Question about Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier
Blown fuses I have an Alpine pdx 1.1000 pushing 2 Alpine 12" type R subs, and my power supply also feed an Alpine MRP-F450 for the front speakers. I have a 100 amp fuse at the battery using 4 gage wire to a Tsunami 2-farad cap then 8 gage to each amp. As I turn it up, the 4 20-amp fuses blow on the PDX 1.1000 amp. Also, my lights dim with the bass.
    Genius:
  • 1,139 Answers
This is a sign the you have poor voltage regulation. Which may mean that you are taxing the electrical system of your vehicle. I would suggest you adding a secondary electrical supply for you audio system. This can be done by adding an extra alternator and voltage regulator and battery supply. This will allow you to drive your audio system without having it (power supply) split between the vehicle and the audio system. The fact is your system is drawing to much current for the unit and your vehicle. You are blowing the 20-amp fuses which means the the amp is creating a currnet draw which is past the rated value of the fuses, which if done too many times could damage the power amp components in the unit. I would also check the ohmage reating on the speakers connect to the unit since you may have the wrong impedance which may also cause excessive current draw and actuate some sort of overcurrent protection.
Posted on Sep 03, 2007
SOURCE:
Parked my car for a day. Went to drive it last night and the sub wouldn't kick in. The sub I have is a 12inch Rockford punch p1. I have a Alpine v-power mono power amplifier MRP-M350 pushing it. Well I...
Is it possible that you may have over driven the unit and blown either the power supply or output stages? Well, if the amp is getting power as you indicate the issue lies within the stages I just mentioned.
Aug 31, 2017 | Alpine MRP-M500 Car Audio Amplifier
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
I just install my new setup ,i have 1 pdx f4 ,1 pdx m12 and 2 sub 10''type r and my pproblems is when i put a song the pdx f4 lights become red and my mid and tweeter cut ...
Disconnect all speaker leads from the PDXf4 - test. If the amp turns on and says on ok - then turn off, and attach one speaker lead at a time until it turns off. When it does check that speaker and the speaker wire to see if it is blown, shorted out etc.
Feb 06, 2011 | Alpine PDX-F4 Car Amp
PDX 1.1000 amp overheating?
Hello thefatman69e,
The Alpine PDX-1.1000 is a physically small amp to produce the power that it does. The result is that it has less physical area for heat to dissipate. Running at or near it's maximum output into a 2 ohm load, it needs some serious airflow to keep it cooled down. I'd look for some way to get more air to it.
Hope this helps.
Sep 21, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Sub will drain all the sound off the front speakers
if you have both amps connected to the same power wire this will happen...run another power wire to the alpine and this should solve the problem.
Jul 25, 2009 | Rockford Fosgate Punch 301S Car Audio...
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Has my subwoofer been blown?
hook ithe sub up to a 9volt battery and see if the woofer moves... You will not dammage the suub testing it this way.
Mar 23, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Alpine PDX-1.1000 1000W x 1 Car Amplifier Car Audio Amplifier Logo
307 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
