Question about Holmes Products HASF1710-UC Stand (Pedestal) Fan
Need a new fan blade assembly for the HASF 1710. Holmes has not be able to find a replacement. One of the four (4) fins on the blade broke off so need a new 4-blade fan (16 in diameter) or a way to re-attach the broken fin.
SOURCE: i have a holmes blizzard fan and need to clean the
Turn the fan around there are four screws on the backside of the grille. You will need a long philips head screwddriver.
Posted on Jul 13, 2009
heatman101
  • 43501 Answers
SOURCE: Holmes "16 fan needs to be lubricated. Where do you add oil
No there is no way to lubricate the new cheap fans internally...they are made to run for a bit and then be thrown out...
I have found that by using a thin oil like WD-40 and then positioning the motor so that it runs back the shaft into the motor you can get it to work into the motor. I usually use WD-40 and then follow with a light motor or sewing machine oil. This seems to give a longer solution...
heatman101
Posted on May 05, 2010
Testimonial: "Just the advice that I expected, and what I had already performed!"
  • 5 Answers
SOURCE: I have a Holmes stand fan HASF2120 that has broken
you must replace the feet., for safety porpusse.,
Posted on Jul 02, 2010
marc_uhrey
  • 72 Answers
SOURCE: Holmes HABF20 floor/box fan: broke
If you can't find a replacement plastic foot. You should be able to find rubber feet at a local Radio Shack. Replace the plastic feet with rubber feet. It will do the same. You may be able to find self-adhesive feet.
Posted on Jul 15, 2011
espressonist
  • 1711 Answers
SOURCE: I have a Holmes electric
Here at fixya we don't sell any product or parts. We can advice you some online shop to find what you need. However in your case there in not any shop that selling any parts for the electric fan on stand not only for Holmes but any brand. The factorys they don't distribute any replacing parts to suppliers and they don't sell the direcly either.
So the only option you have is to mutch the screw cap with one of an broken fan that is mathing yours. You can even buy the simple moder with 16 inch and use the srew cup at link
Posted on Jul 29, 2011
Why is my Holmes HASF-1710 not getting power
This may be a duplicate post but here's my advice. Do a little disassembly to get to the "guts" of the fan. It is not uncommon for the speed control switch to break in such a way as to not allow the circuit to be completed. You may have to actually remove the switch and inspect it to be sure of this. I've had trouble finding replacement switches so I have put them back together with superglue. If this is your problem and you choose to use this solution just be sure all the switch parts get put back where they belong. If this is not your problem, break out the ohm meter and start checking your connections. Hope this helps
Jul 06, 2014 | Holmes Products HASF1516 Stand (Pedestal)...
How do I get the housing off my Holmes hasf 1301 fan?
try turning it counter clockwise no need to be gentle.
Apr 09, 2014 | Oasis Hunter 54' Ceiling Fan
Holmes hasf 1701
this is special operation, you must have skill for to do this. You can use jering with oil and lubricate the house motor is more easy and more efective. Unless the motor is faulty. In that case will be replace it.
God bless you
Jul 11, 2013 | Dryers
My dell inspiron laptop produces howling
I believe the problem may be the cooling fan, of the Fan Assembly.
Dirt, dust, hair, food crumbs, lint, you name it, can be drawn up into the laptop by this fan.
This can cause a strain on the fan's bearings.
It could also be that the fan's bearings have simply failed. They are dry, hence the occasional howling noise.
The method is to open the laptop, and physically check the fan.
Dell Support > Inspiron 5100 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins5100/en/sm/index.htm
FIRST thing;
FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Suggest wear an ESD wrist strap, and connect it's alligator clip to a good ground source. (Electro Static Discharge)
Basic example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
[ I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. Just one example ]
On the Dell Support > Service Manual page, click on -
Microprocessor Thermal-Cooling Assembly
This shows the Fan Assembly. It is connected to the Microprocessor Thermal-Cooling Assembly.
Another view of the Fan Assembly,
http://www.brilliantstore.com/laptop-cooling-pad-dell-cpa-1606.html
View of the Microprocessor Thermal-Cooling Assembly, with the Fan Assembly,
http://www.laptopbattery-usa.com/dell-inspiron-1100-5100-5150-laptop-cpu-cooling-fan-p-1238.html?zenid=okh2t54jgsg369stoj7gipf3k5
See the 4 screws sticking up, and the squarish metal plate they go down in?
This plate sits on top of the Processor.
The two curved slightly flattened copper pipes, are Cooling Tubes.
They are sealed on both ends, and are filled with Nitrogen.
They attach to the squarish metal plate, that sits on top of the Processor, and the other end of them goes to a Heatsink.
This cannot be seen in the photo.
The Heatsink is a rectangular finned object.
Has Tall, Thin, fins.
Heat is absorbed from the Processor, by the squarish metal plate sitting on top of it.The Cooling Tubes then absorb the heat from the squarish metal plate.
Heat is then transferred along the Cooling Tubes, to the Heatsink.
The Heatsink absorbs the heat, then radiates it away with it's fins.
Air from the Fan Assembly, helps carry heat away from the Heatsink fins.
The Fan's blades, center hub, and surrounding cage, (Shroud), must be clean. If the fan's blades are dirty, the result could be an unbalanced fan.
Makes the fan tilt to one side, and possibly scrape the blades on the Shroud.
Also over time the dirt, dust, etc, can cause the Fan's bearings to fail.
Gently see if you can move the Fan up, and down. Gently grab a blade of the Fan, and see if you can move the Fan. You will know if the Fan's blades have too much movement up, and down. (Or tilt to the side)
If the Fan is bad, (Bearings), see if you can buy just the Fan, and replace it.
If not you may wish to replace the entire Microprocessor Thermal-Cooling Assembly.
Should this be the case post back in a Comment.
I need to guide you in proper replacement.
[ You need to Thoroughly clean the top of the Processor, and the bottom of the squarish metal plate that sits on it.
Then Thermal Paste needs to be Properly applied, and the 4 screws tightened down in a sequence ]
Regards,
joecoolvette
Apr 24, 2012 | Dell Inspiron 5100 Notebook
Hello. I have a stand (pedestal) Holmes fan, model number HASF-1516, that is not working when plugged in to the electrical socket. How do I go about troubleshooting?
Firstly please make sure that you connecting wire in not cut at any where and connection is good.
If your connection is ok then also it doesn't rotates then might be your coil has been burned and you need to replace its wiring and check the starter
Aug 18, 2011 | Holmes Products HASF1516 Stand (Pedestal)...
One of the blades fell off and I didn't know if we could just get that 1 blade or not.
No,sorry.You may find a replacement or a used one for parts here,http://www.buycheapr.com/us/holmes+twin+window+fan
May 12, 2011 | Holmes Products HAWF2041 Twin Window Mount...
Hi, I have a pedestal fan (16") for which am looking for spare parts. I need - fan blade (5 blades) - the clips that hold the base grill and the front grill Make: Holmes Model:...
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Jun 09, 2017 | Holmes Products Dryers
I have a holmes blizzard fan and need to clean the blade. how do i take the front cover off
Jun 30, 2009 | Holmes Products Holmes HAOF951T-U Blizzard...
Grinding of fan
There should be a black round nut in front of the blades in the very center. It will have ribs on it so you can grab it. Turn it Counter clockwise, and it should unscrew.
Then you can remove the blade assembly and get to the back cage to tighen the screws.
This should take care of the problem.
Re assemble in reverse order.
Let me know if you have any more questions or if this doesnt work.
Good luck.
Mac
Aug 19, 2008 | Holmes Products HASF1516 Stand (Pedestal)...
Holmes Products HASF1710-UC Stand (Pedestal) Fan Logo
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
ray gallant
xkikbxr
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
