Question about Amana Refrigerators
Just plugged Amana sbde520t in, Motor starts up straight away and front touch panel starts flashing blue. Try to programme temperate for both deepfreeze and fridge but touch screen doesnt seem to respond. I click the top * to turn it on and it doesnt work. Please help.
fridgetech
  • 473 Answers
SOURCE: Fridge freezer KIM 29473GB/01
Liners are not able to be replaced. Will need to buy a new unit if the liner is a problem.
Posted on Oct 07, 2007
the dr
  • 447 Answers
SOURCE: kenmore side by side (2003)
Dont mean to butt in here but your refrig probably has a ECM (electronic contolled motor) which means it has a tiny computer inside it....these motors are plastic and have a plastic blade. these are a little more energy efficient and it helps the manuf get bettter energy star ratings...however...they do from time to time decide not to start every time that the unit comes on...this cause excessive heat and freon pressure to be exerted on the compressor and its electricals... The replacement motor is just the old style shade pole (magnets) motor...not quite as quiet or efficient but wayyyy more reliable. Order a replacement blade seperately from the blade/motor kit since the blade in the kit is always destroyed by the motor inside the box.
Posted on Jan 20, 2008
  • 42 Answers
SOURCE: plug mic and earphone to the front panel
hi!gud am...hope this will help...
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
goodluck...
Posted on Feb 28, 2008
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
  • 1462 Answers
SOURCE: BEKO D 2731 FW Dishwasher Problem
possibly due to water in the sump tray. tilt machine back at 45deg and see if water runs out. if it does and you get rid of the water that way, then the machine should operate. if it reoccurs, then you have a leak
Posted on Jun 21, 2008
SBDE520T Side-by-side. Why does water accumulate on bottom?
The drain tube to the defrost water pan may have become clogged.
Aug 08, 2015 | Amana Refrigerators
ZWD 1662 W start/Pause button flashing but not connecting to programme
hi,if this is the washer drier type try this,unplug m/c!! take lid off and locate the four connections to the drier unit near the back panel.some connections will be double tagged others single tag.disconnect all four connections and let wires dangle down a bit ,they shouldn`t touch anything.plug m/c back in and try a program such as drain and spin,and then if ok try a fill.the reasoning behind this is that the drier element goes faulty and gives a false reading to the control pcb.if this is successful ,replace the drier element.another option if any of that doesn`t work ,check carbon motor brushes.
Jul 22, 2014 | Washing Machines
Hotpoint aquarius washing machine
Try unplug from electrical outlet wait 15 minutes and plug it in. If you are lucky it will reset. If you are not lucky it sounds like the circuit board may be damaged.
Apr 24, 2014 | Washing Machines
My amana 27" front load
Although I do not have the list for your particular model, 'nd' probably stands for 'No Drain'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 29, 2011 | Washing Machines
The washer programme has frozen and stuck on a cycle. how do i reset programme?
try unplugging the machine for 10 minutes,plug it back in and see if it will reset,if not you could have a button stuck inor a bad touch panel,send the model number next time located around the door opening.
Nov 28, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hi i have got an acer extena 2300 laptop
when yo u power up the computer press F8 key then enter in safe mode.
Then go to start menu then run then type in run "chkdsk /r"
then press "y"
then resatrt it then it fixc error on harddisk.
Also try enable vga mode.
Check disply property screen resolution to 1024*768
Jun 23, 2009 | Computers & Internet
Amana Touchmatic Heavy Duty Washer Filter Light Flashing
I have the same washer unit and I purchased my washer new in 1989. The flashing filter light is normal. If the light doesn't flash, than the water filter is plugged up. The water filter is self cleaning each time the water empties. You can take off the front panel(two screws at the bottom and the top disengages with metal clips. The water filter in at the bottom on the right, white plastic housing. There is a drive belt from the motor that powers the pump. When the washer goes into the spin cycle, the motor changes rotation direction and the pump works in reverse, thus flushing out the lint that may have been captured during the agitation cycle. I hope this helps.
Mar 14, 2009 | Amana Washing Machines
Zanussi zwf 1432 w washing machine
pcb as the signs were that the pcb was stuck in a programme and unable to change. Anyway, long story short, to fix it:
Take the lid off the washing machine (2 screws at the back) *unplug first
Locate the pcb, unscrew and lift above the washing machine with all wires in tact.
Locate the wires that are coming out of the back of the "program" board, it should be 2 blue wires.
Follow these back to the pcb and unplug
plug in washing machine
Turn on washing machine
Only the on/off light should come on
Whilst on, and being careful, plug back in the wires you unplugged
VOILA, fixed washing machine!!
Right, have to go, got a weeks worth of washing to do!!!!
Feb 24, 2008 | Zanussi ZWF1430W Front Load Washer
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
