Question about Dryers
Making knocking sound - Dryers
Maybe its not level
Posted on Aug 01, 2013
Does a knock sensor sound like a rod knocking
Knock Sensor contains no moving parts and can not make any noise. It only detects noise in the engine block to allow the engine control computer to make adjustments as needed.
Dec 12, 2016 | Cars & Trucks
What can cause knock sensor to get bad on 2007 ford edge
Well the knock sensor does not make any noise. It senses the vibration in the engine if there is a spark knock to let the computer know to slow down the spark timing.
You probably have a weak piston or lifter or rod bearing making the noise.
Jun 16, 2015 | 2007 Ford Edge SEL
Screechind and knocking sound when it is started
check the harmonic balancer for failure first The sound is probably the pulley slipping on the bonded rubber to the crank hub.
Jun 06, 2013 | Cars & Trucks
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Knocking sounds
Ususally knocking is a sign that the rubber belt which spins the dryer tub is old and has hardened. If the knocking sound gets quieter after you have run the dryer for 30 minutes or so, then the belt is the problem. As the dryer turns, it heats up the rubber belt and makes the belt more pliable. This quiets the knock. I have seen dryers work fine for years, knocking the whole time. Have the belt replaced if the sound bothers you.
Sep 07, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
Top Dryers Experts
