Question about Canon PIXMA MP830 All-In-One InkJet Printer
Pixma mp830 just out of box. copier makes loud clicking noise...copy is blurred toward end of paper works fine when using scanner function without feeding from top Seems paper feeder is broken
    Sergeant:
  • 390 Answers
Take it back for a full replacement, it sound like it has a few faults, why be stuck with it, you have the right to fair trading, which states your product must do wahta it should for a reasonable amount of time. Just out of box and faulting already is not reasonable!!! Hope you hace receipt.
Posted on Sep 01, 2007
SOURCE:
My MP830 will not print. It shows error code 5C10 and makes a loud, quick repeating clanking noise. Any suggestions?
When the printer is not functioning properly it may need to be reset. Make sure that this code is not being generated from a paper jam. Consult your manual for all the ways to check for paper jammed in the printer. (You may not be able to see the paper jam).
Then try a reset as follows:
1) On the printer panel, press and hold the <On/Off> button for one second (the display will go blank). If it does not, unplug the power cord.
2) Wait approx. ten seconds. If unplugged, plug it back in. Otherwise, press the <On/Off> button again.
3) Wait for the machine to cycle through its startup routine before trying a print job.
Dec 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Canon Pixma MP830 will not send faxes. Instead
ASF sub- roller
cleaning
When the paper fed from the ASF is
smeared due to ink mist attached to the
ASF sub-rollers.
Sep 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My Pixma MP830 is printing horizontal lines of various width across the page when printing or when copying from a single sheet laid on the glass.
Hello sir; what you need is cleaning, you neeed to clean prnt head and ink cell, you open the top part let the ink carrier move to the center then UNPLUG the power cord ,now you can easy to clean ink cell.
Aug 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
A loud banging noise from inside - as it adjusts post printing
I'd check that there's nothing that's fallen into the rear paper feed that is now causing the rollers to jam and release with the bang you mention.
If you're feeling brave I'd try holding the printer upside down (get a friend to help you and watch out for the scanner sliding out!) and give it a bit of a shake to see if anything drops out.
Jan 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 Error Message: Scanner is not operating correctly.
This problem sucks. It sounds like the scanner has actually gone bad. This can be a couple of things. The actual ccd unit inside the scanner, a position sensor, a motor or a wire harness.
The latter two are fairly unlikely, the first two more likely. Most probable is the CCD unit. I don't think Canon sells it as a separate piece, but it comes inside a replacement scanner assembly. These complete scanner units are expensive. You'll have to check with your local Canon shop to see what they cost.
Nov 06, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark x7550 Printer, Scanner, Fax - Clicking Noise Question
top feeder for the scanner (on my x6570) had a loose piece of rubber stuck between the feed wheels. The rubber is part of the guiding mechanism that guides the paper to the feed wheels. Remove rubber strip and reattach it where it belongs.
Feb 19, 2008 | Office Equipment & Supplies
Its clicking
Check and make sure that if you have something plugged into the fax/phone ports that it is installed correctly.  I had this noise when I accidentally put the usb cable into one of the ports.
Sep 15, 2007 | Canon PIXMA MP830 All-In-One InkJet...
ADF noise and rollers not moving
Dear Hs87 If there is no paper stuck/jam inside the printer and if the motor works fine, plz check again all the threats, there might be a broken threat or untight threat Thanks
Jul 02, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA  MP830 All-In-One InkJet Printer Logo
71 people viewed this question
Clive
Clive
old marine
old marine
Ekse
