Question about Xerox 4110 4127 4112 4590 4595 Drum Cartridge 013R00646
Xerox 4412 drum cartridge workcentre
Where does the drum cartridge go in the 4595 machine
4 Suggested Answers
  • 2072 Answers
SOURCE: Replace Drum
Start by trying this.
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
If that doesn't work try this. You may not be able to perform step 1 but that's ok.
> Support & Drivers > WorkCentre Pro 555 Support > Search Results Solution: Print / Clear Documents From Memory bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif
Any documents stored in memory due to an error condition will print after the error is corrected. The errors may be: 'paper tray(s) out of paper,' 'paper jam,' or 'out of ink'.
  1. Print a Pending Jobs report to determine what types of jobs are in memory. Press the [Menu] (up arrow) button, then press [2], [2].
  2. If there is a job with the status of Resend Stored Fax, turn off the Resend Stored Fax feature to delete the job.
    To turn off Resend Stored Fax:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [3], [0], [4].
      The screen will display: Resend stored fax
      1. On
      2. Off
    2. Press [2] to disable the feature.
    3. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
  3. Print the ITU-T mailbox report to determine if there are any mailbox documents. From the Standby Mode, press the [Menu] (up arrow) button, then press [2], [4].
  4. Print any documents stored in an ITU-T Mailbox:
    1. From the Standby Mode, press the [Menu] (up arrow) button, then press [1], [8].
      The screen will display: Mailbox
      1. Confidential
      2. Bulletin board
      3. Relay request
      4. Setup & delete
    2. Press [1] to select Confidential mailbox, or [2] to select Bulletin board mailbox.
      The screen will display: Confidential (or Bulletin board)
      1. Print mailbox
      2. Send to mailbox
      3. Poll from mailbox
      4. Store to mailbox
      5. Delete contents
    3. Press [1] to print from the selected mailbox.
      The screen will display: Box number (20 max)
      [_]
    4. Use the numeric keypad to enter the mailbox number, then press [Enter]. NOTE: If you entered a password when creating the Confidential Mailbox, you must enter that password now to print the document.
    5. Enter the password if required, then press [Enter].
Posted on Jan 08, 2008
Avwrexit
  • 47 Answers
SOURCE: change the drum on xerox
Here is the pdf for the manual. Check out chapter 2 page 10 it has step by step instructions on installing the drum.. This should help in the removal of the drum also!
http://download.support.xerox.com/pub/docs/CopyCentre_C20/userdocs/any-os/en/UG_Eng.pdf
Good luck and dont forget to rate my response!!
Posted on May 31, 2008
  • 2072 Answers
SOURCE: We have a Xerox Workcentre Pro575; it has an error
    1. Yes
    2. No
Posted on Nov 05, 2009
Testimonial: "Thanks very much, worked like a charm!"
Workcentre 5024. When I press the green LED button to print, why does the machine just freeze?
may have to do a rest after drum replaced and double check your installation, link below will get you to support.
press the helpful button
http://www.support.xerox.com/support/workcentre-5022-5024/support/enus.html
Jan 26, 2016 | Xerox Office Equipment & Supplies
Where can I purchase DRUM cartridges for my Xerox Workcentre 24 as I need Magenta and Cyan immediately?
go to www.partsdrop.com or aaatoner.com
or if you want immediate supply go to your nearest xerox store and purchase it if you are in new jersey partsdrop is the wholesale dealer and they will give you drums and toners in wholesale price
May 08, 2014 | Xerox WorkCentre M-24 Color Copier
Xerox 4110 fault code 077-330
ERROR CODE: 077-330, Front Door/Panel - DAMAGED
Apr 25, 2013 | Xerox 4110 4127 4112 4590 4595 Drum...
How do i reset my drum for xerox workcentre 7345
You can't reset the drums counter on the machine. The drum has what they call a CRUM on it. It's the micro chip on the drum frame. You can buy new CRUM's or use one that still has some life on it. Press the two plastic retainers to remove the CRUM.
Nov 30, 2012 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Xerox Staple cartridge stuck
If the cartridge is stuck in the slide it is because there are still staples in the replaceable sleeve, if the whole slide is stuck in the finisher, you might open the panel over the staple unit and see if you have staples stuck that are causing you to not be able to remove the cartridge.
Oct 25, 2012 | Xerox 4110 4127 4112 4590 4595 Drum...
Error 093-311
Hi
How to delete bug 093-311 in the Xerox 4112
br
Oct 06, 2012 | Xerox 4110 4127 4112 4590 4595 Drum...
Xerox WorkCentre XD125F- need manual
You can get the spec sheet and the user's guide as PDFs here:
http://www.support.xerox.com/go/results.asp?prodID=XD125f&Xlang=en_US&Xcntry=USA&Xtype=docs&prodName=WorkCentre%20XD125f%20Digital%20Copier%20-%20Laser%20Printer
The spec sheet has the toner cartridge and drum cartridge part numbers (listed as Supplies)
Toner Cartridge 6R914;
Drum Cartridge 13R551
When copier has printed about 18,000 pages the J2 drum cartridge light will come on. The unit will print about another 1,000 pages before the unit stops working until the drum cartridge is replaced.
I hope this helps.
Apr 14, 2010 | Xerox WorkCentre XD125F All-In-One Laser...
Xerox 4110 4127 4112 4590 4595 Drum Cartridge 013R00646 Logo
35 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
