Question about Furuno GP32 GPS Receiver
Keeps blowing fuses,certain polarity is correct,very frustrating
Mackie profx12 fuse keep blow
Be sure the capacitor was replaced with the correct polarity?
in the beginning of my tech career I have replaced caps back words on accident. ..
Mar 06, 2015 | Mackie ProFX12 Professional Compact Mixer
How hard is it to replace under dash fuse box on 1999 pontiac sunfire
It is certainly dooable, but it isn't a trivial undertaking. Just take your time and be methodical. Make sure you make good connections. You are likely taking the correct course if you are keeping the car because chasing loose fuse blocks can be frustrating.
Jan 02, 2015 | 1999 Pontiac Sunfire
Keep blowing number 32 fuse in a 2005 Lincoln navigator what causes it to keep blowing
fusee blow because of excess current caused by a short either in the wires after the fuse or in the equipment that the fuses controls.
Dec 21, 2014 | 2005 Chevrolet Equinox
I have an Onan 3600 microquiet lp. I made the mistake of hooking up a jumper box to the battery with the cables crossed,now it blows the 5amp fuse that supplies power for starting. hope I didn't fry...
It certainly sounds like you have damaged the control board. If you cranked it with reverse polarity, there is a good chance that you have rotor winding damage also. If not you still may have to flash the rotor windings to ensure a correct polarized field. That involves hooking a battery for a couple of seconds to the rotor brushes (with correct polarity) with rotor brush wires disconnected. Only do this if there is no output voltage after you replace the control boards. Bad mistake :)
Aug 05, 2013 | Onan Microquiet Generator Lp Vapor 3600...
When i hook a new battery up i keep blowing the main fuse in the fuse box under the hood. Are the poles on the battery reversed from the standard batteries?
see the schematic:the + RED cable must be in+ and Black cable in -minus.
6_19_2012_11_41_08_pm.jpg6_19_2012_11_42_15_pm.giftest after you did the correct polarities, see if the solenoid or starter motor are in SHORT circuit. disconnect each wire step from step until you isolate the short.
God bless you
Jun 19, 2012 | 1997 Mazda 626
My fuse blows everytime i plug in my sirius radio to cigarette lighter...why?
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
May 12, 2010 | Sirius Satellite Radio Receiver
I have a TRC 458 cb.... it keeps blowing fuses
It may have been reversed polarity on turn on. This can short out the polarity diode and then cause fuses to blow. This is a protection circuit so do not keep trying new fuses as the reverse surge can go into the radio deeper and damage it beyond repair.
Feb 02, 2010 | Radio Shack Radio Communications
Fan is not working even i use air condition or heater no air coming out and i don't know which one to replace?
First check the fuse for the heater/ac fan. If the fuse is OK, you probably need a new blower motor. If the fuse is blown, replace it. If it blows again, you could have short in the heat/ac control computer, or the blower motor may still be bad. In this vehicle, the blower motor is probably less expensive to replace than the controller, and you can test the blower once it is disconnected by applying battery voltage to it (observe correct polarity). If it does not move when jumped directly to the battery, it is almost certainly bad.
Dec 20, 2009 | 2003 Acura 3.2TL
Blows 15 amp car fuse as soon as switch is turned on nothing plugged into inverter
If the fuse doesn't blow until you turn the inverter on, the problem is in the input circuit. First, be sure the polarity is correct when you're connecting the inverter. If you manage to get the 12 volts hooked up backwards this will blow the fuse. If the input polarity is correct, the diode inside that protects against reverse polarity may be shorted. Beyond that, it's difficult to make any suggestions about what parts to check. You would need to use an ohmmeter to check the parts in the input for very low readings from the 12 volt input to ground. If you can do this yourself or know someone who can, it might be worth a try. But if you try to take this somewhere for service - if you can find a shop willing to look at it - it may be more economical just to replace it.
Good luck with the inverter, and thanks for using Fixya!
Nov 24, 2009 | Powerline 0900-73 Slimline Inverter
Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
Dec 02, 2008 | Dishwashers
Furuno GP32 GPS Receiver Logo
18 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
