Question about Home Security
How to change code cisa safe - Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    Change code
    If it is locked and the person you got it from didn't give you the existing code, you can't. We see this all the time. If there was a way to bypass the code to the safe, anyone could do it. They are called a 'safe' for a reason, the contents are safe once the door is closed and locked :-) The only way to get in is to take to a locksmith who will drill the door, open it and put a new door on it. This is not usually a cost effective open with a small locker type safe.
    Nov 23, 2015 | Home Security
    I need to reset my combination to my mesa safe
    This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
    If you changed the Master Code you will need to use the code you changed it to.
    Deleting your current User Codes:
    Input * - * lock will beep twice
    input 6-6-6-# lock will beep twice
    Input current Master Code - # lock will beep twice
    Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
    Re-input user number - # light stays green for 3 seconds
    Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
    This will delete user 5
    Unsuccessful code change: five beeps, repeat the steps.
    Changing User Codes: Code length can be 3 to 8 digits long
    Input 4 - 4 - 4 - # lock will beep twice
    Input Current User Code - # lock will beep twice
    Input User Number - #
    Input New User Code - # lock will beep twice
    Re-input New User Code - # light stays green for 3 seconds
    Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
    That example will change user code 2.
    Unsuccessful Code Change: five beeps, repeat the steps.
    There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
    The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
    Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
    How to open a cisa safe
    use the master key to unlock. its behind the button panel, peel off from bottom lefthand side of the oval sticker pad, to reveal the key hole
    Jan 06, 2013 | Home Security
    Changing the code on my Sentry Safe S3877
    how to change the on sentry safe s3877
    Sep 29, 2008 | Sentry Fireproof Safe
    Home Security Logo
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
