Intruder alarm as i start my pc, it just gives a sound and then silend. no display on board
    Master:
  • 663 Answers
What sound is it? A beep? Or an annoying sound from inside the computer? Please provide more information.
Posted on Aug 01, 2013
15 year old micromark intruder alarm need to switch off
Not really enough info to give you an answer, but I can generalise...
You say Knocked alarm box with ladder alarm started"
If the fault is there permanently from when this happened there's a good chance that you have disturbed the tamper spring/switch on the cover of the alarm unit. when the front of the panel is removed you should be able to see the Sping/switch which is automatically depressed by this front panel, you may find the spring has fallen off the switch or gone out of alignment, refitting / realigning it should remove the tamper fault once the lid has been refitted properly. As for "bleeps when doors, windows opened"
This sounds like the "Chime" feature has been switched on and without the manual I cannot tell you for sure how to switch it off.
Chime is a feature which "Chimes" when a door is opened (Not often used on windows), if this started when the ladder fell on the panel it is most likely just a single key press to switch it off, Once the tamper fault is sorted you should be easily able to find the correct key press to turn the chime feature off.
Sorry for being a bit general but I don't have that particular manual. Hope the info helps you :o)
Mar 20, 2017 | Home Security
What is fault E3?
E3 means that the heating element is operating when it should not be doing so. It may be caused by an older, weaker element that is taking too long to heat the water or the thermostat may be giving incorrect readings. Ensure you are using hot water to fill the machine (if tied to your faucet water supply, run the water until it is hot before starting the dishwasher). Information from the Belling manual:
If the heating element is still heating after the allowed time, then the control board will advance the programme to next step and at the end of the washing cycle the alarm buzzer will sound for 30 sec and the display will show E3.
When the control board detects that the heating element is operating during a non heating step or during the internal test the heating circuit is found to be open circuit then the alarm buzzer will sound for 30 sec and the control board will cease all functions except for the drain cycle which will run for 90 seconds and then E3 will be displayed on the control panel.
Mar 06, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
Whirlpool FRSS2VAF20/0 . 4years old Freezer compartment Alarm goes on , Ig left for a while and start again the freezer works again but after few hours the alarms come on . The display unit shows two...
Hi, there is a fault in the controller board as it must be tripping off the alarm without the sensor giving the signal. You will need to check the controller board for sorting out, other wise just disconnect the alarm as the freezer is working and the thermostat is controlling the temperature correctly
Feb 24, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Alarm keeps sounding and blue light is flashing on dash board, if I close the door the alarm starts all over again. The alarm sounds very weak and weird. Car won't start,
This may sound silly but it worked for me. Try sticking the key in the drivers side door with the alarm going off and go through the motion of unlocking the door. Good luck.
If I have helped you resolve your problem, please
consider giving me a good rating. Thank you.
Oct 22, 2010 | 2004 Mitsubishi Galant
Chassis Intruded
try take out the battery on board for one min. then put in battery see if that works jim
Feb 16, 2010 | ASUS K8N Motherboard
Ep 4g4a+ gives alarm sounds bios does not start
look for three pins on the mother board with a jumper it should say reset or cmos reset put it on the other two for about 8 seconds put it back on the other two and start it up
Jan 23, 2010 | Computers & Internet
The intruder alarm has sounded three morning in a
check the neighbors... maybe some f them are making fun of you... try parking it on a secured area...
Jul 19, 2009 | 2006 Chrysler PT Cruiser
Will not start up and show code 0d
Hello kc59mail ,
For the FAV6800A the od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock.
I think you have a problem with the magnetic reed relay in the left lid lock. If you could try this? I want to make sure you signal an “OP” alarm to the display. Can you select Spin Only cycle with the lid open press start. Do you signal the “OP” alarm lid open to the display? If it does close the lid and the “OP” alarm should clear does it? I’m checking that the lid magnet is in place and the signaling connections are working thru the left lid lock back to the control board.
Let us know what you fin and we will go from there. You could try powering down the machine by removing the 120VAC power cord from you wall receptacle. That may give you three more wash cycles before the od alarm is triggered again.
Mar 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Problem at boot
There is a mechanical switch connector available to determine if someone has opened the chassis.
You can bypass this through the BIOS by entering the BIOS on bootup (DEL? message at bootup? F1?) then look for the system chassis intruder alarm and DISABLE
Another option is to find the pins that the switch is supposed to be connected to (documentation on the ASUS P4B motherboard) and jumper them.
Jul 03, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Aqualite stopwatch alarm
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Feb 11, 2008 | Watches
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
