Question about Lexmark X5250 All-In-One InkJet Printer
Lexmark X5250 power button keeps flashing. I have tried : 1) power off overnight 2) clean encoder strip 3) checked - 100% no paper jam Still keep flashing. When I lift up the top to check ink which doesn't move out. Anyone can help? Many thanks !
4 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Panel Lights stay on at power on
the problem is the fuser is shot, they are still available and you might think about replacing the fed and sep tires at the same time.
Posted on Feb 18, 2008
SOURCE: Lexmark X73 paper jam
please solve my problem
Posted on Sep 26, 2008
  • 3 Answers
SOURCE: Lexmark 5150 - Error 0502
I have had this problem "Hardware Error 0502" which kept getting worse until I could not print any more. So I open the cartridge cover & removed both good cartridges, pushed the cartridge carrier fully to the right hand side & with one slightly damp cloth, a dry cloth & a pair of latex gloves (as the ink stains your skin) I first carfully cleaned the guey head like things on the bottom inside the printer on the left hand side. I removed a load of hard & soft gue with the damp cloth then finished with the dry cloth. Next I cleaned the bottom track aswell, moved the cartriage carrier fully to the left hand side to clean the rest of the bottom track. I then re-installed both cartriages & the printer is now perfect again!
Posted on Jan 08, 2009
Hello my printer wont work, the powerbutton is blinking and i hear a tikking noise. is mij printer broken?? lexmark x5250
It could an alignment problem, a paper jam, or something blocking the paper path. Open the printer cover and remove both the cartridges. While the cover is open, check the cartridge area for any obstructions in the cartridge carrier's path. Check any transparent strip(encoder strip) that has become loose from its position. If there's nothing out of the ordinary, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges and make sure they properly inserted and secured. Close the cover and try to print again.
May 29, 2011 | Lexmark X5250 All-In-One InkJet Printer
Check error
Try the following steps
1. Unplug power
2. USING THE FINGER HOLDS ON EITHER SIDE, lock scanner cover into open position
DO NOT TOUCH THE ENCODER STRIP (clear plastic strip in front of the white vinyl band)
3. Remove jammed paper/foreign objects (check under the print head; if the print head is in the middle, slide it to the either the left or the right side, & check for paper scraps underneath the print head)
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE LEFT SIDE]
4. Move the print head to the middle
5. With the print head in the middle, remove any ripped paper/foreign objects from the left corner (SINCE THE RIPPED PAPER COULD BE VERY SMALL, USE A FLASHLIGHT TO INSPECT)
6. Close the scanner cover & plug the machine back into the power outlet
[PERSISTENCE OF THIS ERROR MESSAGE OR NO PAPER SCRAPS/FOREIGN OBJECTS FOUND MEANS THAT THE ENCODER STRIP WILL REQUIRE CLEANING]
[IF WHEN THE SCANNER COVER WAS OPENED, THE PRINT HEAD IS ON THE RIGHT SIDE]
7. Plug the power cord back into the power outlet...LCD will show "Cover is Open"
8. Press Stop/Exit for approximately 5 seconds until the print head moves to the middle
9. UNPLUG MACHINE FROM POWER OUTLET
10. USE A FLASHLIGHT & TWEEZERS TO INSPECT: Remove any debris from the right corner
11. USING THE FINGER HOLDS ON EITHER SIDE, close scanner cover & plug machine into power outlet
TO CLEAN THE ENCODER STRIP... (clear plastic strip in front of the white vinyl band)
[Markings & debris can adhere on the surface of encoder strip FROM HAND CONTACT &/OR GREASE CONTACT INCURRED FROM REMOVAL OF JAMMED PAPER]
DO NOT USE FLAMMABLE SUBSTANCES NOR ANY TYPE OF SPRAY TO CLEAN INSIDE/OUTSIDE MACHINE
1. Unplug machine from power outlet
3. Clean both sides of encoder WITH ONLY A DRY, LINT-FREE CLOTH
DO NOT FORCEFULLY PULL ON ENCODER STRIP
DO NOT TOUCH ENCODER STRIP WITH BARE HANDS
DO NOT FORCEFULLY SCRUB ENCODER STRIP (THAT COULD SCRATCH ITS SURFACE)
4. Clean encoder strip from right to left--stopping just before the left corner
5. Clean encoder strip from left to right--stopping just before the right corner
6. Repeat steps 5 & 6 two or three times to clean thoroughly
7. After cleaning encoder strip, USE FINGER HOLDS TO close scanner cover
8. Plug machine back into power outlet.
Nov 29, 2010 | Brother M 4318 Matrix Printer
Hardware error 0502 - I have turned printer & computer off and back on & still have error. What do I need to do? I just replaced both color & black cartridges and have been having some problems...
Hello.
The problem is with the encoder strip (thin strip with slots on the end).
Here's what to do (from Lexmark support):
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the printer.
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
How to Perform the Hardware Test on the Lexmark X5150
Using the operator panel on the printer:
1. Press the Option button 10 times until Cartridges appears on the LED display.
2. Press the + button 4 times until Self test appears on the LED Display.
3. Press Select. The printer should print a sheet of paper with one black bar and one grey bar.
4. If the printer fails to print, remove both cartridges and try the test again. (It will feed the paper through and print a blank page.)
5. If the test works with no cartridges in the printer, run it again with one cartridge at a time installed.
Hope this helps.
Dec 19, 2009 | Lexmark X5150 All-In-One InkJet Printer
MY Lexmark X5150 All-In-One InkJet Printer Problem
HI try this its from the lexmark web site
Hardware Error 0502 on LCD Display ID:ENUS16536
2. Disconnect the power cable from the back of the Lexmark X5100 / X6100 Series.
11. Perform the hardware test without cartridges first and then with both cartridges.*
How to Perform the Hardware Test on the Lexmark X5150 ID:ENUS3744
May 06, 2009 | Lexmark X5150 All-In-One InkJet Printer
ERROR 0502
Re-position the Encoder Strip on your all in one Printer
To re-position the encoder strip, perform the following steps:
1. Remove the power cord from the unit.
2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
NOTE
NOTE: There is a small slot that the encoder strip fits into, which is going to be located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the lid to the unit.
9. Re-connect the power supply to the All-In-One.
10. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
See attached pictures, one for an out or place encoder strip, the other for a well placed strip.
Other faults that can bring up this error is a carriage rail that needs cleaning and oiling (so you might want to do that while your inside the thing), and also obstructions to the paper ways. Try removing paper jams, and put the printer upside down to shake loose anything that might jam the mechanism.
Dec 12, 2008 | Lexmark X6170 All-In-One InkJet Printer
Carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Hardware error code 0502
HI try this its from the lexmark web site.
Aug 21, 2008 | Lexmark Office Equipment & Supplies
Paper Jam wont clear and there is no paper in it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Aug 17, 2008 | Dell 924 All-in-One InkJet Printer
Clear paper jam message but no paper jam
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check if the Encoder Strip is Broken or Missing
Note:
Adjust the Printer Paper Guides
Adjust the paper guides to fit the size paper being used .The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides.
Locate and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.\
6. Remove any visible obstructions.
7. Reinsert the paper.
Clean the paper feed roller on the printer.
1. Power down the printer and disconnect the power cord.
2. Remove all paper from the input tray.
3. Wipe the roller gently with a damp cloth.
Aug 13, 2008 | Dell 924 All-in-One InkJet Printer
Hardware error 0502 on lexmark 3in1 printer
Mar 31, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5250 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
