on the internet at www.homelink.com.
Be sure to keep the original hand-held transmitter in
case you need to erase and reprogram HomeLink.
Training a Garage Door Opener with a
"Rolling Code" Feature (If Equipped)
If you have not previously programmed the hand-held
transmitter to HomeLink, see "Programming the
HomeLink Transmitter" listed previously. If you have
completed this programming already, you now need to
train the garage door opener motor head unit to
recognize HomeLink.
1. Find the "Learn" or "Smartbutton" on the garage
door opener motor head unit. The exact location and
color will vary by garage door opener brand. If you
have difficulty finding the Learn or Smart button,
refer to your garage door opener owner's manual or
contact the manufacturer of HomeLink at
1-800-355-3515, or on the internet at
www.homelink.com.
Because of the steps involved, it may be helpful
to have another person assist in programming
the transmitter.
2. Press the Learn or Smart button on the garage
door opener motor head unit. An indicator light will
begin to flash when the motor head unit enters the
training mode.
Following this step, you have 30 seconds to
start Step 3.
3. Return to HomeLink in your vehicle and firmly
press and release the programmed HomeLink button
three times.
The rolling-code garage door opener should now
recognize HomeLink. You may either use HomeLink
or the hand-held transmitter to open the garage door.
If after following these instructions, you still have
problems training the garage door opener, contact the
www.gmcextendedwarranty.com
Dec 19, 2010 | GMC Yukon XL Cars & Trucks
MODEL 139.53975SRT1 1/2 Hp opener will not work with any remotes, I tried to reprogram remotes; pressed learn button, the light next to it came on, pressed button on remote, nothing happened. I cleared...
The correct way to program a remote is to hold the button down on the remote and then press and immediately release the learn button. If this doesn't work your logic board is bad.
Nov 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
I have lost manufacturers manual on my BMW 325ci 2001 model. i only require pages relating to the programing of automatic garage door thank you
NOTE: Some vehicles may require the ignition to be turned on or to the second (or"accessory") position for programming and/or operation of HomeLink. It is also recommended that a new battery be replaced in the hand held transmitter of the device being programmed to HomeLink for quicker training and accurate transmission of the radio frequency. Please use a ladder and do not stand on your vehicle during the programming steps for a rolling code opener.
Rolling Code Programming:
1. Press and hold the two outer HomeLink buttons until the indicator light begins to flash (after 20 seconds). Do not hold for longer than 30 seconds. Do not repeat this step to program additional HomeLink buttons.
2. Place the hand-held remote 1-3 inches from the HomeLink button you want to program.
3. Simultaneously, press and hold both the HomeLink and hand-held remote buttons. Do not release either button until step 4 has been completed. (If you reside in Canada, refer to the "NOTE" below.)
4. When the indicator light changes from a slow blink to a rapid flash, release both buttons.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the"learn" or "smart" button (usually near where the hanging antenna wire is attached).
6. Press and release this "learn" or "smart" button. (The name of these buttons vary by manufacturer.) There are 30 seconds in which to initiate step 7.
7. Firmly press, hold for two seconds, and release the programmed HomeLink button. Do this procedure again and, depending on the make of your garage door opener, do this procedure a third time to complete the procedure.
The garage should now activate when the programmed HomeLink button is firmly pressed and released. If not, give us a call or refer to the "Troubleshooting Tips" noted below. NOTE: If you reside in Canada, replace step three with the following: Press and hold the desired HomeLink button and "cycle" the hand-held remote. To cycle: Press and release the hand-held remote button every two seconds until the indicator light changes from a slow blink to a rapid flash(step four).
Troubleshooting Tips:
** Check the frequency of the garage door opener's hand-held remote (usually found on the back). HomeLink is compatible with radio-frequency devices operating between 288-399 Mhz.
** Put a brand new, store bought battery in the hand held remote. During the programming process (step three above) the battery's energy tends to drain (more so with an older battery). A new battery will increase the speed and accuracy in which the hand-held remote sends its signal to HomeLink.
** Retrain HomeLink holding the hand-held remote at different lengths and angles from the HomeLink button you are trying to program (during programming step three). Try 4-6 inches away at a different angle.
** Confirm that the HomeLink button you are trying to program is in the "programming mode". Press and hold the desired button. The indicator light will be a slow blink when HomeLink is in the "programming" mode and can be programmed at any time.
Verifying HomeLink has picked up a rolling code signal:
** Press and hold the programmed HomeLink button. If the indicator light blinks rapidly for two seconds and turns solid, HomeLink has successfully picked up the rolling code signal. If necessary, proceed with steps 5-7 noted above to complete the rolling code programming.
Sep 09, 2009 | 2001 BMW 325
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
HomeLink works in vehicle... unable to program hand held or remot
When did your remote and keypad quit working? Was it when you programmed the Homelink? It sure sounds like you have a bad logic board.
Jul 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Program 2004 mercury mountainer garage opener
Verify the hand-held transmitter is operative.
Prepare for programming the universal transmitter by erasing all three channels (hold down the two outside buttons until the red light begins to flash [20-30 seconds]). Release both buttons.
Select one of the three universal transmitter channels to be programmed by pressing the desired button
Hold the end of the hand-held transmitter 25-51 mm (1-2 in) from the front surface of the universal transmitter so that the red light can still be seen
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
Hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
If the hand-held transmitter appears to program the universal transmitter but does not open the garage door, the garage door opener may have a code protected or rolling code feature.
To operate, simply press the appropriate button on the universal transmitter. The red light is on while the signal is being transmitted.
IF THE GARAGE OPENER HAS ROLLING CODES---
program as above then------
Train the garage door opener receiver to recognize the universal transmitter.
Remove the cover panel from the garage door opener receiver.
Locate the training button on the garage door opener receiver. Location and color of the button may vary by garage door opener manufacturer. Refer to the garage door opener instruction manual or owner literature.
Press the training button on the garage door opener receiver for 1-2 seconds.
Press the programmed universal transmitter button for as long as the universal transmitter red light flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
The garage door opener should recognize the universal transmitter.
Apr 01, 2009 | 2004 Mercury Mountaineer
Programming remotes for garage door
sounds like you are doing keypad ok. is battery good. as far as homelink in car. follow directions for rolling code/security plus.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftman garge door opener changing code on key pad
having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
managemylife.com Logo
49 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
