Question about Korg Micro Microkorg Xl Synthesizer Vocoder Keyboard Bk
Hello everyone. The dial on my microkorgXL which changes the operations of the knobs does not work, is it possible to fix this? Without it I can't change anything or use the on-screen editor. I haven't opened it yet but it's strange how it's the only thing that doesn't work on this keyboard. Thank you for any help.
    Scholar:
    New Friend:
  • 82 Answers
Sounds like a bad rotary encoder (the part that the "dial" is attached to"). If the circuit board or solder is not cracked in that area then that is likely the problem. You could find the part at mouser.com (about $1) and would need desolder the bad encoder and solder the new one in place or get the whole PCBA(printed circuit board assembly) from Korg.
Posted on Aug 03, 2013
I have a korg pa 80 it have not sound
Initialization: N/A
Preload: Disk Load (6 Disk set available from korgpa.com)
ROM Check: Given on power up.
http://www.sweetwater.com/sweetcare/articles/initialize-reset-preload-korg-pa80-60
Apr 10, 2014 | Korg 37 MINI-KEY 8-VOICE...
Someone spilt half a pint of lager over my Mackie 1604 Vlz3. The desk operated for an hour after but gave some noise so I switched it off. I cleaned off all the surface fluid but some of the knobs, faders...
These units are not the easiest to open up without damage. The lager has likely evaporated and left behind some residue. Yes the pc board it attached by allen screws. Each control must be removed as well. This unit requires a complete clean with an electronics wash. It is possible that there is some corrosion as well. Please have this cleaned professionally and checked. It is in your best interest in the long run.
Dan
Dec 30, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
The wiring is messed up the volume knob does not work right
If nobody has changed the wiring in this guitar, suspect either a broken wire or possibly a cracked resistance element in the volume pot. This can happen if the knob on it takes a blow.
Aug 28, 2010 | Dean Vendetta XM Electric Guitar
Hello; I have a used Behringer pmp5000 mixer. The
Without knowing how you have your monitors configured it is hard to analyze what you have posted.
In brief, SW3 on the schematic that selects MAIN L and MAIN R in the upper position, MAIN and MONITOR in the middle, and bridged in the lower is used to configure the internal amps.
In the upper position, the amp power outputs come from the mixed stereo bus and are simultaneously controlled as a stereo signal by the MAIN slider.
In the middle position MAIN and MONITOR, the left amp receives the signal from the mix bus and is controlled by the MAIN slider. The MONITOR output from the other side of the power amp is controlled ONLY by possibly the "MONO" slider.
The schematics are hard to decode and what is needed is a signal flow diagram.
For my uses, I don't try to use splitting the power amps between mains and monitor but prefer to use the mains together with SW3 in the upper position (Note your 27 may be refering to the user manual designation for same switch). I then use another small amp from the 1/4 inch MONITOR jacks whcih are under control of the MONITOR sliders.
Please note that the MIX for these two MONITOR channels is controlled by the MON1 and MON2 knobs for each channel.
May 23, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How to get the effects to work on the mixer
This is in general for Behringer mixers since you did NOT tell us a model number...
To use the effects you adjust the FX knob for EACH channel for the amount of the mic or input you want to send to effects from that channel. This is the "send" mix.
You dial in one of the effects based on the list near the effects selection window with the selector knob and the number will change and start flashing. You press down on the selection knob which will enter the new effects number and the number will be solid and not flashing.
Then there is a knob to select how much of the OUTPUT of the effects you want to go to the main and sometimes one for the amount to the monitors.
That is all there is to it. The effects can be gated by a foot switch input if you desire.
It is a good idea to include a model number as your thing is posted as if it is a PMP3000 mixer.
May 11, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Cyber Twin selector knob.
The selector knob may be a potentiometer or a rotary impulse giver device. In any case, it looks like the internal contacts are either dirty or oxydized so the value is changing in an erratic way which causes the unit to skip several presets at a time.
It would require a skilled technician to disassemble and clean the controller (if it can be disassembled in the first place), otherwise you will probably need to replace the preset selector knob entirely.
Regards,
Triarcuate
Oct 07, 2009 | Music
Faulty effects behringer djx700
The effects on the PMP powered mixers flash UNTIL you push in on the selector knob. This way you can dial in the next effect number and then push in later to activate when you want it... Could yours possibly be the same technique?
May 16, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Korg Micro Microkorg Xl Synthesizer Vocoder Keyboard Bk Logo
63 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Korg Music Expert? Answer questions, earn points and help others
