Question about Inter-Tel Axxess Corded Phone
How do i change the company greeting. I do not know the administraor mailbox number.
I need to know how to access the general mailbox on the Panasonic KX-T7633 to change the message received when calling in after hours.
the general mailbox can be any mailbox from 100-998... or if you have 4 digit extension numbers, 1000-9998...or it can be one of a couple hundred other greetings if you are talking about custom service menus instead of a mailbox (all this is best determined by your local panasonic dealer/serviceman)
once you know which mailbox is your general mailbox:
1) call the voicemail
2) press "#6*" + the mailbox number
3) enter password then "#"
4) press options "3" then "1" then "1"
5) record your greeting then press "1" to stop the recording then "2" to save it
6) hang up
Jan 07, 2011 | Panasonic KX-T7633 Corded Phone
Hi there, my business uses Panasonic KX-T7431 Digital Super Hybrid System and we have several lines. when nobody is available to take the call it goes directly to a company message stating are names...
The introduction message is usually setup as a custom service menu. You need to determine if this is the case by logging into the message managers mailbox and listening to find the current greeting. To log into the message manager mailbox, call voicemail, dial #6 then *98(for 2 digit mailboxes) or *998(for 3 digit mailboxes) or *9998(for 4 digit mailboxes), enter password followed by #. Once in the message managers mailbox, press 5 to record messages. Your introduction message could be the company greeting or a custom service menu. Press 1 for the company greeting and follow the prompts to listen to the greeting. Press 3 for the custom service menu, then enter the custom service number 1-100( in your case start with 1 until you find the current introduction message) and follow the prompts to listen to the message. Once you have found the current introduction message record your new message and save.
Dec 28, 2010 | Panasonic KX-T7431 Corded Phone
Trying to listen to voicemail grettings.
If your talking about listening to the individual mailbox greetings without calling into the system then you could use feature 980 (leave message)
enter in the mailbox number you want to check and press ok.
Jul 09, 2010 | NorStar M7310 Corded Phone
I'm trying to set up my voice mail and I am getting a message "mailbox locked". Is there a generic password I can enter that will work? Too, can you send me a step-by-step go-by to set up my mailbox?...
If you recieve the message "mailbox locked" then the password was incorrectlyentered too many times.
To reset your password press feature 983
the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
As far as setting up your Mailbox, press your open mailbox key or press feature 981.
When prompted to enter your password enter the password of 0000.
The voice mail will make you change and confirm your password at this point. your password can be between 4 and 8 digits but cannot start with a 0.
after the password is changed the voice mail will make you record your name for the company directory. once the name recording is accepted, the mailbox will be at your main screen.
To record a greeting for your mail box,
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
Dec 22, 2009 | NorStar M7310 Corded Phone
Not able to access our main voicemail on Vodavi Starplus STS
To access the System Administrator Mailbox:
1. Dial into voice mail: From any phone on system dial 150
2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
How to program greetings
1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
2. Press [1] to access system greetings. The system will prompt you for the greeting number
3. Enter the desired greeting number.
For example:
1 = Default Day greeting
2 = Default Night greeting
3 = Default Temporary greeting
4. You will be prompted with the following three choices:
Press [1] to Review.
Press [2] to Record. You will be prompted to record the greeting
When you finish recording, press [#] to save the recording.
You can then
Press [*] + [*] + [*] to exit the system completely
Jul 07, 2009 | Vodavi Starplus SP7314-08 Corded Phone
I need to change the main greeting!!
First of all, there are different locations for each greeting...
and you have to know which greeting you are changing.
The greeting that you are talking about:
-> is it the CCR tree? (is says - press 1 for x, press 2 for y, press 3 for z)
-> is it the Auto Attendant? (welcome to xyz company, if you know the extension of the party dial it anytime)
-> is it the General Mail box?(please leave a message after the beep)
-> is it the receptionist mailbox?(this is the receptionist personal mailbox)
In other words, what does the greeting say, maybe that might help solve this issue.
Jun 25, 2009 | NorStar T7316E Corded Phone
I have a Toshiba DKT3010sd. How do I change the main greeting on the phone? I am able to change all the personal greetings but the main greeting (the first greeting the person hears when they call our...
if the password has not been changed it would be the extension followed by 997, i.e. password for mailbox 990 would be 990997 and 991 would be 991997, you can also log into mailbox 999 and assuming that password has not been changed and is 999997 you could go into admin mode and reset the mailbox security code for 990 or 991, hope that helps.
Jun 17, 2009 | Toshiba DKT3010SD Corded Phone
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
I am trying to change our company voicemail and the manual (with the company's contact info is, who we bought the phone from) has walked away. Is there a standard code for setting the main VM greeting?...
What Toshiba Voicemail system do you have? Is it a Toshiba or third party voicemail? Depending who setup you voicemail and what version you have. Mailbox 990 is the Intro greeting "thank you for calling xyz company". Mailbox 991 is the main greeting "press 1 for sales press 2 for tech support etc. If you have a toshiba Voicemail. Need to login to 990 and 991 (need to know passwords) Newer versions you can setup just 991 mailbox for both.
Nov 26, 2008 | Toshiba DKT 3010 Corded Phone
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Inter-Tel Axxess Corded Phone Logo
Top Inter-Tel Lands Phones Experts
george  peters
george peters
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
