Question about Video Cameras
KDL4DEX500 Flat Screen TV. How to turn off startup sound?
My tv model e470-a0 vizio turns off and on with the backlight and the vizio on screen logo is crystal clear on startup. No picture and sound other than some very very faint scrambled lines towards the...
T con board affects picture only. since you are having issues with both the picture and audio I would suspect the main board which deals with both.
Dec 29, 2016 | Vizio Televison & Video
How to turn off startup sound in sansui LED
Live with it. No way to turn off startup sound of your Sansui LED TV.
Nov 27, 2014 | Sansui Televison & Video
Vizio 47" screen won't stay on
Your Vizio TV may be exhibiting symptoms of power supply trouble even though it is quite new.
Dec 01, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
How to turn off startup sound on tcl lcd tv menu
You can go service mode of your TV by menu>picture>contract press 1950 within 3 seconds.
When you appear a menu, you choose Service Menu>Config>Pwon_music >> OFF
And exit.
Turn off and turn on TV to enjoy
Jun 29, 2013 | Televison & Video
Hisense tv menu options blocked
Hello
What is the exact model number to your Hisense TV? You can get it from the back cover of your TV. Get it to me. OK.
Feb 07, 2012 | Hisense Televison & Video
My tv keeps clicking on and off at startup. Sometimes taking 3-4 attempts to turn the screen on. Also, it will start without picture only sound
Your #1 suspect: LCD inverter, which supplies white light to the screen.
Your #2 suspect: the switched power supply, specifically 24VDC lead that supplies power
to the LCD inverter.
Either way, enjoy your 40-in set while it lasts, since its soon to be heading for a TV repair service.
Jan 02, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung LNT4061F LCD tv with red specs and white lines on screen
Yes this is the color wheel that this tv has you would need to remplace the color wheel here is a web site where you can find it for a good price
www.discount-merchant.com
Good Luck and besta regards
Ness
Dec 18, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Dec 19, 2008 | Philips BDS 4611 46 in. Plasma Television
Video Cameras Logo
32 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
