Question about Whirlpool Washing Machines
I have a Whirlpool WTW4840yw washing machine. The machine only works with the complete cycle. If I want to rinse and drain or drain and spin I cant. Any clues?
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 22, 2008
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
  • 3 Answers
SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
Posted on Apr 25, 2010
My whirlpool duet will go through full wash cycle and when it get to rinse it does full rinse but light for spin does not go on and it doesn't spin it stays in spin cycle (no light on) but it does not...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore model # 110.244222300, Won't automatically complete wash
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is a Whirlpool / Kenmore service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Initial thoughts are that the Timer is worn / broken.
Here is a description of how to gain access to the console on these washers where you may be able to test the timer. (See the Whirlpool service manual for testing)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
Jan 19, 2010 | Kenmore Washing Machines
Spin cycle issue
The problem must have been fixed by now.
I think that the problem was not the belt.
If machine does not advance to spin, check the hose attached to drain pump, ensure that drain pump is working, and check or replace pressure switch.
If that does not fix the problem, check the variable speed motor and gear case.
May 25, 2009 | Whirlpool Washing Machines
Spin mode does not work
Dear "FixYa,"
I have fixed the problem with my washer.
I started clothes washing machine with one load of clothes.
Wash and rinse process completed, as it came to spin,
Machine stop, only I heard was running motor. I opened
machine and found coupler is cracked (broken) and was
unable to rotate the gear.
I replaced new coupler and machine started to work normal.
Thank you
Kanu
Apr 18, 2009 | Whirlpool Washing Machines
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
155 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
