Question about Poulan 1420 14Inch 20 HP Electric Chain Saw
HOW TO REPLACE CHAIN BAR ON POULAN ELECTRIC POLE SAW MODEL PLN1510
dennisgladx
  • 52 Answers
SOURCE: poulan Super 1800 16" chainsaw .
Hi dortfran,
My name is Dennis and I hope to be of assistance.
This sounds like a kink in the chain and I would try a new chain because this can be a very small kink and very difficult to find and straighten out. If you must put the chain saw in a vise by clamping the bar and run the chain back and forth from the sprocket to the bar grove under operating tension and locate the misalignment at the bargrove. Now you have located the problem but the fix is still sweat away, and with some luck you may be able to spring the chain straight and have the link flexable to opporate without a hitch.
Glad to be of assistance. Please rate the solution because i can learn from your rating.
Thank you
Dennis
Posted on Nov 09, 2008
SOURCE: poulan pro series chain saw 20" bearings seizing up on bar
There's a tiny hole on the front of the bar near the bar sprocket. This is used to grease the sprocket. If you go somewhere like Lowe's look in the chainsaw section and you'll find a grease tube that is specially designed to lube the front sprocket. Before lubing use a small wire to clean out any debris from the whole. Press the lube tube against the hole and push repeatedly until grease comes out from the outside of the bar. This should greatly extend the life of the bar.
Posted on Jan 09, 2009
Idaho_Biker
  • 32 Answers
SOURCE: 38 cc Poulan Chain Saw
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals:
http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
Posted on Jan 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: locate exploded drawing of poulan chain saw
I tried a couple locations and found a site that might help go to psep.biz and it will direct you to the blowup. It also indicated that it needed a type number so have that handy. If this doesn't help let me know and I will research further.
rowdy45176
  • 2176 Answers
SOURCE: My poulan chain saw will not start 42cc 14
K, I just looked at their site for another reason but they indicate that you need to make sure of the fuel, the on/off switch and also the spark plug (which I have personally seen) and dirty or clogged fuel lines. If you need to view the manual for the troubleshooting you can go to Poulanpro.com or call 1-800-554-6723. Good luck and let me know if you need more help
Posted on Feb 18, 2009
Part of the chain came off track
if it is a pole chain saw , and the chain came off, it is installed the same as any chain saw
undo the cover over the drive end , remove the blade and chain, loosen of the screw that adjusts the blade length
put the chain back on the blade , put the blade and chain back on the machine , replace the cover and do the nut up till it just touches the cover
adjust the screw until the chain is at a position where if you pull the chain off the bar the inside guide teeth are about halfway out of the bar guide
tighten up the cover nut
Aug 13, 2016 | Poulan pro pp338pt pole pruner - trimmer...
Chain keeps falling off
Check the machine is oiling ok, if there is not enough oil to lub the chain it will stretch causeing it to come off, you should see a good spray of oil from the tip of the bar when the saw is reving.
Jun 02, 2012 | Poulan PLN1510 8 Amp 10-in 2-in-1 Electric...
1.5 hp poulan electric pole saw - what type of oil do you put in?
Hi kim 1481...
You will use "Bar and Chain oil"...it will lube the chain and bar of the electric chainsaw.
You can find it at Ace Hardware,Lowes, Home Depot or your local hardware store.
Please take time to rate me
Aug 21, 2011 | Garden
How to put the chain back on a 14" Poulan electric chain saw
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Sep 12, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
I replaced the chain on the poulan el 14 and when I would tighten the aft bolt this caused the chain to begin to stick when I would manually move the chain
Poulan "1420 Electric Saw Type 2" (may not be your saw)http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
Open the link; Click "View the illustrated parts list [GO]" link; open the "Illustrated Parts Lists" folder; Click "Chain Saw Assembly Type 2". Compare items 20 and 21 with your saw, the flared portion of 20 should be toward the clutch cover not the engine and on the clutch side of the bar. The only other thing that comes to mind is item 23 should fit into the hole on the bar (the bar should be tight against the oiler channel; engine side of the case.). HTH
Lou
If these are correct please add comments below and we will continue.
Dec 29, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
What type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Mar 13, 2009 | Remington 16" Electric Chain Saw
Poulan 1420 14Inch 20 HP Electric Chain Saw Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
