Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
What is the part that holds the bowl on the carb it has an electrical wire coming out of it
    Novelist:
  • 212 Answers
It is a solenoid that has a plunger on it that stops fuel from entering carb when unit is shut off.
Posted on Aug 01, 2013
My toro snowblower will not start,with gas or starting fluid,no spark,stater rust cleaned off flywheel,carb cleaned,bench set,It fired with starting fluid ,but the carb had gunk in float bowl,what am
Clean out the float bowl as well clean out the fuel jet in the bolt that holds the bowl on. There usually are very small holes in this jet and if you can't see or blow through them you have to clean this out. Will not run if this is plugged. You can blow this out with an air com presser or a very small wire to push through it. Don't force anything through this hole or you could damage it. If it will start when you put a spoon full of gas in the spark plug hole and replace the plug and stalls in a few seconds it's usually a dirty carb or dirty jet. You can buy a cleanser as well to spray if needed.
Dec 26, 2014 | Toro Powerclear 221qe Electric Start...
Snow blower dying out?
Its the carburetor. Needs to be cleaned. But try this first. On the bottom of carb is a round bowl with a bolt holding it on .If snowblower has gas in it clamp fuel line to stop fuel leakage. Remove bolt and pull bowl down slowly. Look in bowl to see if there is water at bottom under gas.To be sure dump out fuel and clean out bowl with clean rag and some air. Next place a small piece of tube in bottom of carb that you took bolt out to hold bowl on. Blow air in to remove any dirt and reassemble carefully and refuel carb and start engine. Good luck.
Feb 17, 2014 | Craftsman 21" 179cc* Single Stage...
Carb flooding gas
Where is the fuel coming from? If it is coming from the button of the carb, you may have a bad gasket around the nut that holds the bowl on the carb. If it is coming out from the top of the bowl, you may have a bad gasket ring that goes around the perimeter of the bowl. In addition, if the needle is not positioned correctly in the seat, you may not be closing off fuel. If the needle gets stuck in the down position, your carb will continuously get fuel, and the float will not shut off the flow. Have you tried to take the carb off, or at least remove the bowl to inspect things?
Aug 20, 2013 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Hp gas
Follow gas line from tank to carb. Observe bottom of carb. Remove screw holding carb bowl to carb. Clean bowl. Pinch off gas line with pliers. Ensure float falls down easily. Float up no fuel flow, float down fuel flow. Observe screw that hold carb bowl to carb, see if it has a whole thru it, clean with small wire, bread wrapper works good. Observe center fuel port, clean with wire. Remove pin that holds float and meter needle, clean port with wire. Reassemble. Ensure air filter is clean, oil is full, 30w oil, spark plug is clean and properly gapped. Replace air filter and spark plug once a year. Empty old oil out if any grey is observed in oil, this is moisture, can accumulate after winter storage. Clean out side of carb with carb cleaner to ensure choke can rotate freely. Always use Stabile in gas.
All newer mowers have a low oil shutoff.
May 09, 2013 | Troy Garden
Schematic for a Briggs & Stratton fuel pump & carbrater
most of the time you will not need new parts but the only parts out of the kit you will need is the needle valve (the part on the float) and the bowl gasket the first thing you do is take off the bowl then there is a pin that holds the float down pull it out with a pair of pliers i like one sided wire plyers then drop the carb and bowl in carb acid for 45 min i use chem dip u can get the gallon can for 25 bucks at autozone or advanced auto after 45 minutes pull out the carb and blow off wih air chuck from an air compressor blow out all the littlle holes they are inside and out reinstall float and needle valve reinstall bowl turn air fuel mixture screw all the way in till snug do not over tighten or youll damage it turn back out counter clock wise 2 turns reinstall carb thank me
May 14, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Troy bilt 2550 max psi 2.3gpm pressure washer don't want to kick over
sounds like dirty carb jet. most pressure washers sit for long periods of time and many have the jet in the bottom of bowl where dirt and grime collect. depending on the model the bottom screw holding on the carb bowl is the jet. clamp or turn off the fuel to carb, unscrew the bolt out of the bottom of the bowl and look for a hole down the center and hole on either side under the bolt head. most likely these are plugged. you can take a strand out of a piece of #12 guage electrical wire and somewhat clean the holes well enough to shoot carb cleaner through them. once you clean out the hole going down to the holes going across and clean inside of bowl you can reassemble and should start. in the case of the jet being screwed into the carb assembly just look for a brass screw and unscrew it.and clean it. all jets are made of brass so look for a gold colored screw with flat blade tip screwdriver slot. if its plugged with dirt or old gas you found your problem.
Sep 20, 2011 | Troy-Bilt Garden
I have a toro push mower model 20016 with a 6.5 hp. tecumseh that wont fire. it has new gas,spark plug ,air filter, please help, thanks, clevi
First, check for spark. Pull the plug and attach the plugwire. Touch the threads to metal on the engine and pull the rope. If there isno spark, check to make sure the coil ground wire (found under the engineshroud attached to the side of the coil) is not grounded somewhere. To checkthe coil, pull off the engine shroud (also known as the blower housing), thenpull the thin black wire (not the thick black wire that connects to the plug) offthe side of the coil. This is the kill wire. Using the above procedure, checkagain for spark. If there is no spark, replace the coil. If there is spark,your problem is in the engine shut off circuit. The kill wire is grounding outsomewhere.
Note that over 90% of no start conditions on small engines are caused by fuel starvationand not lack of spark. Tecumseh's are notorious for having carb problems. Ifyour engine has a carb with a plastic float bowl, remove the bowl and clean itout and then replace the two O-rings in the bowl. One goes behind the drainscrew (or fuel shut off solenoid in some cases) and the other goes on thestand-pipe that protrudes out of the bowl. You can find a breakdown of the carbat a place like e Replacement Parts, etc. Look at the breakdown and you willsee the O-rings, stand pipe, and two springs, which must go back in the bowl inthe correct order.
If you have an aluminum float bowl, remove the carb, remove the bowl, take thescrew that holds the float bow on and hold it up to the light. There should betwo holes there and you should be able to see daylight through them. IF not,they are clogged. Take some fine wire (less than .020 in diameter) and cleanout the holes. Then make sure the main jet is not clogged. It is located on thebottom of the carb body and is inside the threaded hole that the float bowscrew \screws into. It not clean, clean it out. Make sure the float bowl isclean and that there are no minute holes it. Hold it up to the light and checkfor daylight. There should be none.
Put the carb back on and try to start the unit. If it still won't start, then Isuggest a carb teardown, an eight hour soak in solvent and rebuild the carb.Kits are available at your local small engine shop.
May 07, 2011 | Toro Lawn Mower With Toro Power Tools
Starting engine, Get Click, click, small amout of movement. Changed batt, sole, safe switch, starter, Remove Spark Plugs Engine Turns over Starter spins engine round & round. Plugs back in no good?
Check for spark at the spark plugs. If you have spark, the the problem is fuel related. If your carbs have an electrical solinoid below the bowl, unplug the wire connection and THEN unscrew the solenoid. There maybe a fiber gasket, be careful not to tear it. Unscrew the solenoid and check to see if clean fuel comes out of the bowl. If no fuel comes out, you have to clean the carb bowl and the jet. If clean and FRESH gas does come out of the bowl, then the (fuel shut off) solenoid is stuck in the OFF position. (the alcohol in our gas causes these solenoids to rust and stick) Buy a new solenoid.
NOW if you don't have spark, check the kill switches first, you may have 3 on a riding mower.You can temporaily bypass them if you don't have an ohm meter for testing.
Feb 10, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My Ariens lawn mower dose not get gas to the Carb float is OK gas line OK.When I push the primer button No gas. Spayed Carb cleaner in carb No change. What can I do next?
You have gas in the float bowl but nothing coming out when you prime correct?
You should remove the bowl jet *(should actually be the bolt that holds on the bowl) and wire brush it clean and then run a fine piece of wire strand through the jets. One of those openings is very tiny.
It is located at the top of the threads and you will need a tiny piece of wire strand to clear this. When you have cleared this and the two bigger openings at the bottom of the bolt put it back in and see if she primes. The primer just puts a raises the air pressure inside the bowl so fuel flows up the main jet. So a blocked main jet will prevent priming and running at anything above idle speed.
Good luck and be careful!
Jul 23, 2010 | Garden
Tecumseh 9hp craftsman snowblower will not stay running
First take the carb off of the engine and then remove the bowl, carefully take the float off paying special attention to the needle and how it is attached to the float. Next, lightly blow air into the fuel inlet while holding your finger over the spot where the needle goes in. Use a bread tie with the paper scraped off. Stick the wire through the pick up tube at the bottom of the carb. Find any other holes and probe those holes with the wire. Then thoroughly wash the entire carb with carb cleaner then blow the whole carb off. Then put the float and needle back in making sure that when putting the bowl back on that it seats tightly all the way around the rubber gasket. Also, just before you put the bowl on turn the carb upside down to see if the float is sitting level. If it is put the bowl on, If not then the spot where the needle sits on the float has to be bent one way or the other just a little until the float sits level. After the bowl is put in place, the nut that holds the bowl on the threaded area should have two possibly three holes plus the hole down the center, probe all holes with the wire. put everything back on the motor and try again. If it still won't run then you will need a carb kit.
Dec 16, 2008 | Craftsman 16" High Garden Tractor Snow and...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
16 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
