The Acer Aspire 1825PTZ touch screen is glitching out. When I touch the bottom part of the screen, mostly the whole taskbar side, the cursor would bring itself to the right-most part of the screen. When I put it to tablet mode and flip the screen orientation, it's the same side that glitches out. (touching the top part would point the cursor at the left-most side of the screen. But when I touch anywhere else, it works properly albeit being inaccurate. I tried re-calibrating multiple times, yet there's no change. I am positive that it's a driver error, and makes me feel negative. Now that I have disabled the touch input, my tablet-PC is kinda down-graded already.
4 Suggested Answers
SOURCE: my touch button at bottom of touch pad doesnt work
My 5100 left button got stuck in the down position. I wiggled it to get it back to the the normal/up position. Then I put some 'scotch' tape on the button and over the frame around the button. The goal is that the tape will keep the button from going in too far. I haven't had to change the tape in six months.
Good Luck,
Posted on Feb 07, 2010
james klgr
  • 362 Answers
SOURCE: i just reformated my hp pavilion tx2500, the
most likely check the device manager but the scrweens touch part does go bad.
Posted on Apr 13, 2010
vikasbharti8
  • 179 Answers
SOURCE: my acer aspire one touch
Check the drivers for the touch pad..install it again..use the below link
http://ud-pc.com/notebook/driver/Acer/Aspire_One/Touchpad_Synaptics_v.11.1.4.zip
else contact acer..your touch pad must have to be replaced(Acer Tech. Number: 1-800-426-7378)
Posted on Sep 06, 2011
White lines in my screen and broken display
If it has been damaged, order a new screen through flea bay or gumtree and follow the online video on utube of how to replace your screen.
Jan 19, 2014 | Acer Aspire Computers & Internet
Acer Aspire M/ The cursor disappeared and I cant get it back
first confirm that your touch pad is working or not. yor touch pad may be disabled or it may be dead. you can enable your touch pad in it's setting. you can connect an external mouse to your laptop to check that. or you can enable mouse keys in control panel.
Apr 10, 2013 | Acer Aspire Computers & Internet
When I'm in the process of typing emails, sometimes the message just disappears; sometimes the cursor jumps to another area of the message and sometimes the cursor disappears! Any solution to this? I got...
Most of the time you can recover the message by hitting ctrl + z. the curser diapering may be a software glitch or a setting somewhere, and I do not have an explanation for the curser moving by its self except maybe accidently touching the sensor with your wrist, they use the heat from the part of your body that touches them so it is very easy to accidently touch it and not realize.
Jan 18, 2011 | Acer Aspire One Netbook 8.9" Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Asus notebook K501J Model. A blue wall at bottom of screen, about two inches high screen' .I cannot remove same. Also I cannot get the task at bottom of screen,
Try this:
Place your cursor at the top of the wide blue band. See if the cursor arrow changes to a 2-sided arrow. If if does, hold down the left button and move the cursor down until the screen is again normal.
Basically what you have done is to take part of the window and increase the size of the bar. This actually should be the taskbar, but it's way too large.
Oct 30, 2009 | ASUS K50IJ-C1 Notebook
FROZEN CURSOR
Sounds like the touch pad is not working anymore. try using a USB mouse and see if that works. also, see if you can reinstall the touch pad software to fix that.
Aug 28, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Cursor jumps around
Try this software:
http://code.google.com/p/touchfreeze/downloads/list
Touch Freeze will disable the touchpad when you start typing. I have not used it, but give it a try.
Also, your touchpad could be wearing out or a driver reinstall could be in order. My wifes Toshiba had a bad touchpad and the cursor would jump all over the place. I disabled it and she now uses an external mouse. No problems anymore.
May 15, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
David Payne
David Payne
