Question about Maytag LAT3600A Top Load Washer
Stop lug how to adjust the stop lug, the screw came out of mine and it fell out so I need to reset it Thanks John
  • masterson Sep 02, 2007
    Thankyou ever so much Thankyou for answering my question, A++++A++++A+++++++A++++++++++++++++++++++++++++++++ Thankyou John Masterson
  • 291 Answers
Been a long time since i done one.. but seems like when in place turn clutch ass. tell feel catch.. should be like 1/8 in. gap with stop
Posted on Sep 01, 2007
How do I set the time?
Hi Charles,
I presume you're referring to a chronometer watch?
You need to twist the crown (little screw on the right side of the piece) counter clockwise until it slightly pops out. This is position 1. You need to pull the crown outward gently until you feel a lug sensation. This is position 2. Turn the crown to adjust the 'date' until you reach yesterday's date (one date before what you actually want). Then pull the crown outward again feeling that lug sensation. This is position 3. Turn the crown so the minute-hand swings in the normal movement of time (don't swing it backwards). Keep doing this until the 'date' turns to the current date. Now your piece is set on the correct date and the minute-hand is in the "a.m." Now keep turning the crown until you've reach the current time (noting the am/pm period you want). Push the crown inward to Position 2, then to Position 1. Turn the crown while in Position 1 to wind the spring. How many times depends on your brand, mine is 35-40 turns. Once I am done, push in the crown and turn simultaneously to lock it down. It will stop when it is seated properly.
Good luck.
Mar 10, 2015 | Watches
Install throttle adjustment nutscrew?
Screw it in until the idle is at the right RPM.
Mar 03, 2015 | Motorcycles
John deere L108.drives for about 2 minutes mowing and stops.leave for about 15 mins and will go again.puffs of smoke when put under load
John:
The puffs of smoke when you put the machine under a load make me think that your carburetor is loading up and needs to be adjusted. Adjust the fuel/air adjustment screws on the carb until it runs properly.
Jan 20, 2013 | John Deere Garden
I have a Dewault D55141 air compressor that runs to 150 lbs of pressure and blows the valve and releases air. I read your reply to same problem about cut out pressure adjustment
Looking at your manual, instead of the actual item since I don't have one, I see 312, 329 and 314. It is possible that 312 the switch is shorted causing the pump to run to pop off and beyond. Item 14 is the pop off valve and if the numbers indicate anything, it is a 175 PSI pop off and is going off early. The switch doesn't have any indication of pressure rating.
The screw and bracket that mounts on the switch may be a pressure adjustment but hard to tell remotely.
Some units like this don't have adjustments, they just pump to a predetermined pressure and stop, being determined by the pressure switch and if the switch fails, a pop off will prevent over-pressuring the tank or system.
If you determine that the screw and bracket do not make an adjustable pressure switch, replace the switch with a like on or one that you can adjust in the range you need. Also if the pop off is going off early, replace or if possible, clean it, they can become dirty with rust.
Is possible that the screw fell out of the pressure switch rendering it "broken" until you put it back in....
Nov 04, 2012 | Dewalt & 2HP Hand Carry Heavy Duty...
How do I adjust(set)the engine speed govenor on an Atco 114cc engine.
Some ATCO carburettors have more than one hole for attaching the throttle cable to the governor pivot, which will allow some variation of the speed setting by moving to a different hole.
Just before the throttle cable reaches the governor pivot it passes through a metal lug (separated from the pivot by a spring) here there is threaded screw on the throttle cable - loosen or tighten this to adjust running speed.
There is also a throttle stop adjusting screw which on the side of the carburettor which you can adjust to set the idle speed.
Feb 22, 2011 | Garden
Hi, my name is Audrey! I have a Ducati 620ie 2002. Recently I was riding and my rear break pedal fell off due to the screw that was holding it was rusty. Ever since that happened my after market vizi-tec...
Sounds like you need a good screw.(to hold the pedal on)
I assume you have replaced the brake pedal, and it is the brake light that is flashing not the tail light.
there should be small electrical brake switch that the pedal has to push to turn the light off, when the brake lever returns to its normal position, this switch is adjustable,
There is also the posibility of the switch being damaged when the pedal fell off.
Jan 31, 2011 | 1999 Ducati Monster 600 - Dark - City -...
I have a 452 echo. lost the manual in a move. the boys 8-9 decided to tune up the saw and now I can't get it running...can you help me with the begining setings..Thanks John
Likely, they have adjusted the H and L jet needles and maybe the idle speed screw. Turn both jet screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting and should let the engine start and run. Start the engine and let warm up, then pull the throttle full on. Adjust H jet needle CW until the engine starts to speed up, but 4-stroking. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW for better idle, but allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but allows the engine to continue to run. Hope this helps!
Sep 08, 2010 | Echo Garden
My handset fell down yesterday and the display is gone.Though I can receive and make calls
Hello
When the handset fell down, the flex that connect the screen and the panel has shift. Get a screw driver, unscrew the phone and try to adjust the screen.
If after doing his the problem continues you need to change the screen of the phone.
Thanks
Aug 12, 2010 | Nokia 6300 Cellular Phone
Kitchen Aid Model KUDPQ1FLSS5 door counterbalance issue
One of the counter bakance springs OR the adjuster for it let go. I had a similar thing where the adjuster which was a thin metal "T" thing that screwed up into the spring as an adjuster folded and fell out of the spring.
Remove the bottom dress cover at the tope kick of the dishwasher. The springs are all accessable right there. The problem will be obvious. Just compare the two sides.
I had to beef up the "T" adjsuter in mine as it was too weak to continue holding in the spring.
One turns it into more or less coils of the spring to adjust the counterbalance.
Apr 21, 2010 | KitchenAid Dishwashers
Adjustting 1020 john dreere carburetor
Adjust both carburetor screws all the way in untill they stop gently then: back out both screws 1 and, 1/2 turns: the engine should now start.
adjust for smoothness; no mor than 1/2 turn in or, out. kill engine and, restart untill engine starts easily.
Apr 06, 2010 | John Deere Tractor 1020, 1520, 1530,...
Maytag LAT3600A Top Load Washer Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
