Question about Canon imageRUNNER iR C2880 Color Copier
Canon ir c2880 wont boot - Canon imageRUNNER iR C2880 Color Copier
iservice
  • 318 Answers
SOURCE: canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Posted on Jun 09, 2009
  • 78 Answers
SOURCE: How do I get to the drum cartridges on our Canon
open front door remove clip on cover to righthand top push lever in and right hand lower door will pop open remove 2 screw 1 top left 1 top right release black handle and the whole assyembly draws out press button on top and lift up there is a little black support arm to stop it falling down unlock the drum you want to change and remove or just call the engineer if you have a service contract?
Posted on Dec 27, 2009
Testimonial: "Thanks!!!"
  • 31 Answers
SOURCE: Unable to scan from Canon IR C2880 to computer
got to canon.usa.com and download the user manual. or go to google.com and type in User manula for the canon ir c2880 copier
Posted on Jul 16, 2010
  • 86 Answers
SOURCE: When printing the printer (
The problem is probably the drum unit.Try to take out the drum unit and look at the drum.Normaly the color of the drum should be all the same across the drum,but if there is brown lines around the drum thats mean it is tiem to change the drum unit.
Posted on Oct 20, 2010
Testimonial: "sorted the printer right out"
spinal
  • 287 Answers
SOURCE: Canon C2880...how do i reset the "unknown" admin
Hello mm,
Ok, we are going into "cautious" territory as I will have to help you into "service mode" which is inherently dangerous for the untrained. But I will guide you to where you need to be,and what you need to do. You merely need to stay with me and not stray. I promise I will send you directly to the right spot, and as long as you don't let your fingers do the walking around all will be well. And as a reassurance, all functions in service mode require an "OK" so you can't accidentally press the wrong button. All smiles......here we go.Locate the "ADDITIONAL FUNCTIONS " button which is to the right of the display. In order to get into service mode you will need to use this button as you execute a 3 step process that needs to be rather fluid and graceful. Here we go. Press "additional functions" RELEASE,now the numbes 2&8 simaltaneously and RELEASE, Now press "addiotonal functions " again. This may take a try or 2 to be successful but when you succeed you will see a new screen. Press "COPIER". Another new screen. Notice the tabs across the top of the screen. Press "FUNCTION" Another new screen, and menu. Select "CLEAR". Now you have the option to clear alot of stuff. Don't clear alot of stuff. LOL . Select PWD-CLR. Once selected press "OK" in the lower right corner. TADA!!!!!!! You did it !!!!!!! Just for grins power off the machine. I normally would not suggest this method of power off but just unplug the device. If you want to it properly, then hit reset until you get back to the main screen. The hold down the main power button for 3 secs and it will walk you tru the shut own sequence.The last request the machine will ask is for you to turn off the main power, located on the right hand side of the copier, about halfway down at the very rear. Either way we have cleared the password. CONGRATS!!!!!! Please let FIXYA know if I helped. You take care. :-)
Posted on Jan 24, 2011
Error code on display E0000045-0000
Canon imageRUNNER iR C2880 Color Copierchange the drum unit, or try to dismantle it and clean but these is not recommended.
Aug 23, 2011 | Canon imageRUNNER iR C2880 Color Copier
When printing the printer ( Canon iR C2880) leaves a line devoid of colour running down the pages. how do I solve this or at least do you know what the cause of the problem is?
Oct 20, 2010 | Canon imageRUNNER iR C2880 Color Copier
Reset/change Remote UI Name and Password on iR C2880
I think that username is: admin, and pass: 0000 or 12345. If that doesnt helps you wrote on emma.servis@gmail.com for service manual.
Jul 29, 2010 | Canon imageRUNNER iR C2880 Color Copier
We have a Canon C2880 and it has started to print blank pages for no apparent reason. Toner cartridges are OK.
You need to check the laser shutter and transfer bias. Best solution would be to call service.
Unable to scan from Canon IR C2880 to computer desktop. Looking for manual for specs.
Jul 12, 2010 | Canon imageRUNNER iR C2880 Color Copier
How do I get to the drum cartridges on our Canon IR C2880?
Nov 16, 2009 | Canon imageRUNNER iR C2880 Color Copier
C2880 tray 1 lifter
pull out tray see if there is paper stuck in side were the tray slides
Oct 23, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon imageRUNNER iR C2880 Color Copier Logo
old marine
old marine
