Question about Broan-NuTone Door Chime Kit by NuTone
I installed a nutone DR-1 electric door release on my intercom system. The release works fine when I test it with the door open. However, with the door closed, the weatherstriping puts some pressure between the latch and the release and it doesn't work at all. Moving the release back, makes the door too loose.
SOURCE: humm in system
Called Nutone distributor and found that the unit is guaranteed for life. What a surprise!
Thanks for your web site, I will use you in the future.
Jay
Posted on Apr 15, 2009
  • 95 Answers
SOURCE: wiring nutone intercom system has two transformers
Here is a link to a blog with a wiring diagram. http://nutoneproducts.blogspot.com/2009/04/nutone-ima3303-master-station-and.html
Posted on Oct 02, 2009
hondo73162
  • 132 Answers
SOURCE: Fan does not work motor will buzz thats all. Nutone ultra quiet t
it may be that the bearings nead to be oiled, have you tried to spin it by pushing it with a pencil and see if it sticks or spins freely ?
Posted on Nov 07, 2009
  • 202 Answers
SOURCE: hi whenever i install transformer to nutone door
Make sure you are applying the correct voltage to the primary windings. what is the voltage you are applying?
Posted on Mar 15, 2010
gotgeek2
  • 565 Answers
SOURCE: i removed my nutone door chime transformer a while
I couldn't find a manual for the LR2982, so I'll give a general description of how to wire a door chime. Most chimes have 3 contacts. F (Front), R (Rear) and C (Common). Some have just two contacts. If your chime has more than 3 contacts do _not_ follow these instructions.
Inside the junction box on the wall where the chime will be mounted, you should have at least 2 cables (usually brown) each, with at least two wires (usually red and white) each. One of those cables goes to the transformer and the other cable goes to the door button.
The beauty of it is that since it's only 24 volts or less and _polarity_ doesn't matter, you don't need to know which cable goes where for a _single_ door button scenario.
For _single_ door button wiring, pick a wire (say the red) from one cable (doesn't matter which cable) and connect it to the "C" contact on the chime. Pick a wire (say the red) from the _other_ cable and connect it to the "F" contact on the chime (if the chime has 3 contacts). If the chime only has 2 contacts connect it to the only contact that is left.
Then all one needs to do is twist the 2 remaining wires together (both white) and cap them off with a wire nut.
If your junction box for the chime has 3 cables in it, the extra cable goes to a rear door button. In that case you _do_ need to know which cable goes to the _transformer_. You can pick up a cheapo voltmeter for about $10 just about anywhere. The cable that reads anywhere from 16 to 24 volts AC between the red and the white wires is the cable that goes to the transformer.
Make sure one of those wires from the transformer goes to the "C" contact (pick one, say the red). Now you know the 2 remaining cables go to the front and rear door buttons. For now, just connect a red from one of the remaining cables to the "F" and one red from the other remaining cable to the "R". Then just twist the 3 remaining white wires (including the white wire from the transformer) together and cap them with a wire nut.
If the rear chime sounds when the front door button is pushed, just swap the wires on "F" with the "R"contacts..
Posted on May 15, 2010
Broan kn350 intercom has a "list" error code on the display - how to fix or reset
Hold "up" - 2 - display. Release display first. Should get a "TEST" indication in LCD window. Turn Circuit Breaker that controls unit off for 15 seconds. Then reset clock and reprogram stations.
Mar 17, 2013 | Broan-NuTone Nutone IMA3303 Intercom...
I would like to replace a Nutone 8663Rm series bath exhaust fan with a Broan 683L The 683L requires an opening of 8" X 8 1/4". Since access it is located in the attic, where it is unbearably...
You can buy a replacement motor assembly for that model.
http://vacuums-intercoms.centralvacuumstores.com/search?w=8663rmsa&af=type%3Aproduct&asug=&x=0&y=0
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rmsa&Search.x=0&Search.y=0
Jun 16, 2011 | Broan-NuTone N-8663RMSA Combination Light...
Wirless bell and intercom
Since most of these systems are digital now, there should be no affect to your application. The signals are all scrambled, as not to interfere with each other.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Mar 15, 2010 | Broan-NuTone RC515 Door Chime Remote...
Wiring nutone intercom system has two transformers don't know how to wire
Sep 19, 2009 | Broan-NuTone Nutone Ir80 Metal Wall...
Humm in system
Jay
Apr 14, 2009 | Broan-NuTone N-IS-338BL Accessory Intercom...
CD player on Nutone master intercom
Turn off the switch to the Nutone intercom system on your main electrical panel for 10 seconds, then turn on, reset unit and it will play!
Oct 09, 2008 | Audio Players & Recorders
Broan-NuTone Door Chime Kit by NuTone Logo
46 people viewed this question
Top Broan-NuTone Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Steve Pack
Steve Pack
Are you a Broan-NuTone Electrical Supply Expert? Answer questions, earn points and help others
