Question about Samsung HT-X40 System
Samsung ht x30 protection - Samsung HT-X40 System
4 Suggested Answers
SOURCE: samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Posted on Nov 21, 2011
caroldon
  • 17129 Answers
SOURCE: SAMSUNG HT X30 SHUTS DOWN WITH" PROTECTION"
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
gopakumarg43
  • 74118 Answers
SOURCE: my samsung ht-x30 shuts down after 5 secs and displays protection
Hello
disconnect all the speaker connections, and switch ON the set only, and see whether any protection function energizes or not. If yes, the fault is with the amp itself, and most likely to some damge of components in the output circuit section of the amp. If the amp does not show any protection, when all the speakers are disconnected, make sure that, any one amoung the speakers be the cause of this problem. Connect one after an other and find out which one causes protection circuit to energize. OK.
Posted on Dec 28, 2011
Samsung home theatre HT-X30,
The DVD player may have failed.
Dec 19, 2013 | Audio Players & Recorders
My samsung ht-x30 shuts down after 5 secs and displays protection
Hello
Dec 28, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
It's a known issue with samsung Home Cinemas. It has to do with the cooling of the device and other related issues. One of the bellow could solve the problems.
First thing is to reset the device:#1 - Make sure there's on dvds in the system
#2 - Put it on stand by
#3 - Hold down the STOP button on the UNIT
#4 - HOLD until you see the stand-by light flash
#6 - This has now reset the system
If that doesn't work try to do a firmware upgrade http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=HT-X30
Nov 21, 2011 | Samsung Audio Players & Recorders
I have a problem using the usb port in my samsung ht x30. i'm using a 1tb external hd. it says no files. is it becuase the external hd is so big?
The external hard drive is most likely not compatible. In the user manual on pg 62 is a list of "USB Host Feature Supported Products"
(can be found here if you do not have access to one: http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/HT-X30-_E)
Feb 02, 2011 | Samsung Audio Players & Recorders
My HT-X30 AMP had blown some capacitors. Where can I get a new complete circuit board? and approximately how much would it cost?
You will find in
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Samsung++HT-X30%2CTX35%2CKX30%2CTKX3
Aug 15, 2010 | Audio Players & Recorders
Samsung ht-x30 sutting down protection error
Dec 05, 2009 | Samsung Audio Players & Recorders
Samsung DVD plater HT-X30
Try to burn your cd with CD-R 650MB/74 mins.and play: i believe it will work.
Apr 03, 2008 | Samsung HT-X40 System
Protection displayed and shuts off
Hey guys! Im glad you found my solution on my blog, and posted it here. I hope you ccan fix yours, or get it replaced on warranty. Im happy to help you with anything, the capacitors i think was 4,7 uF, 100volt, not sure.
Here is the link to my solution: http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
:D
/ lemurt
Mar 01, 2008 | Samsung HT-X40 System
Samsung HT-DB600
samsung told me the fan is not working and needs replacement or a tune up??? They can repair it for $150.00....totally sucks
Apr 29, 2007 | Samsung HT-DB600 System
Samsung HT-X40 System Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
